83 user(s) are online (45 user(s) are browsing Forums)
GRIS, more...
JimD Brakes/87
NJ
14 Posts
I need new pads, and rotors on the rear. Any recommendations, and where should I buy, thanks Jim.
Posted on: 2009/2/3 20:23
NC Kid Re: Brakes/87
North Carolina
1671 Posts
I like Napa rotors. Hawk for brake pads.
Posted on: 2009/2/3 20:26
CentralCoaster Re: Brakes/87
I got the rotors turned at pep boys for $8 each and ordered some Hawk hps pads from tirerack. I don't know why everyone throws perfectly usable rotors away.
Posted on: 2009/2/3 21:00
88BlackZ51 Re: Brakes/87
481 Posts
because it's fun........
Posted on: 2009/2/3 21:38
pianoguy Re: Brakes/87
I like the Hawk ceramic pads I installed last year - almost no dust at all. Good choice for a DD. performancepeddler.com usually has some good prices on them.
Posted on: 2009/2/3 23:27
JimD Re: Brakes/87
NJ
14 Posts
rotors have been turned once already, thats why I'm getting new ones, Jim.
Posted on: 2009/2/4 0:40
Danspeed1 Re: Brakes/87
Mooresville, North Carolina
1121 Posts
Because after you turn a set of rotors, and you drive in traffic on the turnpike during rush hour, the rotors are warped to hell after about 500 miles.
I like Rotor Pros Slotted Rotors, my second choice is a set of Napa Rotors, with a set of Hawk HPS Pads.
DG
Posted on: 2009/2/4 3:24
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
Show me a set of warped OEM rotors and I'll show you $100. Break them in properly, and you won't notice 0.030" difference in thickness.
Rotorpros is just another ebay special made in China. Probably not an issue for a street car, but I'd rather let you be the guinea pig.
Posted on: 2009/2/4 5:44
anesthes Re: Brakes/87
Boston, MA
Because brand new rotors are $20 each at autozone, and turning rotors reduces the thickness which increases stopping distance.
-- Joe
Posted on: 2009/2/4 11:32
Boston, MA
How much runout do you want to see ?
-- Joe
Posted on: 2009/2/4 11:34
BillH Re: Brakes/87
Yep, warped rotors are rare.
Posted on: 2009/2/4 13:24
SpectatorRacing Re: Brakes/87
Yup, very rare. Very elusive. About as common as a two horned unicorn.
In other words, non-existant. The pulsing often confused with warpage is simply uneven buildup of pad material on the surface. Turning them removes this and exposes fresh metal. So does dragging the brakes with cold (abrasive) pads.
However, i'm also of the opinion that for $20 I'd rather get new ones.
Posted on: 2009/2/4 15:26
Aardwolf Re: Brakes/87
Fremont, WI
209 Posts
I haven't seen $20 rotors for years! Autozone.com has only one listed for the rear at $68.99. How does a thinner rotor increase stopping distance???
For online shopping try racepages.com they have free shipping.
Posted on: 2009/2/4 16:10
-- Joe
Actually they're $55 per front and $40 per rear. Made by Durasuck.
You're spending more money for surely lower quality than the OEM rotors.
How does a thinner rotor increase stopping distance? It would have a tiny effect on heat capacity. You're probably shaving off about 5% of the mass.
If your driving style depends on that last 5% of heat capacity, then you really have no business running duralast rotors either.
Cheap rotors = core shift
Posted on: 2009/2/4 17:52
Actually a rotor with bad core shift will expand unevenly as it heats up and cause pedal pulsation and even jerk the steering wheel back and forth. Basically warping, but only while hot. Turning a rotor with core shift won't resolve that, in fact I think it would make it worse.
These parts run through so many middlemen and get rebranded that its impossible to know exactly what you're getting.
You can at least open the box before you buy and visually check core shift though and casting quality in the vanes. It won't tell you anything about metallurgy, but its a start.
Posted on: 2009/2/4 18:28
I'm working on a few lawsuits where Chinese cast iron waste piping is causing problems. It's well documented that some of the foundries are putting out garbage quality pipes with porosity and cracks. They coat the inside of the pipes with a paint brush taped to a stick.
The problem is, the distributors don't even know where their overseas suppliers are getting it from, and the source can change at any time. Different sizes are made in different foundries too.
After these products are UL/CE/ISO/IAPMO/WHI whatever certified for use, the QC goes unchecked. The only criteria after that is how cheaply can they be manufactured without getting their customers caught up in too many lawsuits for selling defective product.
The end result is a product that's more difficult to install and has a shorter life. People are so obsessed with first-cost and quality products can't possibly compete with that. This further inflates the cost and reduces availability of the good stuff, which continually drives more people to buy garbage that they otherwise wouldn't.
Posted on: 2009/2/4 18:40
