148 user(s) are online (100 user(s) are browsing Forums)
jhammons01 Lazy Man tip (Battery removal)
That pesky side panel has to come off when you need to change the battery.
It's pretty much straight forward until you come to that last 10mm screw that is located under the Rocker panel.
Once you get it out, and before you button it back up again, get your trusty Dremmel out and make an oval into a slot for reassembly and future battery issues.
Once you do this, you can then slip a 10mm into the thin open area between the rocker and panel and just loosen that 10mm screw enough to slide the panel out...this makes it so you don't have to remove the screw all the way. A real time saver.
Pictures 1, 2, an three are of the hole that is now a slot....
Pictures 4 and 5 are reassembly with a nifty slot
jpg  Lazy Man tip 001.jpg (105.59 KB)
798_4a4d54a14c927.jpg 640X427 px
jpg  Lazy Man tip 002.jpg (98.78 KB)
798_4a4d54b346759.jpg 640X427 px
jpg  Lazy Man tip 003.jpg (90.22 KB)
798_4a4d54c486a66.jpg 640X427 px
jpg  Lazy Man tip 005.jpg (97.51 KB)
798_4a4d54d664373.jpg 640X427 px
jpg  Lazy Man tip 004.jpg (117.11 KB)
798_4a4d54e52c809.jpg 640X427 px
Posted on: 2009/7/3 0:46
Matatk Re: Lazy Man tip (Battery removal)
Good tip! As often as some guys change their batteries....
Posted on: 2009/7/3 0:48
BillH Re: Lazy Man tip (Battery removal)
On a 92, that's been done at the factory.
Posted on: 2009/7/3 1:09
1Fast04Vert Re: Lazy Man tip (Battery removal)
Same for the 95.
Posted on: 2009/7/3 1:46
Jeffvette Re: Lazy Man tip (Battery removal)
Like that on my 90 as well.
Posted on: 2009/7/3 4:38
rayquayle Re: Lazy Man tip (Battery removal)
139 Posts
And my '86. I wonder when this change went into production. I'm the original owner of my '86, so I know mine came that way from Bowling Green.
Posted on: 2009/7/3 8:55
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
jhammons01 Re: Lazy Man tip (Battery removal)
LOL.....this is going to be one of those "early '84" issues.....that only the misfir....er...Crossfire guys has to deal with...
Posted on: 2009/7/3 15:29
bogus Re: Lazy Man tip (Battery removal)
I was thinking the same thing... both bastets 87 and my 92 are slotted.
Call it great minds thinking alike...
Posted on: 2009/7/3 16:07
Josh Re: Lazy Man tip (Battery removal)
91 is slotted as well.
Posted on: 2009/7/4 16:21
CentralCoaster Re: Lazy Man tip (Battery removal)
My 85 was just a hole.
So I turned it into a slot also.
Posted on: 2009/7/7 0:38
86PACER Re: Lazy Man tip (Battery removal)
41 Posts
This mod came already done from the factory starting in '86.
Which means my super lazy azz did not even have to lift a finger.
Posted on: 2009/7/7 10:26
xccter Re: Lazy Man tip (Battery removal)
Downtown Annapolis, MD
461 Posts
I have a wrench for removing that panel that I modified on the grinder to make it thinner so it'll fit easily between the rocker and access panel.
Posted on: 2009/7/7 13:28
ยด71 350/270 L48 Coupe
NCRS #48337
I wonder if there was another factory change somewhere along the line. On a 92, there's tons of clearence for a standard wrench.
Posted on: 2009/7/7 14:30
^^On the older models, you have to take out the two screws in the wheel well and at least two from underneath the rocker panel in order to pull the rocker down far enough to get a wrench in there.
The last of my pictures shows the rocker being flexed downward
Posted on: 2009/7/7 16:16
Good to know.
At least it's only 2 screws for you guys.
Posted on: 2009/7/7 16:31
I have some mini wrenches that came in a bag in my big craftsman set. Work good for fitting in that tight space, a standard wrench is too thick.
You can actually remove the battery without pulling the whole panel off, but it flexes a lot and is tricker than necessary. Just make sure you line it back up so the door doesn't chip the paint when you open it.
Posted on: 2009/7/7 17:28
I still like this thread
Posted on: 2012/3/30 15:41
As you should. It helps the last three 1984 and 1985 Corvette owners quickly swap their battery.
Posted on: 2012/3/30 16:48
CorvetteArchives Re: Lazy Man tip (Battery removal)
65 Posts
I took one from my kid's cheapo tool set...they were thin enough to work perfectly!
PS I dont like the title "Lazy Man"...it shopuld be smart man tip..... always "work smarter not harder!":-)
Posted on: 2012/4/2 2:56
