Epimax | Vent Grills and Lights | ||
Nice, easy project for a change! Got the 'grill' material from home depot: aka-gutter covers! Picked up the led lights from Auto Zone...
Posted on: 2009/2/27 11:53
Durango_Boy | Re: Vent Grills and Lights | ||
That looks awesome, even being so subtle.
I did that to mine too...I really like the results, and it adds a 'new' look to it. [IMG]http://i106.photobucket.com/albums/m242/durango_boy/DriversVentMedium.jpg[/IMG] [IMG]http://i106.photobucket.com/albums/m242/durango_boy/CIMG0834.jpg[/IMG] |
Posted on: 2009/2/27 13:15
Trae1976 | Re: Vent Grills and Lights | ||
Nicely done! Haven't seen that on a C4 before.
Posted on: 2009/2/27 13:20
itlgo2 | Re: Vent Grills and Lights | ||
Posted on: 2009/2/27 15:13
CentralCoaster | Re: Vent Grills and Lights | ||
Another easy way to get those vents to light up is to soak the motor in gasoline and start it up.
Posted on: 2009/2/27 15:46
1Fast04Vert | Re: Vent Grills and Lights | ||
That's been done before, did't quite work out. |
Posted on: 2009/2/27 18:25
flyboy | Re: Vent Grills and Lights | ||
I like.
Posted on: 2009/2/28 2:17
Epimax | Re: Vent Grills and Lights | ||
Thanks DB! Those looks great-Front and side! Man, I'm loving those side pipes too!! |
Posted on: 2009/2/28 2:43
Thank you Sir! |
Posted on: 2009/2/28 2:45
Posted on: 2009/2/28 2:46
Thanks! |
Posted on: 2009/2/28 2:47
Posted on: 2009/2/28 8:02
Dads90 | Re: Vent Grills and Lights | ||
I would like to try this. How is it secured to the inside of the panel ?
Posted on: 2009/3/2 1:55
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
apeacefulstorm | Re: Vent Grills and Lights | ||
does debris get trapped in there?
Posted on: 2009/3/2 2:17
"I have the need, the need for speed...." |
bogus | Re: Vent Grills and Lights | ||
nothing really passes through, except air. The radiator stops everything...
I like the look. I would do mine with green LEDs |
Posted on: 2009/3/2 4:47
I cut a single piece, folded it so that it would fit inside the panel openings nice and tight. Then, I used gorilla glue along the edge that is in contact with the inside of the panel, and it's in there nice and tight. As Bogus stated, nothing passes through there but air, and I don't think the inserts would decrease the air flow that much anyway. The lights are secured by double sided tape. All together, material costs were less than 10 bucks! My kinda project! |
Posted on: 2009/3/2 11:13
Thanks Andy! I thought about installing red ones in there! Also thought about wiring them to the turn signals, but it just wouldn't be as cool, IMO! I'd have to sit in the garage with the blinkers or emergency flashers on to admire the lights! |
Posted on: 2009/3/2 11:21
