244 user(s) are online (199 user(s) are browsing Forums)
Also known as SMC.
The only issu...
BillH Today's Shop Tip
When you're working on your car and have bolts, nuts, clips, etc. from different areas laying everywhere. A neat way to separate them and make your reinstall easier is to use a 6 or 12 hole muffin pan.
You can even note on the pan where the screws came from with a Sharpie and remove the Sharpie with brake clean when done.
I've been using one for a long time for stuff that will get put back together quickly. i use baggies for the longet term stuff.
Posted on: 2009/3/14 15:33
psycovette Re: Today's Shop Tip
Spokane, Wa
57 Posts
THanks for the great tip now if you want to make that even bette place a magnet on the bottemand the whole pan will be magnatized.
Posted on: 2009/3/14 16:35
Spend money I don't have, on things I don't need, to impress people I don't know.
Anyone can restore em...it's takes a real man to cut one up
Matatk Re: Today's Shop Tip
Never thought of that - good tip. I like to draw the part on a piece of cardboard and poke the bolts through it. Keeps them from falling out and losing them, too.
I like the magnet idea, psy.
Posted on: 2009/3/14 20:31
CentralCoaster Re: Today's Shop Tip
I did the cardboard trick a few times when I was new to working on the vette!
An old speaker magnet works great for keeping bolts and screws from disappearing.
Posted on: 2009/3/14 21:47
TommyT-Bone Re: Today's Shop Tip
33790 Posts
How do the muffins taste next time the wife uses the pan?
Posted on: 2009/3/14 22:20
Jeffvette Re: Today's Shop Tip
You shouldn't be talking about her muffin.
Posted on: 2009/3/14 22:40
pianoguy Re: Today's Shop Tip
Probably better than the turkey's gonna taste after I used the baster to suck out my old power steering fluid.
Posted on: 2009/3/14 22:55
Turkey tasted a little funny after I used the baster to suck out my old brake fluid, but damn that bird could stop on a dime!
Posted on: 2009/3/14 23:07
itlgo2 Re: Today's Shop Tip
Missouri
288 Posts
did someone mention, muffin?
Posted on: 2009/3/15 1:54
BrianCunningham Re: Today's Shop Tip
My thoughts too
Posted on: 2009/3/15 2:29
BillH Re: Today's Shop Tip
I've done that with the speaker magnet that CC mentioned.
I also have a couple of Harbor Ft. magnetic parts dishes, got them on sale for $0.99.
Posted on: 2009/3/15 12:24
Turkey Baste Her?
Posted on: 2009/3/15 12:27
I set the tooltray from my toolbox into the front end, fits perfectly in front of the airfilter. Then I toss a towel over each front tire and go to work. I can now reach my tools and screws from both sides of the engine bay, and also have a comfy place to sit.
Posted on: 2009/3/15 14:49
