180 user(s) are online (100 user(s) are browsing Forums)
brian targa top
193 Posts
So for you guys or gals that have the targa top, do you ever take it off or is it just to much of a pain to take off and put back on cause it is bolted in. Why did corvette go with something like the supras do slides in on the back and then turn a handle to lock the front. Has anyone sawed off the end of the tool and put it on a power tool so it is easyer to take off and put back on? Also, do they make things to change it from that crappy bolt on design to more like the supra or something that isnt a pain?
Posted on: 2008/3/30 13:14
Matatk Re: targa top
Of course I take the top off. That's the purpose. Only takes a minute, and then it's top off fun. No need to saw off the end of the ratchet, just buy a t45 star bit. Some guys have used a little black and decker electric hand screwdriver along with that. I've never seen a design change to have a handle instead of the bolts.
Posted on: 2008/3/30 13:18
leftoverture Re: targa top
34 Posts
If you use a power tool, make sure to keep the torque set kinda low, I don't think it would be good to strip the bolts out. . .
Posted on: 2008/3/30 13:38
1988 Z52 Coupe 4+3
pianoguy Re: targa top
I use a little Ryobi screw gun that I got at Home Depot - works great and it's small.
Be prepared for a rubbery ride when you take the targa off. The first time I drove topless I thought the front end was going to fall off. The targa top was a late decision in the design of the C4, and it bolts in because it had to be a structural member. When it's off, the car is not nearly as stiff. I installed an R-D Racing Camber Brace, and that helped quite a bit. I'm also going to install their Cross Frame, and I bought an AFSB Targa Bar - those should make it stiffer than a plank.
Posted on: 2008/3/30 14:06
xccter Re: targa top
Downtown Annapolis, MD
461 Posts
I have my Targa off at least once or twice every couple weeks from spring to fall. It's usually on during the heat of the day in summer, and off for evenings.
I recently bought a fiberglass Targa to help keep the sun off when it's hot. Makes the a/c work less.
I don't find it a pita, but anyone with even minor back problems may disagree.
´71 350/270 L48 Coupe
NCRS #48337
JeepCycle Re: targa top
Nesquehoning, PA...Pocono Mt.s
30 Posts
Lots of back problems but this is still no trouble...it's very light and proper hand placement makes it easy to balance...
Posted on: 2008/3/31 1:03
CentralCoaster Re: targa top
I think it sucks. Old men were the demographic for this car, but I can't imagine how an old man would remove the fiberglass (heavier than acrylic) roof, or open the hood, let along get inside the damn thing.
Someone designed and built a setup that used latches to secure it but he didn't go further because he couldn't afford a patent and was afraid of someone stealing his design if he started producing them.
Posted on: 2008/4/1 0:46
Oaklands Re: targa top
Morristown, TN
480 Posts
When nice weather comes around, I take my top off and leave it off most of the time. I really enjoy the fresh air coming in. As a matter of fact, my top is off now. If it is in the 60's - 70's I drive it. If it gets a little cool at higher speeds, I turn a little heat on and roll up the windows. Our weather is starting to get a bit warmer so the top will be off most of the time.
Posted on: 2008/4/1 3:28
FLYINLOW90 Re: targa top
Windsor Ontario Canada
514 Posts
Our targa is not off as often as I would like 'cause the wife gets migraines from too much sun. So I bought a headliner and installed it on the targa.
As far as removing it, I don't find it too difficult. More of a PITA than anything.
Gary
Posted on: 2008/4/1 14:30
pappyfreebird Re: targa top
1028 Posts
i myself preciate the tips...id prolly freak ifn felt that flex...so now ill be prepared fer it...but im jus in from plowin mo fuggan sno...but good newss is its awready meltin...hey i gotsum beer yontsum???? wahahahaha ja ja jive talkin uh huh heyhuh,,,yo purty momma wanna smell me!!!sarry maybe a tad bit too much jonny bravo heyhuh...ja ja jive talkin ooo yea...hey men fool maybe but i r sucking air n walkin free lifes good..n i gots me a fuggan vet dude!!
Posted on: 2008/4/1 16:11
JonnyAngle Re: targa top
Minneapolis, MN
151 Posts
It's a necessary evil. THe best thing is to get the targa sliders in the back to help guide you while putting the targa in back. Otherwise just grin and bear it.
Posted on: 2008/4/1 18:39
CAP94 Re: targa top
4 Posts
I take mine out in the spring and leave it out for as long as possible. I think it's a pain but I love the top off.
Posted on: 2008/4/2 0:16
1028 Posts
what do ya mean jonnyangel...sliders??? are they a bear to put bake on er what...ain had mine off yet..ifn i want air i ride a skooter...cars are fer compfort n speed ...maybe now ill git it all in one trip
Posted on: 2008/4/2 13:45
The sliders are just some rails you can install in the cargo area to make it easier to slide the top into its storage brackets back there. I haven't seen a need for them yet, but I get older every day :-P
Posted on: 2008/4/2 14:04
Minneapolis, MN
151 Posts
Here's a link to them on MAM. http://www.mamotorworks.com/corvette?frame=1.763
I've never used them myself but have heard good things. A true redneck might be able to fab something up to save $70.
Posted on: 2008/4/2 20:15
boomguy Re: targa top
Tacoma, WA
9 Posts
I just came back from a drive with my top removed. I rarely, rarely drive with it in. That also however means that from mid-October through mid-March it rarely leaves the garage.
Fortunately I have a company car (Magnum) so I don't have to commute in my vette.
I am also fortunate that I live around the Seattle area and from about late May until early September it is 65-80 degrees almost every day with a few puffy clouds, a light breeze and no humidity to speak of. Perfect targa weather!
As far as removal and installation, I am a very big...uh, thick guy. I'm about 6' and 335lbs. I have the rechargeable black & decker screwdriver with the T45 bit and it takes about 2 minutes to bolt it on or unbolt it. With my size and ballast I have no trouble putting it in the cargo area, I do have the solid top by the way.
The only issue is that if you are attempting to re-install the top you have to have the vehicle on very very level ground. It's okay if it is uphill or downhill but all four corners of the car need to be on a level horizontal plane. Unfortunately because the car flexes so much if you have one or more tires below the others it changes the dimensions of the opening relative to the top of the windshield and the rollhoop. The dang thing just won't line up well enough to sink the bolts in.
Anyway, that's my two cents.
What I really need is some help locating an AFSB bar from any manufacturer.
Steve Guy
Posted on: 2008/4/4 0:50
I would rather die upon my feet than to have lived upon my knees!
Here's one source for the ASFB targa bar:
http://www.prostreetcustoms.net/CorvettePage.html
I was lucky enough to find a like-new used one. R-D Racing also has a similar targa bar, but with square tubing.
Posted on: 2008/4/4 3:09
brian Re: targa top
193 Posts
Steve Guy
im 6'6 290 lbs. its not a problem with the weight of the thing it is just a bitch to unbolt. and bolt in
Posted on: 2008/4/4 3:51
vetteblondie Re: targa top
Jonesboro, AR
4659 Posts
When the weather is nice, my top comes off and stays off till it rains. But, the bolts are a real pain in the arse - surely to Gawd there is a guru in here with some mechanical aptitude who can engineer and fabricate such an adaption that we may use to get rid of the bold headache.....
Posted on: 2008/4/5 1:53
�Ugol's Law
CasetheCorvetteman Re: targa top
If you buy a T45 youre going to have the wrong bit for the job. The factory bolts are T40.
I bet to differ sir. I use this:
[IMG]http://i11.photobucket.com/albums/a185/Casethecorvetteman/Car%20work/Tools%20and%20equipment/Drill.jpg[/IMG]
And i turn the torque up to at least 20. Im yet to strip a bolt, and after i do them up with the V28 Milwaukee, i then tighten them further with a hand tool. The bolts are not going to strip out unless you cross thread them, and if youre careful, i dont see how you could.
Posted on: 2008/4/5 2:17
Sorry bout that - Case is correct, as usual...lol. And I wouldn't worry about stripping the bolts tightening them. Unless you mean the heads themselves, like the previous owner did on mine. I just bought a replacement bolt...no serious issue there.
Posted on: 2008/4/5 6:40
HAHAHA!! Thanks mate, youre a gentleman
As long as you have the right length TORX bit and its good quality, itll be a nice tight fit in the head, and should fit straight enough, and easy to hold straight when using a power tool, where as the hand tool can get on an angle abit easier and chew the head out, easpecially if the bit gets some wear. The bit im using is a FORCE, so its not likely to wear out in a hurry. If it does its got an unconditional lifetime garrentee.
Posted on: 2008/4/5 7:03
514 Posts
Right On Brad.........
IMO That is the only AFSB. I think the R-D Racing one looks like poop.
Last year I was going to get one from Pro Street Customs but I found the guy a little difficult to deal with. I may try again this year.
Gary
Posted on: 2008/4/6 1:42
Tacoma, WA
9 Posts
Thanks for the info on the AFSB, I appreciate it. A friend of mine in our Corvette Club has a TTR Targa Truss that I am hoping he will let me borrow when I go down to the track.
I just can't yet find $475 to buy the other one yet.
Steve
Posted on: 2008/4/6 8:15
Why dont you make your own or get a mate to do it for you Boomguy?
[IMG]http://i11.photobucket.com/albums/a185/Casethecorvetteman/My%20cars/Picture058.jpg[/IMG]
Posted on: 2008/4/6 9:13
Tacoma, WA
9 Posts
I am truly not mechanically inclined.
The fact that I was able to remove the headunit and all of the speakers from my car and get them back into place was a damn miracle.
I have never held a welder or bent a piece of metal other than by sitting on it.
As far as my friends go, I work in the insurance industry, not the most hands on group in the world.
I do sincerely appreciate the suggestion, it is not one that I had considered likely out of habit or practicality.
:book:
Posted on: 2008/4/6 16:21
1028 Posts
hey case er any cats any better n up close pix n maybe demensions of that thingie
Posted on: 2008/4/6 17:54
