Jeffvette | 85 no start | ||
1) Have fuel to rail 38 psi which is within range
2) Fuel to cylinders, test light pulsing on injector when starting, plugs have fuel smell as well. 3) Spark at each cylinder. Cranks over like a champ but does not catch. Distributor was set at TDC. At wits ends on this. Any suggestions or trails to go down? |
Posted on: 2010/10/29 7:10
captmike13 | Re: 85 no start | ||
Double check for fouled plugs and correct gap.
Posted on: 2010/10/29 10:24
Matatk | Re: 85 no start | ||
TDC on compression stroke for cylinder 1? Are you sure it's not 180 out? Is it a tooth off? Check all wires and also plugs like Mike said. Is it a strong spark or a weak one? Matthew |
Posted on: 2010/10/29 14:23
BillH | Re: 85 no start | ||
If the disty's wrong, it will backfire somewhere.
The puzzling thing is that the plugs aren't wet, I'd think you've cranked it quite a bit. How hard is it to pull an injector on a 98 to see if it's actually squirting? |
Posted on: 2010/10/29 14:59
It is a pain to pull the injectors. The intake and runner tubes need to be removed if I remember correctly.
Posted on: 2010/10/29 18:38
CentralCoaster | Re: 85 no start | ||
It's a bitch to pull injectors compared to most cars but you can install 1/2 the fuel rail upside down and watch the injectors spray during cranking. (remove dist fuse during this test).
What does it do with starter fluid spraying into the TB? remove maf for this of course. Also, it will not idle cold with maf unplugged, but it should still fire up and then die right away as the ecm cuts the fuel. |
Posted on: 2010/10/29 19:35
Jeffvette | Re: 85 no start | ||
Hard to start when the exhaust is completely plugged from mice!
Up and running after I chiseled all the crap out of the pipes. |
Posted on: 2010/10/30 7:57
Maybe you need some exhaust cats. |
Posted on: 2010/10/30 12:23
TommyT-Bone | Re: 85 no start | ||
Sonofabitch. Could it be the devious work of |
Posted on: 2010/10/30 12:48
rayquayle | Re: 85 no start | ||
Good one, Bill. |
Posted on: 2010/10/30 12:55
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
Sounds like the search for their new home was exhausting. Maybe they thought the holes in the mufflers were swiss cheese. |
Posted on: 2010/10/30 14:12
383tpimachine | Re: 85 no start | ||
Woah never heard that one. Did any skeletons fly out? |
Posted on: 2010/10/30 16:45
