damien89 | Newbie with a fuel pump question. | ||
First of all hi to everybody.
I used to hang on the corvetteforum but since i found this forum i started preferring this one. Yesterday i went to start my dad's 89 to put it in the garage when all of a sudden it just died. Then i tried to start it again and i could hear the fuel pump making a whirring noise as if it wasn't picking up fuel. I went and bought 10 lit of fuel because i thought maybe it had run dry but it stayed the same (no start). The car cranks but doesn't start. Tomorrow my mechanic is coming to see if it has pressure in the fuel rail. If their isn't pressure in the rail it most probably is a bad pump right? Could it be something else? If it is the pump should i buy an acdelco one or is their something more reliable? I am from Malta Europe so internet ordering is preffered if i had to order from someone other than ecklers or midamerica. Thanks everybody. |
Posted on: 2011/1/9 18:54
bogus | Re: Newbie with a fuel pump question. | ||
Malta! Welcome!
It does sound like the fuel pump. It could also be the fuel pump sock filter. At the bottom of the pump is a white (well, when they are new) filter sock. It is about 8cm x 2cm and attaches to the bottom of the fuel pump. If that falls off, it can make picking up fuel harder, or, if it clogs. Also, the main fuel filter, which is on the right front frame rail (by the exhaust!). Since you are far out in the middle of no where, I would order a new fuel pump, new sock and new fuel filter. The new filter is easy, if the pump decided to spew garbage up the fuel line, it would be clogged... and depending on when the car last was run, the fuel line might be clogged. That would be easy to fix with an air compressor! Just remove the fuel delivery from the tank and disconnect it at the fuel filter and blow! If there is a clog, that might free it. Also, when you replace the pump, get a good one. I have been researching them lately, because the replacement ones are just not that good. I will have to dig up the names I was looking at. I will get that info later today. |
Posted on: 2011/1/9 19:20
damien89 | Re: Newbie with a fuel pump question. | ||
Thanks! |
Posted on: 2011/1/9 19:25
Ultraman | Re: Newbie with a fuel pump question. | ||
Hi welcome to the site. Hope you can hang out with us. There is a lot of things it can be as Andy is saying. If it is the fuel pump a good one I think is a Walbro 255 pump. They may be a bit more money but I think the quality is there.
A company called Specter Werkes makes a kit for the C4 that provides a new sock and gaskets and screws and such. You could check that out at www.spectergtr.com Thanks for signing up lots of knowledge about Corvettes here and some fun too. |
Posted on: 2011/1/9 19:39
I searched their site and lokks like they haven't got a pump for the 89 vette, they have for the 84-85 and 90-96 models and ZR1. Thanks anyway. |
Posted on: 2011/1/9 20:02
I had to dig a bit for it but it is on there. It's a Racetronix GSS340M fuel pump. Part # RXC569-FPA-B Enter fuel pump 1989 corvette in their search function and it will come up. |
Posted on: 2011/1/9 20:18
Thanks i found it. Would the extra pressure from the pump harm anything since my dad's vette is bone stock? Will it run normal? |
Posted on: 2011/1/9 20:48
I'm sure that the pump will work on a stock engine since there is a fuel pressure regulator that sets the fuel pressure going into the intake. That is what regulates the pressure not just the pump. If I recall those pumps will handle a lot more horsepower and fuel needs but will work well on the stock engine also.
I am not an expert like some of the guys are, but I think a little extra fuel pressure wouldn't hurt much anyway. Someone else will chip in soon with some confermation of that if I am right. |
Posted on: 2011/1/9 21:14
It's not so much pressure, it's volume. And the bigger pump can push more volume.
In general, tho, you are right. The AFPR will keep all even. |
Posted on: 2011/1/9 21:55
Matatk | Re: Newbie with a fuel pump question. | ||
Welcome to the site. The first test you have to do, as mentioned, is check for fuel pressure at the rail. Then you can look for the cause of the problem.
If it is the fuel pump, I recommend either AC Delco or as mentioned a walbro fuel pump is very good. You do not need a 255 lph pump. I have the walbro 190 lph to feed my 383 stroker and it works just fine. I purchased mine from racetronix with the install kit and it was great. http://www.racetronix.biz/customkititems.asp?kc=FPA-011&eq= or just type in fpa-011 in their search box. Matthew |
Posted on: 2011/1/10 0:03
Thanks to everyone for the replies. I will post back when i will have found the fault.
Posted on: 2011/1/10 9:21
JeffK | Re: Newbie with a fuel pump question. | ||
I got the kit from Racetronix when my pump went. It was a great package.
I agree with Andy, get a new pump and filter. Had the car presented any other problems previously? |
Posted on: 2011/1/10 12:17
SpectatorRacing | Re: Newbie with a fuel pump question. | ||
Racetronix uses Walbro pumps. At least they used to, it's been a couple of years since I talked with them.
You can easily verify if it's your pump or your fuel pressure regulator. Attach a fuel pressure gauge to the fuel rail (sounds like you already planned this). You should have around 43 psi. If you don't, it could be the pump or the regulator. Clamp off the fuel return line for a second. If the pressure spikes, then the pump is fine. If it is low, it's probably the pump. And you don't need a 255 lph pump. Everyone on the other forum loves to tell you it's a performance upgrade, but there's no advantage on a stock car. I personally use a fuel pump from a 90's Chevy pickup truck. Cheaper and higher flow... |
Posted on: 2011/1/10 15:25
aka Scaryfast |
CentralCoaster | Re: Newbie with a fuel pump question. | ||
Sounds about right. At WOT throttle, my stock engine uses about 100 lph. The rest goes right back to the tank.
Posted on: 2011/1/10 15:46
None that i know about. What i was also going to do before my mechanic comes with his gauge was to disconnect the line going in the fuel filter and turn the key on, when the pump tries to prime the system I'll see if fuel comes out. What do you all think about that? If fuel doesn't come out then most probably is the pump right? |
Posted on: 2011/1/10 19:06
You'll probably just make a mess. The pump could be too weak to start the car, but still strong enough to push gas through the line. If nothing comes out, sure, but I'd wager that some gas will flow. |
Posted on: 2011/1/10 23:07
aka Scaryfast |
hdfire | Re: Newbie with a fuel pump question. | ||
Just ordered my new pump kit from racetronix. I'm sure this is my problem too Matthew! Thanks for the link. |
Posted on: 2011/1/11 2:01
I did a write up on changing the fuel pump in the tech library. If you need help let me know. Matthew |
Posted on: 2011/1/11 3:02
Thanks for the tip that the pump would still push a bit of gas. |
Posted on: 2011/1/12 17:48
Yeah i read your write up about changing the pump. Thanks for taking the time to creating it and thanks for all the others who have helped till now. Damien |
Posted on: 2011/1/12 17:51
92LRC | Re: Newbie with a fuel pump question. | ||
Hey guys, I don't want to hijack the thread but I think I've got a problem along these same lines.
Las few times I've had the car out it stalls when I go around a corner too hard. It just dies quietly and I can get it to turn over again but it will only run for a second. It kind of sputters and almost seems like it's struggling to get fuel. I started thinking it might be the fuel pump or the strainer sock. When I run the car easy (no sharp turns) it runs fine, no stalls. But lets face it this car was made to take sharp turns so...... Any input is appreciated. Thanks |
Posted on: 2011/1/18 0:25
I recommend you start a new thread. |
Posted on: 2011/1/18 2:22
I think Racetronix is having another Sale on that other forum for anyone who hasn't gotten theirs yet.
Posted on: 2011/1/18 13:26
Today our mechanic came with the fuel pressure gauge to check the pump.
The gauge showed 10 psi when i turned the key to prime the system. Gonna order a pump from rock-auto because i had purchased from them before and they are a forum vendor. |
Posted on: 2011/1/22 17:29
Just a small update, yesterday i managed to change the fuel pump on the vette. Would like to say thanks to anyone who helped in this thread.
I would like to thank Matatk for his fuel pump removal write up, it helped me alot. The only problem i had was removing the fuel feed line. It took me almost an hour to get the pipe off. Thanks again to everyone!! |
Posted on: 2011/2/14 9:29
Glad you got it changed and we could help!
Matthew |
Posted on: 2011/2/14 12:27
