220 user(s) are online (182 user(s) are browsing Forums)
captmike13 Battery replacement. Need help. Emergency. Wife is almost stranded.
Hillsboro Mo
2166 Posts
Hi guys. I have slight emergency. Battery is bad in the vette. It is her DD. Wife needs help. I'm in Indiana and of no help to her. She needs to know how to get the panel off so that the battery can be changed. Please any help will be appreciated.
She would need a step by step of which screws to remove and where they are. We would really appreciate the help.
Mike and Ellen.
Pictures would be nice.
Posted on: 2010/1/13 3:18
13 GMC 3500 dually
captmike13@yahoo.com
TommyT-Bone Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
33798 Posts
It's a minor pain. There is a bolt on the bottom of the panel.A bolt by the door hinge on the top rear and all the torx screws that line the exterior wheel well on the panel side. You can see the bolt in the bottom center of the panel but I usually do this lying on the ground.
Posted on: 2010/1/13 3:35
33798 Posts
The battery is also held in place by a little wedge. You need an extension to get to it.
Posted on: 2010/1/13 3:37
captmike13 Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Hillsboro Mo
2166 Posts
Sears didn't know anything about it. Bought the battery and they almost broke the panel.
13 GMC 3500 dually
33798 Posts
That's because the moron isn't using common sense. It's kind of obvious.
Posted on: 2010/1/13 3:38
Hillsboro Mo
2166 Posts
My manual is home too. But we all know how easy that is to read. The battery is starting to not hold a charge. I think I'm gonna have her put a charger on it tonight. If it starts after work tomorrow she can drive it to our mechanic and have it changed.
Posted on: 2010/1/13 3:40
13 GMC 3500 dually
33798 Posts
Although the first time I tried to do it I thought I had to go from the top. Finally figured it out.
1Fast04Vert Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Did they get it installed OK?
Posted on: 2010/1/13 3:41
Hillsboro Mo
2166 Posts
No battery is not installed. Took car home.
Posted on: 2010/1/13 3:45
13 GMC 3500 dually
33798 Posts
Let me put in a plug for auto clubs here. They are worth there weight in gold for a breakdown. Matter of fact AAA has a battery service. They bring out the right battery and install it.
CentralCoaster Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Based on my 85...
She needs a 10mm open end wrench to loosen the hidden lower bolt shown in the photo, it's about 2/3 of the way towards the back of the battery panel. It screws upward, so to unscrew she has to turn the wrench towards the front of the car. Just loosen it, don't remove.
Then theres's a 10mm bolt on top near the door hinge, sometimes hidden by the rubber piece that seals to the hood. A nut driver or a socket on a ratchet work here.
There are a few torx screws going in from the fender liner. These can usually be removed with a small hex bit, or if she needs more room she'll have to turn the key on and turn steering wheel to the left. These screws use a T-30 bit. A T-27 or T-25 or even a 5/32" should also work, or even a flat blade screwdriver of the perfect size.
And lastly there's the battery hold down bolt. I think this is just a 10mm hex and is between the battery and the firewall down by the base of the battery. Remove that. I'm not 100% sure it's 10mm, I lost that bolt a long time ago.
With all that loose, tug on the panel evenly to get it loose.
And the battery terminals can be undone with an 8mm or 5/16" wrench or ratchet/socket. Remove the negative terminal first.
jpg  fanover3.jpg (19.33 KB)
793_4b4d3f8a72508.jpg 297X379 px
Posted on: 2010/1/13 3:46
33798 Posts
CentralCoaster wrote:
Based on my 85...
Thanks for the technical follow up CC.
Posted on: 2010/1/13 3:49
Hillsboro Mo
2166 Posts
Thanks CC. I think the wife will tackle this tomorrow.
Posted on: 2010/1/13 3:51
13 GMC 3500 dually
Lol, when I started writing that, there were no posts yet. I even got my torx bits out to check!
And for posterity, on 84 and 85 vettes only, the lower bolt goes into a hole, not a slot. So when you loosen it, the panel doesn't come out all the way. You pull the top out and bend it downwards, and there's enough room to fish the battery out.
If you ever do have the panel out though, turn that damn hole into a slot.
Posted on: 2010/1/13 3:52
Hillsboro Mo
2166 Posts
Thanks guys. I really appreciate this.
Posted on: 2010/1/13 4:01
13 GMC 3500 dually
flyboy Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
I think the bottom bolt is 10mm.
jpg  upper anchor point.JPG (855.14 KB)
1735_4b4d453f259a9.jpg 2272X1704 px
jpg  lower slotted anchor point.JPG (842.86 KB)
1735_4b4d45774113e.jpg 2272X1704 px
jpg  front at wheelhouse.JPG (838.44 KB)
1735_4b4d45a8a39c1.jpg 2272X1704 px
jpg  one bolt at bottom.JPG (839.61 KB)
1735_4b4d45ec9c262.jpg 2272X1704 px
Posted on: 2010/1/13 4:03
Brite1 Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
2 Posts
Thanks Everyone for your help!!!!!!!!!!
Posted on: 2010/1/13 4:09
Hillsboro Mo
2166 Posts
Brite1 is My wife. Give her a warm welcome
Posted on: 2010/1/13 4:12
13 GMC 3500 dually
2 Posts
<<<<<<<< Mike's Wife ;)
pianoguy Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Welcome, Brite1! Best of luck with the battery - it's kind of a pain, but not all that bad.
Posted on: 2010/1/13 13:33
BillH Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Yep. But Mike's pannel is a bit different, it won't have the slot, just a hole and the bolt has to come out. I think it's only 85 & 86 with the hole. Most guys make that a slot when they first pull the panel.
Posted on: 2010/1/13 15:07
bogus Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Fun, eh?
the only car where changing the battery takes 22 posts!!!!
Read CC's post, that's got what you need.
Posted on: 2010/1/13 15:31
jhammons01 Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
Posted on: 2010/1/13 15:50
BrianCunningham Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
One of the reasons I'm relocating mine.
Going to put my dry sump tank there instead.
So is she all set?
Posted on: 2010/1/13 16:01
Hillsboro Mo
2166 Posts
From what I have been able to gather, it's the 84 and 85 that have the hole and not the slot. Could be later models too.
Posted on: 2010/1/13 16:14
13 GMC 3500 dually
Probably is Mike, I should have added IIRC. :toothy3:
Posted on: 2010/1/13 16:21
Hillsboro Mo
2166 Posts
Either way when she gets it off we will have a slot put in.
Posted on: 2010/1/13 16:23
13 GMC 3500 dually
She can put the slot in.....use fingernail filing tools.
Was that sexist?
What I am saying is, it is very soft material and any file can take it off very easily......then shape it correctly like you would a fake nail.
I used my dremmel and that took all of 17 seconds.....a bit over kill
Posted on: 2010/1/13 17:56
Jeffvette Re: Battery replacement. Need help. Emergency. Wife is almost stranded.
If it hasn't been done yet. Get a hold of me.
Posted on: 2010/1/13 20:05
Hillsboro Mo
2166 Posts
No not done yet Jeff. I'll have her check here when she gets off work.
Posted on: 2010/1/13 23:00
13 GMC 3500 dually
The bolt does not have to come out to remove the battery. She only has to loosen it and hinge the panel down.
Ideally, yeah, remove the bolt and make it a slot, but that takes more work. I think I removed mine when I had the rocker panel off. Can you even get the bolt out otherwise?
Posted on: 2010/1/14 1:52
Hillsboro Mo
2166 Posts
(15:07)Brite1: Good Afternoon CGs! Wanted to say thank you to everyone for the assistance in changing my battery. Mission Accomplished !
Posted on: 2010/1/14 21:17
13 GMC 3500 dually
Cool! Now let's walk you through a clutch swap next.
Posted on: 2010/1/15 5:54
