BillH | Today's Shop Tip | ||
When you're working on your car and have bolts, nuts, clips, etc. from different areas laying everywhere. A neat way to separate them and make your reinstall easier is to use a 6 or 12 hole muffin pan.
You can even note on the pan where the screws came from with a Sharpie and remove the Sharpie with brake clean when done. I've been using one for a long time for stuff that will get put back together quickly. i use baggies for the longet term stuff. |
Posted on: 2009/3/14 15:33
psycovette | Re: Today's Shop Tip | ||
THanks for the great tip now if you want to make that even bette place a magnet on the bottemand the whole pan will be magnatized.
Posted on: 2009/3/14 16:35
Spend money I don't have, on things I don't need, to impress people I don't know. Anyone can restore em...it's takes a real man to cut one up |
Matatk | Re: Today's Shop Tip | ||
Never thought of that - good tip. I like to draw the part on a piece of cardboard and poke the bolts through it. Keeps them from falling out and losing them, too.
I like the magnet idea, psy. Matthew |
Posted on: 2009/3/14 20:31
CentralCoaster | Re: Today's Shop Tip | ||
I did the cardboard trick a few times when I was new to working on the vette! An old speaker magnet works great for keeping bolts and screws from disappearing. |
Posted on: 2009/3/14 21:47
TommyT-Bone | Re: Today's Shop Tip | ||
How do the muffins taste next time the wife uses the pan?
Posted on: 2009/3/14 22:20
Jeffvette | Re: Today's Shop Tip | ||
You shouldn't be talking about her muffin. |
Posted on: 2009/3/14 22:40
pianoguy | Re: Today's Shop Tip | ||
Probably better than the turkey's gonna taste after I used the baster to suck out my old power steering fluid. |
Posted on: 2009/3/14 22:55
Turkey tasted a little funny after I used the baster to suck out my old brake fluid, but damn that bird could stop on a dime! Matthew |
Posted on: 2009/3/14 23:07
itlgo2 | Re: Today's Shop Tip | ||
did someone mention, muffin?
Posted on: 2009/3/15 1:54
BrianCunningham | Re: Today's Shop Tip | ||
My thoughts too |
Posted on: 2009/3/15 2:29
BillH | Re: Today's Shop Tip | ||
I've done that with the speaker magnet that CC mentioned. I also have a couple of Harbor Ft. magnetic parts dishes, got them on sale for $0.99. |
Posted on: 2009/3/15 12:24
Turkey Baste Her? |
Posted on: 2009/3/15 12:27
I set the tooltray from my toolbox into the front end, fits perfectly in front of the airfilter. Then I toss a towel over each front tire and go to work. I can now reach my tools and screws from both sides of the engine bay, and also have a comfy place to sit.
Posted on: 2009/3/15 14:49
