188 user(s) are online (79 user(s) are browsing Forums)
Ultraman, captmike13, more...
red_johnny Where is the horn relay located
I am looking for my horn relay as it suddenly stoped working today. This is a 85. It was working a week ago when I was about to install a air horn. Now I have the air horn hooked up but the relay is not clicking at all. What is it supposed to look like?
Posted on: 2008/2/2 21:32
Matatk RE:Where is the horn relay located
22812 Posts
On my 89 it's under the DIC - I'm not sure on an 85. If I recall correctly it's a little black square. Someone correct me if I'm wrong on that.
Edit:
Try this link to the darkside:
http://forums.corvetteforum.com/showt ... &highlight=horn+relay
Posted on: 2008/2/2 22:21
MK 82 RE:Where is the horn relay located
Palm Beach Gardens, FL
439 Posts
I am sorry to report that it is buried in the dash. Great spot, huh?
Posted on: 2008/2/2 22:26
96 CE Roadster LT4
Notorious RE:Where is the horn relay located
In his absence I'm filling in for CFI-EFI.
Where does your FSM say it is?
RACE ON!!!!!
Posted on: 2008/2/2 22:38
red_johnny RE:Where is the horn relay located
I was digging in the dash to locate it but could not. Its still in peices right now
Posted on: 2008/2/2 22:42
Midnight85 RE:Where is the horn relay located
Streator, IL.
264 Posts
Directly behind the dic.
Posted on: 2008/2/3 5:16
Touringmike RE:Where is the horn relay located
Sussex,Wi
569 Posts
RACE ON!!!!!
Ohhh. Ouch.
As midnight85 states, Remove the DIC, fuse and relay will be right there.
Posted on: 2008/2/3 16:14
´85 4+3
Ok, call me stupid....DIC?
Posted on: 2008/2/3 17:45
Sussex,Wi
569 Posts
Driver information center,stupid.
The goofy screen where the "OD Engaged/SES/Security engaged" light is on.
Take that out, and the fuse/relays are behind it
Edit; Had to add stupid.
[size=9:fcfc263d58]You asked for it.[/size:fcfc263d58]
Posted on: 2008/2/3 18:22
´85 4+3
Ok, now that I know where to look I should not have a problem finding it. Thanks
Posted on: 2008/2/3 18:30
pappyfreebird RE:Where is the horn relay located
1028 Posts
wahahahahahahaha !!!!fell offin my bar stool!! (n i dont evin drink) hey kin i fill in fer cfi nextime huh huh kin i huh!!! ok i go to my corner now...were still funny as L...good thing ya explained the dic too...i were bout ta say hey red i r the foo and evin i know wehre mines at wahahaha
Posted on: 2008/2/3 20:54
Oaklands RE:Where is the horn relay located
Morristown, TN
480 Posts
RACE ON!!!!!
That's a macro key for Vinnie at the dark side.
Posted on: 2008/2/3 22:23
ROFL Uh, sometimes I misplace mine.
Posted on: 2008/2/4 3:26
439 Posts
I like you Pappy even though it is a bitch to understand you most of the time!
Posted on: 2008/2/4 9:35
96 CE Roadster LT4
Streator, IL.
264 Posts
I agree!!
Posted on: 2008/2/4 11:29
CentralCoaster RE:Where is the horn relay located
There's a few different things behind there, they put em there so a thief can't get to em quickly to disable the alarm.
I think the horn relay is 2nd from the left. Should be a fuse for it too which I believe also powers the alarm module.
To remove that center bezel you have to pull the cluster bezel part way out.
Posted on: 2008/2/4 20:47
It was the fuse guys! Thanks for the help
Posted on: 2008/2/4 21:10
I also forgot to add there will be a video to follow
Posted on: 2008/2/5 3:35
