Browsing this Thread:
2 Anonymous Users
Mekanic | Fuel Injectors! | ||
Thats right! I am offering fuel injectors here, any make, any model, and any flow rate. Custom, or stock.
From less than 300cc to over 1800! High impedance or low! And the best prices you will find. Pricing example. LT1, Autozone price, $78 EACH! That's $624 + tax! My price... How about a custom made, FLOW MATCHED set of 8 ..... for $169.95 ALL injectors I sell come with a minimum 3 year warranty. And they come with O rings! Don't spend an extra $25 on O-Rings when my injectors cost less, and have them included. We also offer injector service and rebuilding. Send us your stock innjectors, have them go through our 12 step process, including disassembling and replacing worn parts, ultrasonic cleaning, and testing, all for $15 for each top feed injector, or $20 per side feed injector. Any questions, PLEASE ask. PM me for pricing info for your application. Shop owners and dealerships are more than welcome! I myself am using a set of custom made injectors in my LT4, and so are several other members here, this is a really great product, and I look forward to serving you! ~Rich |
Posted on: 2008/8/14 14:34
pianoguy | Re: Fuel Injectors! | ||
Coolio!!
Posted on: 2008/8/14 14:53
anesthes | Re: Fuel Injectors! | ||
How much for a set of 36# at 43.5psi and 12-16 ohm? -- Joe |
Posted on: 2008/8/14 16:15
Mekanic | Re: Fuel Injectors! | ||
Joe, what application are these for?
EDIT: just looked at your mod list, I didn't know you were supercharged heh. I'll have prices for you in a couple |
Posted on: 2008/8/14 17:06
I'll probably be injector shopping this fall. I have a hunch I'm a little lean up top. Once I get traction I'll know for sure.. -- Joe |
Posted on: 2008/8/14 17:47
Custom made Bosch Design III's to flow 36lb will be $269
Posted on: 2008/8/14 18:21
Not a bad price. Whats the bosch # on them? Do you happen to know what pressure they were tested with? 3 bar or 2.7? Specific gravity of the test fluid? Price is fair! -- Joe |
Posted on: 2008/8/14 20:57
Jeffvette | Re: Fuel Injectors! | ||
This sounds like FIC.
Posted on: 2008/8/14 21:26
Its a bosch EV6 They will be custom made to flow whatever you want, at whatever pressure you specify. Use ASNU fluid, which has the same gravity as gasoline, 0.739 Jeffvette, I am working with FIC on this, I am the newly appointed sales representative for Jon. Business has been very busy for Jon lately so I came on to lend a hand on some of the websites, as well as Florida and other parts of the southeast. Jon prides himself in customer service, and with me here as well, I can help keep up with our customers everywhere. You will always be able to be in contact with either Jon or I for any questions. If I don't have the answer, I will get it. |
Posted on: 2008/8/14 23:01
BrianCunningham | Re: Fuel Injectors! | ||
I'll be needing so BIG injectors for when I put my blower on, figure 700hp.
Posted on: 2008/8/15 0:17
I can do anywhere between 30 and 50psi in the design III for the same 269.
And I can offer much much larger, but it would make tuning the engine to idle and be drivable would be very hard. I'll run the #'s and see what would suit you ~Rich |
Posted on: 2008/8/15 0:26
The GEN III injectors are not supposed to be tampered with - they are a 1 pc injection molded design. How are they 'custom making' them?? Let me know! -- Joe |
Posted on: 2008/8/15 0:59
It will never idle. Been down that road. I'm an advocate of 'big injectors' and the right tune, but you cannot idle (reliably) with pulsewidths lower than 1.5 msec. Most 700hp cars make about 50hp at idle, which means at 1.5 msec you're looking at about a 38# injector. A 42 will prolly give a rich idle, or erratic injection. At 700 HP under boost with a BSFC of .6 you need 52# injectors at 100% duty cycle. 52s will never idle, not in a million years so what you'll need to do is get an adjustable regulator so your running around 45psi at idle and around 65psi under boost. -- Joe |
Posted on: 2008/8/15 1:04
The injector isn't plastic, its a plastic cover over a stainless steel core. Jon wont even tell me what exactly he does to modify them. BUT!... I'll get a dissected picture of a design III so you guys can see whats going on in them. And I'll get a video up of some of of our modified Design III's on the flowbench, all on a common rail at the same fuel pressure, all flowing different amounts. Brian, doing the #'s it looks like at an 80% duty cycle your going to need some 65lb injectors. |
Posted on: 2008/8/15 1:23
901stvette | Re: Fuel Injectors! | ||
just wondering how you come up with that number.. also my prev car was a 4.6 mustang with a rousch blower. Boosted to 14.. we ran 60lb seimens deka on that motor on the street till i lost control on the cross bronx one night.. It idled perfect. rousch performance did the programming and all was well.. still liked that car..
Posted on: 2008/8/15 1:53
HP X B.S.F.C
------------- NO OF INJECTORS X .80DS = LBS/HR PER INJECTOR BSFC = .50 FOR NA .60 FOR SUPERCHARGER .65 FOR TURBOCHARGER So it would be 700 x .60 = 420 8 x .80 = 6.4 420 / 6.4 = 65.625 And I agree, its all in the tune on how it will idle, but the larger the injector the more difficult to tune |
Posted on: 2008/8/15 2:01
OK. Just a little confused. Bosch III is a fully plastic injector: http://i20.ebayimg.com/03/i/000/dd/e3/bb4a_1.JPG EV6 is different - I agree. So the $169 ones are Bosch III and the "custom" ones are EV6? I'd love to see the video! I'm really curious how you guys are modding them. I'd be interested in a set of 36# eventually (36# at 3 bar). Do you guys have any flowbench charts showing the injector tested? I'm curious what the flow is like at varied pulses, vs static? Thanks! -- Joe |
Posted on: 2008/8/15 2:43
EV6's are design III's, http://fuelinjectorconnection.com/sho ... p?_a=viewProd&productId=8
The video will show all 4 injectors that will be on the rail will be the same core, all 24lb bosch 3's, 3 of them will be custom flow rates from us. I'll find out about the charts. |
Posted on: 2008/8/15 15:03
chevylu | Re: Fuel Injectors! | ||
From the man: http://forums.corvetteforum.com/showthread.php?t=2104010 |
Posted on: 2008/8/15 16:21
I'm getting a new one from him showing 4 24lb design III's, 1 @ 24lb, and the other 3 custom flowed by us |
Posted on: 2008/8/15 17:01
Those are Bosch III's. You can tell from the EV1 connector, rather than an EV6 connector found on EV6 injectors: http://cgi.ebay.com/ebaymotors/Bosch- ... ihZ023QQitemZ360073468837 The Bosch III's would be the ones I want. the EV6s wouldn't work in my car as they have EV6 connectors, and I have EV1 connectors. Quote:
Thanks! -- Joe |
Posted on: 2008/8/15 17:02
the EV6 is the type of core, I can get you EV6's with Toyota connectors if you like.
Here is the new vid |
Posted on: 2008/8/15 19:18
I'm definitely running a boosted referenced regulator. So, what I need is an injector that can handle the flow at the high pressure, but have a nice spray pattern at reduced pressure for idle. |
Posted on: 2008/8/16 4:03
I'll get you a price on some 65's if your interested Brian.
Posted on: 2008/8/16 8:01
Sure
Posted on: 2008/8/16 11:30
PM Sent Brian
Posted on: 2008/8/16 20:31
Posted on: 2008/8/17 2:41
It takes a lot of knowhow and some specialized equipment. I don't even know how he changes injector sizing
Posted on: 2008/8/17 2:55
hey can he punch out some hyabusa motorcycle injectors.
Posted on: 2008/8/18 3:44
Ohh, good question, I'll find out!
Posted on: 2008/8/18 3:52
hyabusa use a 28 lb injector that is not modifiyable. they use a inverted cone pintle that cannot be tamperered with..
the hyabusa uses a 3 bar regulator.. if your running lean try geting a 4 bar reg. 60psi and set the constant to 36. Should do the trick |
Posted on: 2008/8/18 4:16
thanks i will definatly do that.
Posted on: 2008/8/18 4:32
no prob! Good luck Travis, your 30's are shipping today |
Posted on: 2008/8/19 18:42
Little thursday bump, and was wondering if Travis had gotten his injectors yet?
Posted on: 2008/8/21 15:22
Travis93 | Re: Fuel Injectors! | ||
Just got them, going out not to install.
Posted on: 2008/8/21 17:43
alright, let me know if you need any info on the install, the LTx is very easy to do, once youve done it, it takes about 30 minutes hehe
Posted on: 2008/8/21 18:44
Were cookin up something really special for the L98 guys, I should be able to release info tomorrow.
For everyone who has been waiting, there wont be any reason after this :D |
Posted on: 2008/8/26 0:39
Matatk | Re: Fuel Injectors! | ||
Matthew |
Posted on: 2008/8/26 14:03
Alright! I've been waiting a few weeks to release this and we finally have them in!
For the TPI guys, I can now offer the full install kit for only $30 more. Comes with the plenum gaskets, runner gaskets, and viton o-rings for the fuel rail. So when you order injectors, if you want the install kit, everything needed will come right to your door! So 22lb Bosch design III drop ins, with the install kit, for $199.95 , and the 24lb with install kit for $219 . Injectors only are still available, but with this there is no running around looking for the gaskets, 1 call to get it all! |
Posted on: 2008/8/26 17:58
Wow that is a good idea. One stop shopping is where it's at.
Here's a question - What upgrades will the bosch IIIs handle on the motor? For example - I (eventually) plan on the following, whenever I get around to it - headers w/exhaust, ported plenum, big tube runners, ported intake, mild cam, ported heads (possibly), chip. Will the 22s support that? Or will I need to upgrade to the 24s? I don't want to buy 22s and then 6 months from now need to upgrade injectors. Matthew |
Posted on: 2008/8/26 18:44
Oh, and for guys wondering, that's a great price for the extra gaskets, etc. Just the o-ring kit alone from gm is about $28. Plus the convenience of it all makes it well worth the price.
Matthew |
Posted on: 2008/8/26 18:45
I can understand that totally, with the heads and cam a larger injector would suit you much better. What power level are you expecting when its all done? And yeah, were really excited about the kit, saves a lot of money, and tons of time |
Posted on: 2008/8/26 18:49
Mekanic wrote:
Once done, I'd be happy w/300 at the crank. I don't need a lot, just to spice it up a little. That's 55 over stock (for my 89). I have ohmed my injectors, they test fine hot and cold, but I still have that little hard start problem. Also, the performance doesn't seem consistent. Some days it feels much stronger than others. I still have a few more tests to do, but I'm convinced my injectors are leaking. Just a feeling (yes, very scientific, I know). I already replaced the FPR. I just don't want to do everything twice (at a 3 hour job to replace the injectors) and pay twice. But, like everyone else, I don't want to dump $2,000 in all at the same time, even though that's the best way to do it. My first step was going to be porting the plenum/intake and big tube runners, with the head/cam package to follow later. I may have to rethink that. Matthew |
Posted on: 2008/8/26 18:58
At 300-330HP the 24's would do just fine. I understand not wanting to take stuff apart more than once, I'm the same exact way haha.
Posted on: 2008/8/26 19:10
Also, for the leaking, put a gauge on it, prime the rails, and then let it sit, a leaky injector will drop the pressure really quick.
I'm using the design III's in my car and noticed a big difference in idle and partial throttle response. My vette has the same thing where 1 day it will feel tame, and the next it feels like it wants to tear your face off with acceleration haha. My friends LT1 camaro did the same as well. I have no idea as to why tho |
Posted on: 2008/8/26 19:21
Lichen | Re: Fuel Injectors! | ||
Are you guys pretty much restriced to Chevy injectors? I'm looking for some for my '97 Tacoma.
Posted on: 2008/8/27 1:04
Not restricted to chebby's at all. I'll get you a price
I just need to know what engine it has. |
Posted on: 2008/8/27 1:36
1997 Tacoma 4x4. 2.7 liter 4 cyl.
Posted on: 2008/8/27 2:20
Rich -
BTW, I had some free time today, so I played with the car a little. Finished doing my FSM steps for the fuel system and narrowed it down to....you guessed it....leaky injectors. So my previous "scientific guess" was ok...lol. Anywho, the wife wasn't too keen on my idea of heads and a cam, but I'm still gonna do the intake work, SLP big tubes, ported/siamesed plenum, and possibly LT or shorty headers. Do you think I'll need 24s for that? What about a chip - any ideas there? Thanks, Matthew Oh, and the car ran *great* today after doing all my tests...I adjusted the TV cable and that helped, too. |
Posted on: 2008/8/27 2:37
Well 22's will support up to 281CHP , 24's will do 307CHP, but you will need have a chip burned.
PCM4Less would be able to do it easily. |
Posted on: 2008/8/27 3:18
