310 user(s) are online (261 user(s) are browsing Forums)
CentralCoaster TPI vs. LT1 or miniram dyno curve?
Does anybody have back to back comparisons on either of these?
I recall the low end of a TPI and LT1 being nearly identical, yet everyone seems to think the TPI is superior there. I'm not convinced.
Posted on: 2009/1/9 16:16
cuisinartvette Re: TPI vs. LT1 or miniram dyno curve?
Thinking of doing a conversion?
Posted on: 2009/1/9 17:25
anesthes Re: TPI vs. LT1 or miniram dyno curve?
Boston, MA
What do you think will have more low end a 400hp miniram combo or a 240hp stock L98?
To answer your question, Mike Davis did some back to back testing that may help:
http://www.eecis.udel.edu/~davis/z28/winter01/dyno/
Mike's a nice guy too if you need to ask him questions.
-- Joe
Posted on: 2009/1/9 18:31
Boston, MA
How do you guys in CA get away with things like that? I thought if your car doesn't pass smog they lock you up and make you listen to Al Gore presentations?
-- Joe
Posted on: 2009/1/9 18:32
BrianCunningham Re: TPI vs. LT1 or miniram dyno curve?
Posted on: 2009/1/9 18:34
Aardwolf Re: TPI vs. LT1 or miniram dyno curve?
Fremont, WI
209 Posts
I remember a thread from CF awhile back:
http://forums.corvetteforum.com/c4-ge ... 5-l98-torque-monster.html
Same numbers yeah, I'd rather have an LT1.
Posted on: 2009/1/9 19:00
1989GTA Re: TPI vs. LT1 or miniram dyno curve?
61 Posts
Now with a modified TPI you get the best of both worlds.
Posted on: 2009/1/9 20:23
BeachBum Re: TPI vs. LT1 or miniram dyno curve?
751 Posts
I think that is a pretty good article, thanks for sharing.
I think what is more important is the performance, which they show at the end of the article as below.
Track Results
............SR........LT1
R/T........0.609.... 0.561
60'........1.962.... 2.027
330'.......5.508.... 5.588
1/8........8.396.... 8.467
MPH........86.11.... 86.14
1,000'.....10.866... 10.921
1/4........12.947... 12.994
MPH........108.14... 108.43
The above is pretty much what I saw with the comparison vs the Miniram, but mine was a bit more et difference, which was probably due to my automatic application. They used a T56 manual with the above test as per the article.
Posted on: 2009/1/9 20:51
751 Posts
The long tube TPI is superior in off-idle torque than the LT-1..... it'll make literally 40 more ftlbs down at 2500-3000 rpm...... but it sacrifices to much rpm to do it..... hence the LT-1 is drastically superior to the TPI long tube runner set-ups in my opinion.
For stock motors, the actual peaks are probably similar at close to 350 or whatever, but they occur 1000 rpm apart.
The Superram is a different animal though, it'll give you an extra 500-1000 rpm over the stock TPI....and yet only give away a little torque off-idle, but makes up for it and then some by 4000 rpm.
Posted on: 2009/1/9 20:58
CentralCoaster Re: TPI vs. LT1 or miniram dyno curve?
I don't really care about the superram.
The reason I ask is I see stock LT1s constantly putting down 300 ftlbs of torque at 2000 rpm, and is flat as a pancake too.
So I'm wondering how the TPI can possibly beat that.
92 LT1 with no mufflers and SLP chip:
http://www.lt1.net/images/vette/c4dyno.jpg
95 LT1 Firebird with catback (see lowest line):
http://www.lt1.net/images/dyno.jpg
95 LT1 with long tubes and chip:
http://www.dragtimes.com/images_dyno/ ... evrolet-Corvette-Dyno.jpg
Posted on: 2009/1/9 21:25
BrianCunningham wrote:
Track Results
That's disappointing.
Had the launch and 60' times been equal, the LT1 would have actually had a better ET in the 1/4. You can see after the 60' mark, it actually caught up to the superram a bit.
Posted on: 2009/1/9 21:33
patgizz Re: TPI vs. LT1 or miniram dyno curve?
Medina, OH
228 Posts
the LT1intake.com test is apples/oranges.
Posted on: 2009/1/9 22:07
751 Posts
I don't think this is exactly what you're looking for, but its the best I can help you. It does kind of give a good idea of what the two torque curves look like like considering the LT-1 produces a torque curve similar to the Miniram intake, with that, these two superimposed dyno graphs show the difference in torque between the two styles. The motor is a 383 with somewhere around a 236/242 cam. These were both done on the same motor & dyno.
[IMG]http://i526.photobucket.com/albums/cc342/tldrane/TPIvsMR.jpg[/IMG]
Posted on: 2009/1/9 22:18
751 Posts
Track Results
In my opinion, on slicks with equal launches, the difference in et would be greater.
Posted on: 2009/1/9 22:19
Josh Re: TPI vs. LT1 or miniram dyno curve?
This is pretty close to what you are looking for. It's my stock-ish L98, a heads/cam LT1, and a hotcammed LT4. My turd did make a little more down low than either of these cars.
Green = My L98.
Red = 96 LT4, hotcam, long tubes, cat back, electric water pump, 4.09 gears, tuned by me.
Blue = 1995 LT1 with LE1 heads/cam, long tubes, mail order tune.
All cars are ZF6 cars.
The heads/cam car would have made more if I had been allowed to tune it. You can see how rich it gets towards the end of the pull. Probably another 10 RWHP or so in the fueling on that one. Spinning it out would have netted a bigger number as well, but this thread is about the low end of the engines, so peak numbers shouldn't really matter.
The LT4 car runs at the drag strip with me quite a bit and on any given day he is between a full second and 1.3 seconds faster than I am. He also traps 10-12 MPH higher. He also sixties better than I do, mid-low 1.7's to my high 1.7's low 1.8's. We both run bias ply ET streets. All in all, his car is MUCH faster than mine, regardless of the low end numbers.
jpg  joshchristodd.1.jpg (0.00 KB)
Posted on: 2009/1/9 22:24
751 Posts
Considering you have a ZF6, that is a pretty good test. An auto will throw off the low numbers due to the converter flash on a chassis dyno..... but not yours.
Posted on: 2009/1/9 23:52
C4 Corvette 436 - Pure Black
751 Posts
For those curious, here are the 3 dyno graphs of the Stock TPI, Miniram and Superram all on top of each on the same 383 motor. Kind of interesting if you're a TPI guy.....
[IMG]http://i526.photobucket.com/albums/cc342/tldrane/SR-MR-TPIA.jpg[/IMG]
Posted on: 2009/1/9 23:53
vetteoz Re: TPI vs. LT1 or miniram dyno curve?
http://www.compcams.com/Community/Art ... Details.asp?ID=1737510521
Posted on: 2009/1/10 13:02
LD85 Re: TPI vs. LT1 or miniram dyno curve?
Indianapolis, Indiana
784 Posts
have you considered the HSR?
Posted on: 2009/1/12 13:09
2005/Z51
Boston, MA
He needs a singleplane and a big vortech blower.
-- Joe
Posted on: 2009/1/12 13:28
784 Posts
-- Joe
I don't know,,,, going fast isn't for eveyone
Posted on: 2009/1/12 18:24
2005/Z51
How so? It's clear to me the LT1 had a worse launch, yet still caught back up a little afterwards. I don't think the LT1 intake will ever be the limiting factor on the 60' of a stock vehicle, or even with drag radials.
Posted on: 2009/1/12 22:01
751 Posts
My opinion is based upon my own personal experience between the Miniram and Superram. I ran them back to back on a A-B-A test...... the SR had a harder 60 ft by a tenth.... the MR could never recover from that, in fact it got worse.
However, a Miniram is not an LT-1 intake, but they do provide fairly similar torque curves when looking at apple to apple comparisons.... with that said, in my opinion, both on slicks, the difference between the two would have been greater, I think the SR has the ability to 60 ft MUCH harder than an LT-1 with the same street set-up. The LT-1 is a limiting factor.... it simply does not generate the mid to low rpm torque that the SR does, which prevents it from accelerating with the Superram.
However, roughen up the LT-1 with a loose converter and the right cam/gear combination and it'll fly passed the SR at all increments.
Posted on: 2009/1/13 0:21
Ah ok, I forgot about the converter limitation.
Would you agree with me though on a 6-speed?
I guess some of the comparisons I may have seen could've had different stock heads and cam. So perhaps the newer design was compensating a bit for the loss of torque from the intake.
Posted on: 2009/1/13 0:25
751 Posts
I really don't know with a 6 speed, I would just be guessing, I've never done any testing. I am sure somebody else has at one time or another.
But, I will say, the trend with gearing an LT-1 6 speed seems to be more along the lines of 3.73-4.11, and the SR or TPI's, 3.07-3.54..... and thats going to help the LT-1.
But, I don't know, I am sure there are some with some experiences that could chime in. At the end of the day, as I had said in another thread, regardless of if its a SR, MR or LT-1 intake, they're all good and a big step over a TPI intake. Pick your poison and go have fun :thumbright:
Posted on: 2009/1/13 3:20
