259 user(s) are online (206 user(s) are browsing Forums)
BrianCunningham Joined the snapped shock bolt club today
should of put a torch to it the second it started singing.
at least that worked on the height adjusters.
managed to snap it off with just a little piece showing.
already tried a torch and some vice grips
anyone know a good way of getting it out w/o screwing up the welded nut on the frame?
and things were going so good too..
Photobucket
Posted on: 2010/4/30 23:56
bogus Re: Joined the snapped shock bolt club today
I guess you are referring to the bolts that hold the shock mount into the frame?
Well... I would soak it with PB blaster.
Posted on: 2010/5/1 2:51
pianoguy Re: Joined the snapped shock bolt club today
I would guess you'd either have to weld a nut onto the stub or use an E-Z-Out. Sounds like fun
Posted on: 2010/5/1 3:07
BrianCunningham Re: Joined the snapped shock bolt club today
Yes,the ones into the frame, late c4
I picked up an easy out set today
Hopefully that and a torch will get the job done
Looks like I'll have to get a tap set as well
Posted on: 2010/5/1 19:33
There is another option... it's this thing where a guy with a plasma cutter eats the bolt out, leaving the nut behind.
very common in boating and very effective in general.
Posted on: 2010/5/3 3:09
Aboatguy Re: Joined the snapped shock bolt club today
My Avatar was redistributed!
498 Posts
Brian
Did you get that sucker out yet?
I've had decent luck with reverse rotation drills...I like the fact that I'm not tightening the bolt during my efforts to remove it.
MIke
Posted on: 2010/5/8 20:16
my computer to a dump
so I've been spend all my time rebuilding it
Posted on: 2010/5/9 15:12
bummer.
Posted on: 2010/5/9 18:11
well tried out the bolt extractor
it actually snapped off inside the bolt
fortunately I managed to get it out
now I'm left with a pilot hole
I'm thinking of drilling it out with progressively larger bits, then taking a cold chisel to it
thoughts??
Posted on: 2010/5/11 21:30
CentralCoaster Re: Joined the snapped shock bolt club today
If you can drill it more, you can use a larger extractor. I don't think it'd be possible to get whats left of it out any other way. A chisel will just jam all the metal further into the hole.
Posted on: 2010/5/11 22:03
1Fast04Vert Re: Joined the snapped shock bolt club today
Use a left handed drill bit. First spray it with some BP blaster, then take a punch and whack it real good just to try to loosen the threads up.
Posted on: 2010/5/11 22:26
rklessdriver Re: Joined the snapped shock bolt club today
Eveny once in a while I would get something at the shop that had a broken bolt in it that just wouldn't come out with an easy out or left handed drill. The way I would fix them is to progressivly drill the pilot hole in the broken bolt bigger and bigger until I was at the "Tap Size" (drill bit). If you dion't have a drill/tap size chart, the threads will just about (or barley) show.
Then I would start the tap and re-cut the threads. What was left of the bolt would get cut out with the tap as long as your centered pretty close on the broken bolt (Easy to do on a vertical mill. NOT so easy laying on your back under a rear fender...).
If your off of center too far to fix it that way just tap it to the next size bolt or heli-coil it if it's important the bolt be the same size.
I think the next size up is too big
I can try it though
Photobucket
Photobucket
Posted on: 2010/5/11 22:28
jaa1992 Re: Joined the snapped shock bolt club today
Stone Mtn, GA (near Atlanta)
187 Posts
thoughts??
Had the same problem - by the time I got to a drill bit that was 3/4 the diameter of the bolt the remainder came out without having to use a chisel.
Took a tap to clean the threads.
Posted on: 2010/5/11 23:54
Matatk Re: Joined the snapped shock bolt club today
22808 Posts
I've done that but it looks like you're a bit off center with the pilot hole. Or perhaps the picture is deceiving. The larger drill bits will follow what's there and you run the risk of drilling into the car itself.
Any chance you can weld it?
Posted on: 2010/5/12 2:13
VtVette Re: Joined the snapped shock bolt club today
Las Vegas, NV
357 Posts
and another idea if it all goes to hell: Weld Nuts
http://www.mcmaster.com/#weld-nuts/=71tcx4
Just drill out the original bolt/nut, insert this into the hole and weld it in place.
Posted on: 2010/5/12 2:28
Brian
VTvette
rklessdriver wrote:...
or have trouble getting the drill in there.
it's definitely off a little off center
BTW it's either a welded on or captured nut inside the frame
Posted on: 2010/5/12 2:34
Picked up a metric tap set when I bought the longer snake today for my sink drain issues.
EDIT
Those bolts are 8x1.25 BTW not 1.0 or 1.5
put in correct size, oops
sales guy said one thing, but sold me the right one.
either that or my morning coffee ran out
Posted on: 2010/5/17 23:55
After going through a few bits, I got the bolt through drilled today
I'm not into the nut as of yet
I need to disconnect the abs connectors to get the drill at a better angle.
I got it hollowed out pretty good, so I tried collapsing it with a chisel.
didn't work, but I got all the frays off, so it's better set for taping
Posted on: 2010/5/18 22:13
tried getting a tap extension today
I can't get the t-handle in there
all the ones I found were for a 7mm or smaller tap
a square drive would work
Posted on: 2010/5/20 0:51
a friend lent me a tap handle with a sliding handle
it's working
taking it easy so I don't break the tap
got it about 1/2 done
I'll finish it tomorrow.
some of the bolt's still in there.
I'm hoping at this stage that it's friction welded in.
Posted on: 2010/5/20 23:46
finished it up today
put a bolt in there just to make sure
of course the real test will be when I torque everything down.
Posted on: 2010/5/21 21:18
Glad to hear you got it done, or at least all of the hard part.
Posted on: 2010/5/21 23:07
22808 Posts
Did you end up tapping it oversized or could you salvage the original threads?
Posted on: 2010/5/22 2:09
498 Posts
Congrats, however ,like Matak I'm interested in if you were able to save the threads, used a helicoil, nutsert, or larger bolt....
Posted on: 2010/5/22 13:02
tapped to the original size
but it's offset a little
there's some of the original bolt still in there
what's left if friction welded it.
I'll see if it will hold
if not, I'll oversize it, and and either put an oversized bolt or helicoil in it.
Posted on: 2010/5/23 20:57
TommyT-Bone Re: Joined the snapped shock bolt club today
33790 Posts
So is the rubber gonna hit the road for Memorial Day weekend?
Posted on: 2010/5/25 21:24
498 Posts
What he said!
Are you on the ROAD YET????
Posted on: 2010/5/26 2:25
pappyfreebird Re: Joined the snapped shock bolt club today
1028 Posts
boy n ol trick ive used many times is wud i call pencil sharpin a hard bolt n weld her to the stub...the heat along wid the new head cranks em right out..ifn nawt then i do the lil biggar till tell she pops er i have to tap new ...great ya got her out..ive got a spendee set of the new reversd bit n taps,,but ain tried em yet
Posted on: 2010/5/26 11:42
still working on clearance issues
Posted on: 2010/5/26 12:53
Steve40th Re: Joined the snapped shock bolt club today
1114 Posts
One thing I learned on a very difficult bolt was using a left hand drill. After nothing succeeded, I welded a rod with a nut and just unscrewed it.
Posted on: 2010/5/27 3:45
Ko'u ohana aia ku'a ikaika
