129 user(s) are online (86 user(s) are browsing Forums)
cuisinartvette Whats missing from this 400?
[IMG]http://i7.photobucket.com/albums/y276/CNCBLOCKS/bblock.jpg[/IMG]
Posted on: 2009/11/19 7:51
anesthes Re: Whats missing from this 400?
Boston, MA
Must have been a 4-bolt block huh?
-- Joe
Posted on: 2009/11/19 11:20
TommyT-Bone Re: Whats missing from this 400?
33807 Posts
The stuff it needs to work.
Posted on: 2009/11/19 11:58
Matatk Re: Whats missing from this 400?
22810 Posts
The rest of it.
Posted on: 2009/11/19 12:39
Durango_Boy Re: Whats missing from this 400?
I would kind of like to see what's left of the crank that used to be in there after that kind of devastation.
I sure hope this wasn't someone's bright idea to remove 4 bolt main block material and weld it into a 2 bolt block. Yikes.
Posted on: 2009/11/19 13:23
Mekanic Re: Whats missing from this 400?
Tampa Bay Florida
827 Posts
pffft, JB weld and Zaino that bitch will put down... about 600HP
Posted on: 2009/11/19 13:28
~Rich
Polo LT4
1Fast04Vert Re: Whats missing from this 400?
Have anchor, boat needed?
Posted on: 2009/11/19 13:39
BrianCunningham Re: Whats missing from this 400?
Ouch!
Posted on: 2009/11/19 14:29
RedGut86 Re: Whats missing from this 400?
36 Posts
Almost there, just take out those useless cylinders and you have a budget lightweight 400 block that weighs what an Al block does. Suck on that.
Seriously though, what the hell happened there. The uniformity of the damage is what is most frightening. Butchered 4 bolt conversion? Story?
Posted on: 2009/11/19 20:03
jhammons01 Re: Whats missing from this 400?
I wonder if the Oil pan still holds oil....
Posted on: 2009/11/19 21:35
22810 Posts
Not necessary. That's a new design engine. The lack of pistons and a crank cuts the friction to zero, thus oil is no longer required.
Posted on: 2009/11/19 23:09
cuisinartvette Re: Whats missing from this 400?
400 blocks can be prone of cracking if you throw too much at them that one made just under 500hp, yanked the main webbing clean out of it. What caused that particular block to go I dont know, not mine. Just posting it for fun.
Have seen many live at higher power levels fwiw.
Posted on: 2009/11/20 1:33
bogus Re: Whats missing from this 400?
20860 Posts
what a mess that is... time to recycle. The scrap iron is worth about .40 a lb.
Posted on: 2009/11/20 5:10
Greg Re: Whats missing from this 400?
Corydon, IN
11 Posts
A little detonation goes a long way.
Posted on: 2009/11/20 5:11
36 Posts
Wow, that doesn't seem like ridiculous power and in a 400, impressive that the whole webbing ripped out. It would be interesting to watch how that progressed.
Guess the SHP block makes more and more sense.
Posted on: 2009/11/20 5:47
Boston, MA
It was a 4 bolt block, right?
I've heard of this happening to the 4 bolt 400 blocks. Believe it or not, they are weaker than the 2-bolt.
If I were to do this again, i'd probably go with a Dart block for $1500.. I probably spent more in machining making my 400 2-bolt 'bulletproof' than what a Dart block would cost me needing only a final hone.
-- Joe
Posted on: 2009/11/20 13:53
tpi421vett Re: Whats missing from this 400?
Salt Lake City Utah
125 Posts
I have a friend that's a local bracket racer. 406 about 500-550hp 2 bolt block. The same EXACT thing happened to him. He makes alot of passes each year, and hearing the horror stories of 4 bolt blocks having issues, he stayed with a 2 bolt block. The amazing thing was it didn't hurt any of his rotating ass'y. I guess he got lucky... sort of!
Posted on: 2009/11/26 0:40
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
