skirlin | How do you tell if a wheel bearing is bad? | ||
I had a car once with a bent axle and when driven down the road your could feel it and when placed on jack stands the wobble was easily seen. Late last season I think my right rear wheel bearing went bad. Upon acceleration it made a 'thump,thump, thump' sound that increased as I sped up. No sound while coasting or while at steady speed (i.e.: 70 mph on the highway). I tried to move the axle shaft but it was solid. While jacked up I tried to move the wheel by hand but it was solid. I did notice while installing new shocks that the rim is bent (lip). I also noticed the lower control rod has a shiny spot corresponding to the tire.
My idea is the bearing is bad causing the tire to contact the control rod while under load. The car has 143K on it. Any input would be greatly appreciated. I have the funds to fix, I just don't want to start throwing money at it hoping to find the problem. Been there done that. Please help. Thanks. |
Posted on: 2009/2/23 6:26
There is no point in living if you can't feel alive. |
bogus | Re: How do you tell if a wheel bearing is bad? | ||
Are the bearings OE? If so, you really need to consider new ones. They historically only last about 90k miles.
There is a wiggle test, too. Another guess is the rear rubber bushings. I know mine are shot. I am planning on getting the banski kit. |
Posted on: 2009/2/23 8:05
Woodstock | Re: How do you tell if a wheel bearing is bad? | ||
Wheel bearings tend to make a hammering sound and it's get better or worse during cornering.
My 7 year old Good Year's made noise like a worn out wheel bearing, what a difference with the Kumhos. You might just lost a weight and need a tire rebalanced. |
Posted on: 2009/2/23 13:44
91 convertible |
xccter | Re: How do you tell if a wheel bearing is bad? | ||
When the rear bearings went on my '88, one season apart, it was more of a low growling sound. 110k miles or so.
When I replaced them, they looked really horrible. Like they'd been left sitting in rusty water in the back yard for months. After replacement, the rear end had no noticable noise at all. Make sure you replace the teflon washers too, and they have to be installed correctly. They can go on one of 2 ways. The right way, and the wrong way. I didn't on the first one, and got a loud clicking sound every time I put the car in gear. [IMG]http://i260.photobucket.com/albums/ii12/xccter/RearWheelBearing.jpg[/IMG] |
Posted on: 2009/2/23 14:31
ยด71 350/270 L48 Coupe Numbers Matching Ontario Orange 4 spd, Mid-year side pipes, deluxe black leather, ac, ps, pb, pw, tilt/tele steering wheel. 93k miles. Original rotors still riveted to the hubs! NCRS #48337 |
A few other points...
1. At 143k, don't be surprised if you have a siezed ujoint. 2. The stub axle rusts a bit within the bearing. That will also make it make noise. Whenever you do the bearing, hit the axle with a steel brush and then coat with antisieze. 3. If you replace the rear bearings, be ready to torque the stub axle bolt... I mean TORQUE that sucker!!! 200 ft lbs is the updated torque rating. I am not looking forward to that one... yuck. I am going to get a pipe for my torque wrench, so I can leverage better. 4. I reiterate the importance of the bushings. The rubber hardens and they just don't do the job anymore... it's bad... real bad... |
Posted on: 2009/2/23 15:46
skirlin | Re: How do you tell if a wheel bearing is bad? | ||
Thanks for the response. I am planning on new wheels and tires so that is one area. Sounds like replacing the bearings was in the future anyway. I was thinking about shopping at Corvette Central.
U-joints, sounds like a good idea at about $18 each. Now, rubber or polyurethane bushings?. Are they difficult to put in? Now for the torque on the bearings. 200 ft/lbs? FSM says 66, why so much more? I am getting excited, summer is coming. |
Posted on: 2009/2/23 17:12
CentralCoaster | Re: How do you tell if a wheel bearing is bad? | ||
Then the FSM is wrong.
I think that 66 ft lbs applies to the 3 torx bolts on the backside of the bearing. Why is the wheel lip bent? Are you sure the entire wheel isn't tweaked? Did you run over something? An out of balance wheel will destroy a bearing must faster. |
Posted on: 2009/2/23 17:24
1Fast04Vert | Re: How do you tell if a wheel bearing is bad? | ||
[quote]
CentralCoaster wrote: Then the FSM is wrong. I think that 66 ft lbs applies to the 3 torx bolts on the backside of the bearing. quote] My 95 FSM calls for 167 ft lb on those three bolts. |
Posted on: 2009/2/23 17:35
Well, there's your typo.
No way in hell those T55 bolts should see 167 ft lbs. They would snap right off. The manual has them backwards. And I recall they had a TSB or something that upped the torque on the spindle nut. So... 66 ft lbs on the torx bolts, and 200 ft lbs on the spindle nut. These are also consistent with standard torque settings for the size and grade of the bolts in question. |
Posted on: 2009/2/23 17:51
From the 1984 service manual:
Hub/bearing to knuckle: 59-73 ftlbs. Spindle to hub/bearing: 151-177 ftlbs. |
Posted on: 2009/2/23 17:54
Oh yeah, 1992 FSM does say 164 lb.ft. for the spindle and 66 for the hub mounting bolts. 66 on the spindle would be bad. As for the wheel,I am not sure why it is bent. I have not hit anything in the short time I have owned it. The sawblades are beat up at all four corners and they put 255/40r17 on it (9.5" wheels) which I really don't like because the rim sticks out further than the tread width. I am flip flopping between Z06 (black or comp grey) or the GS A-molds (17x11) with new rubber all around.
Posted on: 2009/2/23 18:38
VtVette | Re: How do you tell if a wheel bearing is bad? | ||
Are the Teflon bushings mentioned in posts 4 and 5 the ones that go on before the large nut which gets torqued to 200lb ft? 2 Hard to tell from the picture.
thanks. |
Posted on: 2009/3/18 1:40
Brian VTvette 1993 triple black roadster 6 speed |
vetteoz | Re: How do you tell if a wheel bearing is bad? | ||
Cheapest genuine AC Delco bearings $100 http://www.corvetterecycling.com/product_p/7470501.htm |
Posted on: 2009/3/18 3:04
What a coincidence, FedEx is scheduled to deliver two of these tomorrow from corvetterecycling.com. I also have all of the half shaft ujoints and control arm bushings ready to go. Gonna be a busy day Saturday. I went with the comp gray Z06 wheels, looks great. Before: [IMG]http://i296.photobucket.com/albums/mm183/skirlin/PICT0057.jpg[/IMG] After: [IMG]http://i296.photobucket.com/albums/mm183/skirlin/PICT0060.jpg[/IMG] I'll post pictures when it is all done and on the ground. Dave. |
Posted on: 2009/3/18 5:04
klkordzi | Re: How do you tell if a wheel bearing is bad? | ||
Noise when you corner or turn is a test for wheel bearings. If you turn right and hear noise, it's the left side bearing and vice versa.
Posted on: 2009/3/18 23:35
jhammons01 | Re: How do you tell if a wheel bearing is bad? | ||
No, that Teflon coated washer goes on the spindle prior to the bearing being placed. |
Posted on: 2009/3/19 1:24
Matatk | Re: How do you tell if a wheel bearing is bad? | ||
Good to know for future reference. Which side of the washer goes in/out? Matthew |
Posted on: 2009/3/19 2:26
It's pretty obvious when you stick it on there. The ID is flared out and only fits one way.
Posted on: 2009/3/19 4:00
Oh, I see how it is.....OK OK I give!! I DON'T KNOW I hope you are happy with what you've done..... |
Seriously, I think the Teflon would face outwards. But I am not for sure
Posted on: 2009/3/19 4:02
Hey, I'm good at asking questions, what can I say? I can give a lot of answers, too. They won't be correct, but I can give them Matthew |
Posted on: 2009/3/19 11:38
rickreeves1 | Re: How do you tell if a wheel bearing is bad? | ||
I'll be doing this soon. |
Posted on: 2009/3/20 16:43
95-Lt1-auto-Polo-Conv, 125hp ZEX N2O dry, LE Cam 226/234 565/565 109LSA, Comp Pro Mag 1.6rr, Patriot Xtreme Springs, PCMFORLESS, K&N, AO Ram Air, 52mm TB, EM LT Headers, X-pipe, Meziere HD EWP, Vigil 2800, TransGo Shift Kit, Pro-Built Trans, 24lb SVO'... |
Both sides are painted with whatever that stuff is.
Also where did the teflon thing come from? Is that just myth or published somewhere? |
Posted on: 2009/3/20 20:12
