140 user(s) are online (98 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
djxib Need to buy a new opti ... *ACK*
North Georgia
456 Posts
Just picked up my new 383 from the builder - and although it dyno'ed fine he says that the opti is very worn inside and will take a crap soon. I figure that I should probably replace it anyway before I drop it into the car and I can keep the old opti as an emergency spare.
I have been researching the forums and looking at ebay and amazon - and there are so many opinions and options that I am thinking about flipping a 3-sided coin between Delphi, AC Delco, MSD.
Honestly, I have no idea how to even make a decision on this, so I figured to ask the gurus.
What opti should I buy? I will pay $500 bucks if I knew it would be reliable.
its enough to drive a man to drink...
Posted on: 2011/7/16 2:54
Andy
tjpreul Re: Need to buy a new opti ... *ACK*
The MSD is great for the early style replacement. It has a rubber o-ring, and a venting system.
Posted on: 2011/7/16 2:58
bogus Re: Need to buy a new opti ... *ACK*
20860 Posts
I have dynaspark.
Posted on: 2011/7/16 6:52
biggrizzly Re: Need to buy a new opti ... *ACK*
If you got the $$$ buy the MSD unit. Good quality part IMO
Posted on: 2011/7/16 9:31
Matatk Re: Need to buy a new opti ... *ACK*
22811 Posts
I have dynaspark.
But you have the old dynaspark. Apparently the new (third) owners are running it into the ground and putting out non-quality pieces.
I have no personal experience with buying optis (L98) but I'd go ac delco or MSD - those seem to be the two best choices for a basic replacement.
Posted on: 2011/7/16 12:05
BillH Re: Need to buy a new opti ... *ACK*
Andy, here's what my MSD looked like inside after 10k miles.
http://www.corvette-guru.com/modules/ ... id=118974#forumpost118974
Plus the MDS is vented and the GM replacements are not (important on a 92-93).
Posted on: 2011/7/16 13:20
SJW Re: Need to buy a new opti ... *ACK*
Central Maryland
51 Posts
I was fortunate that when the opti began misfiring on my '94 back in 2004, the Dynaspark was still being built by DynoTech Engineering, and that's what I installed. The car's been running flawlessly ever since. Sadly, I've been seeing almost nothing but bad reports from Dynaspark users since Phil sold the product line off some years ago.
If I were needing a replacement spline-drive opti, I think I'd probably go with the MSD unit, despite the mixed reviews I've read about them.
If I were needing a replacement pin-drive opti, it'd be a toss-up between the MSD and OEM, and I'd probably tilt toward the OEM unit because the quality difference is smaller, and the price difference is larger. But I'd caulk the unit up with RTV before I installed it...
Live well,
SJW
Posted on: 2011/7/16 14:18
20860 Posts
I have no alegence to them, just saying I have one.
The current owner, his name is Bob I think, seems on the ball.
I bought one in 2009. Several months ago, it flat out died. Code 16. Come to find out that someone screwed up the assembly and bent the tone disc, causing it to rub up against the optical pickup, lunching same.
He fixed it promptly without charge.
So far, the new unit is working fine.
Posted on: 2011/7/16 15:11
BrianCunningham Re: Need to buy a new opti ... *ACK*
went with the MSD
Posted on: 2011/7/16 15:51
teebee Re: Need to buy a new opti ... *ACK*
12391 Posts
Let's see...the first one I put on was an OEM. After about 3000 miles I started having issues. "Couldn't be the Opti it's new." After a big run around I find the cap on the new OEM opti is carbon tracking all over the place. That's when I decided to go with MSD. I very high quality unit....well worth the money in my opinion.
Posted on: 2011/7/16 16:45
djxib Re: Need to buy a new opti ... *ACK*
North Georgia
456 Posts
Thanks guys - you've swung me over to the MSD. I've read some advice where people recommend dismantling a new opti to make sure the rotor screws have loctite - should I do this with the MSD?
Posted on: 2011/7/16 18:46
Andy
That problem was mostly with guys that raced, a lot of high RPM.
But do it anyway since you will have the cap off to install it. Takes like 5 minutes.
And put the bottom vent hose on before you install it, it's way easier to put the hose clamp on that way.
The upper vent hose (with the check valve) can be teed into the vacuum line on the pass side that comes out of the intake (just to the rear of the stock opti connector.
Posted on: 2011/7/16 19:23
rklessdriver Re: Need to buy a new opti ... *ACK*
Absolutely locktite the rotor screw, and make sure the O-Ring/cap seal is properly installed when you put the cap back on.
Posted on: 2011/7/16 20:35
20860 Posts
The reason I went DynaSpark was that they are the only ones with a capless option.
Posted on: 2011/7/16 21:08
The early ones came with a round 0-ring that was a pain. The latest have a square o-ring that stays in place, it's a big improvement.
Posted on: 2011/7/16 22:02
jaa1992 Re: Need to buy a new opti ... *ACK*
Stone Mtn, GA (near Atlanta)
187 Posts
Check out the summit white box opti. The engine I put in Jan needed a newer style opti and I needed it NOW.
Its worked well so far, several events and its now on the replacement engine.
Posted on: 2011/7/18 0:09
I'd check it just to play it safe
some have found let over metal from the machining
I didn't
Just watch the gasket when you put it back together.
Posted on: 2011/7/18 0:38
I hardwired my harness in (figure 11). The connection on my car was shot due to the heat and age.
http://www.msdignition.com/uploadedFi ... ors/8381_instructions.pdf
Posted on: 2011/7/18 3:09
Yea, that's another point. The MSD 92-93 connector doesn't fit the Corvette connector, fits the other GM harnesses though (unless they made a change lately).
It's not a big deal though, just 4 wires to do.
Posted on: 2011/7/18 13:10
I found the wire config.
Cut and pasted from Tyler's (tjpreul) older post:
I ended up hard wiring mine in. Here is an answer from BillH when I installed mine.
"I need to add on the 92, unless MSD made a change recently, the opti connector will fit a Caprice harness but not the corvette.
This isn't a big deal, just 4 wires to solder and heat shrink.
Here's the wire connections:
92 LT1 MSD
black/red(stripe) to brown/yellow - low resolution
purple/white to brown/orange - hi res
yellow to red - 12 volt
black/pink to red/green - ground
The 5th wire in the LT1 harness is a ground/shielding wire. It's not needed on the MSD Opti. It doesn't connect to anything on the GM Opti either, just wraped around the other 4 wires for shielding."
Note: On the shielding, I left mine off too with no problems in 4 years.
One person has posted that they had a problem until they has that shield connected to ground.
But I'd try it without first.
Posted on: 2011/7/18 13:24
