pianoguy | Big block | ||
About 109,000 HP
Posted on: 2009/3/29 23:58
bogus | Re: Big block | ||
I dare you to fit that in a Corvette... well, at least a CAR Corvette.
Even then, the class of warship called corvette is much too small for that monster. Who makes that? Wartsila? |
Posted on: 2009/3/30 0:21
TommyT-Bone | Re: Big block | ||
That'll make one hell of a dragster. I wonder who made the heads.
Posted on: 2009/3/30 0:27
AFR.
Posted on: 2009/3/30 1:05
Matatk | Re: Big block | ||
Holy bejesus that's a big engine. Wonder if they're leaving any power on the table?
Matthew |
Posted on: 2009/3/30 1:21
Dude, they only spin at 900 RPM... how much power is there to lose?
Posted on: 2009/3/30 2:37
Sweet90 | Re: Big block | ||
Really does give a new meaning to the word "Big Block"
Jim |
Posted on: 2009/3/30 2:41
Dads90 | Re: Big block | ||
I bet it gets about 22 mile per gallon !!! At least thats what it will say on the sticker.
Posted on: 2009/3/30 3:02
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
Calm | Re: Big block | ||
22 with a Tremac.....ZF behind it probably 25-26.
Posted on: 2009/3/30 5:24
BillH | Re: Big block | ||
When I was an engineer for Ingersoll-Rand, I visited a plant in Sherbrook,Canada. They made a 16 cyl, diesel powered natural gas pump about that size. It has 4 1/2 ft. dia. pistons. The rpm readline was 64.
Posted on: 2009/3/30 13:06
BrianCunningham | Re: Big block | ||
So, we going to start a 100,000hp club?
Posted on: 2009/3/30 13:32
Me in front of a 400 ton truck at Syncrude
This is just a lowly 3,600 hp though. |
Posted on: 2009/3/30 14:39
400hp427vette | Re: Big block | ||
Wow now thats power
Posted on: 2009/3/31 2:40
cool |
Posted on: 2009/3/31 16:08
mikeV | Re: Big block | ||
Oh no you didn't |
Posted on: 2009/3/31 23:23
My understanding is there was several hundred pounds of left over material after the rebuild. (2 lock washers and a 2 ft. bolt)
Posted on: 2009/4/1 1:52
captmike13 | Re: Big block | ||
wonder how much torque that bad boy has.
Posted on: 2009/4/1 3:17
