269 user(s) are online (218 user(s) are browsing Forums)
TommyT-Bone, more...
Also known as SMC.
The only issu...
Jeffvette 85 no start
1) Have fuel to rail 38 psi which is within range
2) Fuel to cylinders, test light pulsing on injector when starting, plugs have fuel smell as well.
3) Spark at each cylinder.
Cranks over like a champ but does not catch.
Distributor was set at TDC. At wits ends on this.
Any suggestions or trails to go down?
Posted on: 2010/10/29 7:10
captmike13 Re: 85 no start
Hillsboro Mo
2166 Posts
Double check for fouled plugs and correct gap.
Posted on: 2010/10/29 10:24
13 GMC 3500 dually
captmike13@yahoo.com
Matatk Re: 85 no start
TDC on compression stroke for cylinder 1? Are you sure it's not 180 out? Is it a tooth off?
Check all wires and also plugs like Mike said.
Is it a strong spark or a weak one?
Posted on: 2010/10/29 14:23
BillH Re: 85 no start
If the disty's wrong, it will backfire somewhere.
The puzzling thing is that the plugs aren't wet, I'd think you've cranked it quite a bit.
How hard is it to pull an injector on a 98 to see if it's actually squirting?
Posted on: 2010/10/29 14:59
Hillsboro Mo
2166 Posts
It is a pain to pull the injectors. The intake and runner tubes need to be removed if I remember correctly.
Posted on: 2010/10/29 18:38
13 GMC 3500 dually
CentralCoaster Re: 85 no start
It's a bitch to pull injectors compared to most cars but you can install 1/2 the fuel rail upside down and watch the injectors spray during cranking. (remove dist fuse during this test).
What does it do with starter fluid spraying into the TB? remove maf for this of course. Also, it will not idle cold with maf unplugged, but it should still fire up and then die right away as the ecm cuts the fuel.
Posted on: 2010/10/29 19:35
Jeffvette Re: 85 no start
Hard to start when the exhaust is completely plugged from mice!
Up and running after I chiseled all the crap out of the pipes.
Posted on: 2010/10/30 7:57
Maybe you need some exhaust cats.
Posted on: 2010/10/30 12:23
TommyT-Bone Re: 85 no start
33774 Posts
Sonofabitch.
Could it be the devious work of
jpg  Rat-Woman--40374.jpg (199.35 KB)
852_4ccc14313ea64.jpg 750X1147 px
Posted on: 2010/10/30 12:48
rayquayle Re: 85 no start
139 Posts
Good one, Bill.
Posted on: 2010/10/30 12:55
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
Sounds like the search for their new home was exhausting.
Maybe they thought the holes in the mufflers were swiss cheese.
Posted on: 2010/10/30 14:12
383tpimachine Re: 85 no start
Corpus Christi
976 Posts
Woah never heard that one. Did any skeletons fly out?
Posted on: 2010/10/30 16:45
1970 El Camino-Awaiting LSX
