213 user(s) are online (161 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
flyboy rattle from hell
I'm embarassed to admit how much time I spent poking, prodding,pushing,pulling,squeezing,prying,listening,etc.,inside,outside,up and down trying to find the rattle from hell that seemed to eminate from the frowny face pictured. It turned out to be the pipe from the A.I.R. pump that connects to the Cat. It would vibrate against the trans. hump after the car warmed and on left hand turns and telegraph the noise to the upper dash. Figure that out! Almost drove me crazy. I was able to salvage something out of my dash and console disassembly by replacing the Bose tuner with one with a working C/D, hardwire my radar detector and add a antenna switch that I mounted in the console. All's well that ends well.
jpg  rattle from hell.jpg (162.00 KB)
1735_49a1f4908750f.jpg 568X426 px
Posted on: 2009/2/23 1:18
Dads90 Re: rattle from hell
Pearland, Tx
318 Posts
Man I hate rattles.. Was about to rip out things and all it was, was the Ebrake vibrating, a little electric tape, fixed. Glad you found it, others aren't so lucky.
Posted on: 2009/2/23 2:08
pianoguy Re: rattle from hell
That looks like way too much fun - should've replaced the heater core as long as you were in there ;-)
Posted on: 2009/2/23 2:55
Schrade Re: rattle from hell
flyboy wrote: I was able to salvage something out of my dash and console disassembly ...
Salvage???
That's how you get to 'know' your vette. Disassemble, clean, photo-document, etc., ... even if nothin' is wrong.
I do that kind of stuff for FUN. EVERYbody who has a vette, or any car they wanna' keep up should do that.
My 2
Posted on: 2009/2/23 3:20
Epimax Re: rattle from hell
Wilmington, NC
1814 Posts
Glad you found it!! I installed this (pic below) a while back when I was changing out my heater core. It's attached with a lot of 2 sided tape; however, it rattles like you wouldn't believe.
It's coming out this week.....
jpg  c1.JPG (110.22 KB)
1871_49a286da37a0b.jpg 640X480 px
Posted on: 2009/2/23 11:22
CentralCoaster Re: rattle from hell
Get a louder stereo!
Posted on: 2009/2/23 16:51
BrianCunningham Re: rattle from hell
That's not such a bad idea.
like doing the WP and the opti together, whichever fails 1st.
Posted on: 2009/2/23 20:04
crash Re: rattle from hell
WRIGHT CITY MO 63390
977 Posts
thats what i like about being old and wearing hearing aids. i dont hear the little stuff. and when i do hear something its easier to find.
ps yes your in that far by all means put a new heater core in it.
Posted on: 2009/2/24 0:45
flyboy Re: rattle from hell
Thanks, but it's back together. On to bigger and better projects. Blade, I'm getting to be so "intimate" with the Vette, soon I'll know it better than my ....
Posted on: 2009/2/24 3:39
pappyfreebird Re: rattle from hell
1028 Posts
im wid cc ...crank the tunes n fug it,,when it falls of then hopefully ill see it..nawt really i kinda a freak that way too
Posted on: 2009/2/25 1:54
Rattle sounde like shaking dice inside a plastic cup. It had to go!
Posted on: 2009/2/26 2:05
vetteblondie Re: rattle from hell
Jonesboro, AR
4681 Posts
I hate crap like that. One of my speakers has something loose behind it I can't find, and my air vent on passenger side vibrates. Has a folded up piece of paper in there now. works.
Posted on: 2009/2/26 2:23
�Ugol's Law
