Browsing this Thread:
2 Anonymous Users
brian | washed my car.. pics | ||
ok all done washing the car. heres some pics. i need a motor for one of the lights and i need advice on how to fix the other. didnt do pics of the inside cause dirt is just CAKED on and i need to replace everything but the carpet.
Posted on: 2008/3/13 19:21
Edited by brian on 2008/3/13 22:09:13 Edited by brian on 2008/3/13 22:10:05 |
jhammons01 | Re: washing my car | ||
Posted on: 2008/3/13 21:00
TommyT-Bone | Re: washing my car | ||
That sounds like my belts when I first crank them suckers up till they warm up a little. Cover up your distributor and altinator with a plastic shopping bag. Avoid spraying electronics and wiring harnesses as much as possible. Use a degreaser and let it soak a little before you spray. Don't wash your car before you clean the engine compartment. Wash it after. |
Posted on: 2008/3/13 21:41
brian | Re: washing my car | ||
k thanks. i just got done washing the car trying to upload now but my grandmas computer sucks really bad. i didnt wash the engine. also the pics suck cause its with my camera phone o well
Posted on: 2008/3/13 21:45
LD85 | Re: washing my car | ||
I love that color :thumbleft:
Posted on: 2008/3/15 13:28
2005/Z51 |
brian | Re: washed my car.. pics | ||
yeah its a nice color :D, but once i fix the engine and inteior and tranny im going black with red racing strips.
Posted on: 2008/3/15 14:11
patsfan05488 | Re: washed my car.. pics | ||
Looks nice !! Good luck with your new child.
Posted on: 2008/3/15 14:23
volzfan | Re: washing my car | ||
:me2: :me2: |
Posted on: 2008/3/15 15:28
'98 Coupe, LS1, Corsa Pace Car Exhaust, WCC "X-Pipe", Blackwing CAI, C6 Z-06 wheels, Custom two tone (Pewter/Black) Seat Skins from "Corvette Originals" Vettes of the Smokies |
anyone no how to fix the lights? i no one needs a motor but the other one is like loose.
Posted on: 2008/3/15 22:47
so no one knows what is wrong with that other headlight?
Posted on: 2008/3/18 20:47
Does anyone no why the drive side light isnt flush?
Posted on: 2008/4/11 4:33
captmike13 | Re: washed my car.. pics | ||
Here is what I was sent. Hope this helps.
The headlight housing cover is held onto the headlight drive housing by a couple of small torx head screws just under the headlight and a phillips head screw on each outside towards the rear. You can see them with the hood open. The headlight hood plate is held on by two bolts with 9 or 10mm heads just under the headlight cover, and a couple more at the back end under the headlight bulb. If you turn on the headlights and then at the midpoint of their swing open/out, push the knob back in just until the power to the lights stops, you can get at all of the screws and bolts. You can also use the manual motor screw on top of the headlight motors to manually rotate each headlight to the midway point. You don't need to remove anything to make the adjustment. Just loosen the headlight hood plate cover bolts a bit and tweak the plate until it sits flush. This may take a few attempts to get it exactly right, as you have to close the headlights each time to check your results. It my be a bit frustrating to get it perfect, but once you do, you will probably never have to do it again, as replacing a burned out headlamp doesn't require removing the hood plate. There are also two bump stops that can be adjusted that look like the ones for the hood. They are what stop the headlamp assembly when rotating. These may be all you need to adjust to make your covers fit flush. |
Posted on: 2008/4/11 5:10
lt4obsessed | Re: washed my car.. pics | ||
Nice looking ride my friend! About those lights, for the time being you can manually open/close the lights with the knob located on top of the assembly with the hood open. At least you can have them both open or closed.
There was an article some time ago in "Corvette Fever" magazine about how sometimes it's not the motor but just the bushings/bearings that go bad. (they're plastic) If you go to manually move the light and hear/feel resistance this may be your problem. If you go to their website they might have it archived. Good luck with the ride. |
Posted on: 2008/4/15 12:54
1996 LT4 Black on Black. |
tobijohn | Re: washed my car.. pics | ||
I seem to remember that too. And I also thought there's an exact fit cheaper alternative for those bushing/bearings from some other application too. I'll try to remember where I saw that... |
Posted on: 2008/4/18 2:22
John 1996 LT4 coupe black/black 160 Tstat, K&N, Hypertech PPIII (for the fans), CAGS, Nitto 555 EPs, 275/315s, Chrome A-molds, a little tint and some black-outs AIRFOIL FREE! |
thanks for the info but i am in the process of selling that car but i will tell the buyer about this website. i got a 2002 hayabusa thats why im selling
Posted on: 2008/4/18 2:48
pappyfreebird | Re: washed my car.. pics | ||
pardon my ignorence all ta L ,,,but whats a hayabossa,,,any pix
Posted on: 2008/4/18 16:11
FATED | Re: washed my car.. pics | ||
If this car has the original headlight motors they don't have the bushings like in the article.
Real reason for reply is that color metalic bronze. It looks a lot like the color of my 85 but hard to tell from my computer. |
Posted on: 2008/4/18 21:03
1985, Performance Chip, hole in muffler, and other Mods |
Hey my corvette was stolen and my insurance agent is trying to get me for insurance fraud. does anyone no what color my car is. i told him like a light brown but he called me and was like um your car looks silver. does anyone no the exact color?
Posted on: 2008/8/1 7:08
TommyT-Bone | Re: washed my car.. pics | ||
What year Vette?
Posted on: 2008/8/1 11:26
convas | Re: washed my car.. pics | ||
My guess would be Medium Gray Metallic.
Posted on: 2008/8/1 12:21
CentralCoaster | Re: washed my car.. pics | ||
That sucks.
This car is Dark Bronze Metallic. http://www.cardomain.com/ride/347939 Same as yours maybe? Why does the insurance co. care? What company are you dealing with? |
Posted on: 2008/8/1 17:04
You should make this a new thread.
Posted on: 2008/8/1 17:05
yeah thats the same color ill tell my insurance dude. im with progressive.
Posted on: 2008/8/1 19:42
