183 user(s) are online (126 user(s) are browsing Forums)
BrianCunningham wait for it to be above freezing before washing DD?
right now my trucks covered in salt
I'd like to wash it all off, but I've been waiting for the temps to climb about freezing even though I'd use a car wash.
don't want to be driving an ice berg afterwards
make sense or not?
Posted on: 2010/1/12 16:58
1Fast04Vert Re: wait for it to be above freezing before washing DD?
You might as well wait. What is in your forecast?
Posted on: 2010/1/12 17:29
Aardwolf Re: wait for it to be above freezing before washing DD?
Fremont, WI
209 Posts
It's fine to wash a vehicle in the cold. It's freezing around here for months and it's very common to wash the salt off in car washes.
Posted on: 2010/1/12 18:36
DaleD Re: wait for it to be above freezing before washing DD?
Cuyahoga Falls, Ohio
1389 Posts
I usually wait until it's around 28* or higher. If you wash a car when it's near freezing, even if it's below, the radiant energy of the sun will usually warm the car enough to keep the locks from icing.
If it's very cold, or if you wash later in the day, you're asking for iced locks.
Posted on: 2010/1/12 18:41
BrianCunningham Re: wait for it to be above freezing before washing DD?
That's the trouble
I don't leave for lunch
So it sounds like I need to hit in on my way in to work
suppose to be in the 40's Friday anyways.
Posted on: 2010/1/12 18:45
Fremont, WI
209 Posts
I used to spritz some WD40 in the locks before winter but I've been to busy to take care of all the cars here now. There have been zero problems with frozen locks.
Posted on: 2010/1/12 20:00
TommyT-Bone Re: wait for it to be above freezing before washing DD?
33772 Posts
Pics?
Posted on: 2010/1/12 20:18
Jeffvette Re: wait for it to be above freezing before washing DD?
No heated garage with a floor drain?
Posted on: 2010/1/12 20:52
Matatk Re: wait for it to be above freezing before washing DD?
I have a heated garage but floor drains are illegal around here.
I washed my truck on Sunday to get the crap off of it. Temp was about 15-20 outside and by the time the car left the heated dryer in the wash the water left on the mirrors was frozen. I've never had a problem.
matthew
Posted on: 2010/1/13 1:12
Touringmike Re: wait for it to be above freezing before washing DD?
Sussex,Wi
569 Posts
Used 4 buckets of water to wash my truck today. I got a long handled brush I use for washing. Water spigot is turned off, plus the hose reel is in the garage, and it's frozen.
It was 27 degrees when I did it.
Bottom of the driveway is now a skating rink.
Temps approaching 35 tomorrow. Going to do the wife's family truckster tomorrow.
Posted on: 2010/1/13 2:47
ยด85 4+3
floor drain in garage could = BOOM!
that's why I want to go to a carwash
I've seen those things exits completely iced up.
Posted on: 2010/1/13 14:43
