238 user(s) are online (192 user(s) are browsing Forums)
Matatk TPI vs LT1 intakes
So tell me if I'm nuts, or what. I currently have my stock TPI on my 89. I've got another 89 plenum and intake sitting in the garage waiting for me to port, along with a brand new set of SLP runners for it. Pretty much had my mind set on this deal. But now I've been considering just doing the converted-LT1 intake swap instead. I see them for sale every once in a while, and the cost would be the same. I could sell my other parts without issue. I think performance-wise they should be similar based on things I've read, but I'm just not sure what to do. Seems like the converted-LT1 would be easier to install.
I know I'm just ranting here, but what do you guys think?
Posted on: 2009/1/8 17:58
Notorious Re: TPI vs LT1 intakes
It's definitely easier to install. Even the most practiced will spend some hours R&Ring a TPI set-up where these intakes can be installed in a fraction of the time once it's set up and all changeover parts are on hand. Although of course on an LT1, there's no distributor involved in the process, I can easily R&R mine in an hour, surface cleaning and all.
Posted on: 2009/1/8 18:12
I hate sporks...
DaleD Re: TPI vs LT1 intakes
Cuyahoga Falls, Ohio
1389 Posts
The TPI is better looking, if you care.
Posted on: 2009/1/8 18:16
Skidmarks Re: TPI vs LT1 intakes
Blue Mound, Illinois
98 Posts
There is a distributor with the TPI to LT1/mini-ram swap that I believe he is talking about.
Posted on: 2009/1/8 22:31
Dirt is for racing. Pavement is for getting to the track.
85L98-84L83 Re: TPI vs LT1 intakes
113 Posts
I'm still rocking the TPI on my 85 but one day I will install my superram once I aquire vortec heads and a cam.
Posted on: 2009/1/8 22:43
Of course there is, I never said there wasn't.
BrianCunningham Re: TPI vs LT1 intakes
It is?
Posted on: 2009/1/8 22:56
Randyj75 Re: TPI vs LT1 intakes
MD
129 Posts
I have considered it also; I read a post by Josh (Neat) over at the other place, and his costs were very close to the mini ram. I have also read there can be tuning issue's, not sure if that's true or not. I think you would need a small cap distributor, and I would make sure the intake that you buy has been machined correctly. If the distributor hole is not in the right place, it can cause the dist gear to not mesh correctly w/ the gear on the cam. You also want the holes for the water outlets to be on the front of the manifold, not the rear.
Randy
Posted on: 2009/1/9 0:41
CentralCoaster Re: TPI vs LT1 intakes
Why? The price of the vortech base more than offsets any savings you get on the heads.
Posted on: 2009/1/9 3:20
Matatk Re: TPI vs LT1 intakes
Randy
Thanks, Randy. I've been looking at this swap for about 6 months now, but decided to do the TPI early on. I just figure now the LT1 is so much easier and would be less difficult to R&R if there were problems. After installing my Bosch III injectors I found out how much of a PIA the TPI system is.
As far as the intake itself, I see them for sale every once in a while. Like this thread:
http://forums.corvetteforum.com/c4-pa ... s-lt1-intake-for-l98.html
The guy had it on his car for several years with apparently no issues, so seems like it has been machined/set up properly.
As far as aesthetics, I could care less either way.
Posted on: 2009/1/9 15:46
patgizz Re: TPI vs LT1 intakes
Medina, OH
228 Posts
i bought one from pr0zac becuase i wanted to do the swap. then i started figuring in changing the distributor, harness for that, i don't like the remote thermostat housing idea one bit - so i bought a superram. i had to buy 1 2/3 of them to get good parts but in the end i've always wanted one.
Posted on: 2009/1/9 22:22
1389 Posts
BrianCunningham wrote:
It is?
I think so.
Posted on: 2009/1/9 23:13
to each his own
Posted on: 2009/1/9 23:57
Ok, well is there anyone on here who has actually done it?
Posted on: 2009/1/10 1:32
113 Posts
I have the vortec base on the shelf, I got it on ebay for $112.
Posted on: 2009/1/10 5:39
Danspeed1 Re: TPI vs LT1 intakes
Mooresville, North Carolina
1121 Posts
Posted on: 2009/1/10 7:21
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
Thanks, Dan. I've been to that website a few times. The best information on the swap, I think, is over on the thirdgen boards. More guys over there seem to have done the swap.
Posted on: 2009/1/10 17:32
Nice! I picked up a used edelbrock base for $65 and massaged some stock runners and matched them up to it. It's a stretch. I think I'll just get some large tube runners instead.
I want it to look stock.
Posted on: 2009/1/10 18:17
