313 user(s) are online (261 user(s) are browsing Forums)
-=Jeff=- New C4 Frame Braces
Bartlett, IL
573 Posts
I might have your answer..
Currently on my Car are a set of frame brace to help give the C4 a solid frame feel like the C5. These will bolt in any post-86 (uses front X brace bolt points), no drilling required, although there might be an extra hole in the brace that would require one hole to be drilled but would be optional. These braces can be left on while removing exhaust ETC, it is not a cross brace of any type.. The Brace was designed by Gordon Killebrew..
These braces are NOT lower then my exhaust. they are similar to F-body Sub frame connectors (in mounting) and are not X-Braces
So far I have driven 100 miles with the top on but the car is definitely more solid then it was prior.
Need to drive with the top off to see how well it is
in the picture below the car is dirty from rain..
you can see the head of one bolt here on the left and the rod (in black) running length of car..
[IMG]http://lh3.ggpht.com/_N1g6599TmMo/TBV-BP2dRuI/AAAAAAAAA1U/T7yuLXFoD5c/s720/DSC_0064.JPG[/IMG]
few more of the one side..
[IMG]http://lh3.ggpht.com/_N1g6599TmMo/TBV-B_uOY4I/AAAAAAAAA1U/z95B1_8VVVM/s720/DSC_0065.JPG[/IMG]
[IMG]http://lh6.ggpht.com/_N1g6599TmMo/TBV-DOUAI7I/AAAAAAAAA1U/dUizxP_gQes/s720/DSC_0066.JPG[/IMG]
[IMG]http://lh6.ggpht.com/_N1g6599TmMo/TBV-EaST9iI/AAAAAAAAA1U/-IKzQtkBtDg/s720/DSC_0067.JPG[/IMG]
REAR Mount:
[IMG]http://lh5.ggpht.com/_N1g6599TmMo/TBWUP3_QCDI/AAAAAAAAA10/ansLo3j_0Qg/s512/DSC_0001.JPG[/IMG]
[IMG]http://lh4.ggpht.com/_N1g6599TmMo/TBWUQ0HTukI/AAAAAAAAA14/rswBfD4fXBs/s512/DSC_0002.JPG[/IMG]
[IMG]http://lh5.ggpht.com/_N1g6599TmMo/TBWUSLb_6TI/AAAAAAAAA18/8CPhZoRDO6A/s720/DSC_0003.JPG[/IMG]
Front Mount:
[IMG]http://lh3.ggpht.com/_N1g6599TmMo/TBWUSmObFoI/AAAAAAAAA2A/jUe0r8Y-eqY/s720/DSC_0004.JPG[/IMG]
These are being made by Vette2vette. not sure on ETA for final production as these I have are Prototypes
Posted on: 2010/6/14 12:27
-=Jeff=-
1990 Corvette ZR-1 #1051
pianoguy Re: new C4 Frame braces
Interesting!
Posted on: 2010/6/14 12:53
383tpimachine Re: new C4 Frame braces
Corpus Christi
976 Posts
none for 85
Posted on: 2010/6/14 13:11
1970 El Camino-Awaiting LSX
-=Jeff=- Re: new C4 Frame braces
Bartlett, IL
573 Posts
383tpimachine wrote:
none for 85
it would work but you have to drill and use Nutserts for your 85. and would need to get a template for the holes from a later car so they are in the correct spots
Posted on: 2010/6/14 13:17
-=Jeff=-
Corpus Christi
976 Posts
none for 85
So the only difference between 85 and 86+is a few extra holes drilled?
I can do that.
When is v2v going to publish these? or are they already on the market?
Posted on: 2010/6/14 13:37
BrianCunningham Re: new C4 Frame braces
any pics off the car?
Posted on: 2010/6/14 15:01
Bartlett, IL
573 Posts
Nope I don't have those. vette2vette might
V2V wants to be sure they work as they should. I was told they will be at Bloomington showing them.
but most questions for when avail etc, should be sent to them.
My job is to provide feedback to them and the community on how they work
So far as said, with roof on I felt a difference but weather here is not cooperating for top off driving
Posted on: 2010/6/14 15:05
-=Jeff=-
SpectatorRacing Re: new C4 Frame braces
Hmmm...
It's not the bottom of a C4 that needs the help. I had a much beefier brace on my car when I first bought it, it was a box section and welded to the front and rear subframe (see below). It sill shimmied and shook with the top off. Nothing short of a 6-pt is going to really fix this, and obviously that's not going to happen on a street car.
You're better off with one of these braces that goes in place of the roof IMO. I think RD makes them?
jpg  Motor Swap 009.jpg (0.00 KB)
Posted on: 2010/6/14 15:13
Jeffvette Re: new C4 Frame braces
SpectatorRacing wrote:
Hmmm...
That's what I was thinking when I first saw it. C4 frame flexes or twists in the middle and it's mainly a lateral issue. A solid rod connected at the ends with heim joints is still going to allow the frame to twist.
Iteresting design though.
Posted on: 2010/6/14 21:57
SpectatorRacing Re: New C4 Frame Braces
Why do you need the adjustable ends on a frame brace? Shouldn't it be a fixed end?
Just curious. Seems like an unecessary expense.
Posted on: 2010/6/15 15:04
-=Jeff=- Re: New C4 Frame Braces
Bartlett, IL
573 Posts
probably because no C4 frames are perfect?
Posted on: 2010/6/15 15:29
-=Jeff=-
BillH Re: new C4 Frame braces
Nothing short of a 6-pt is going to really fix this, ?
Tubeframe.
Posted on: 2010/6/15 16:49
Now THAT I believe!
Posted on: 2010/6/15 20:32
Weavsvet Re: New C4 Frame Braces
446 Posts
What about the jacking points? Do these interfere with them?
Posted on: 2010/6/15 20:40
Bartlett, IL
573 Posts
Don't know yet.. I am planning on driving the car to my club meeting tonight (if nice weather top will be off)
I will look at it more on the weekend
Posted on: 2010/6/15 20:45
-=Jeff=-
corvetteronw Re: New C4 Frame Braces
Lowell, MI
Jason will be installing this on my 91 coupe at Bloomington Gold. I will take pics and submit an article to Corvette Enthusiast too.
I will be there from Friday noon till about noon Sunday if anyone is in the area.
I have no financial interest in this other than a price break on the install.
Posted on: 2010/6/16 4:15
CentralCoaster Re: New C4 Frame Braces
I don't really see the point.
Posted on: 2010/6/17 3:26
Lowell, MI
Gordon said he offered this solution to the C4 engineers as a fix to the C4's chassis problems during the C4s run at the plant. He said they turned him down due to the extra costs (if my memory serves me correctly).
Posted on: 2010/6/17 4:10
bogus Re: New C4 Frame Braces
Now THAT I believe!
Why do you think GM pioneered the concept of the oval hole... really helps out when the rest of the car is made to the same level of precision.
Posted on: 2010/6/17 6:10
not suprising... anything to save $10.00. And I doubt the engineers turned him down. I am betting it was the Wharton grad who knows jack shit about racing or performance cars.
Posted on: 2010/6/17 6:11
Jakers Re: New C4 Frame Braces
Georgia
14 Posts
A big huge AMEN to that one!!!! He is also the "practical" guy that drives a mini-van!
Posted on: 2010/6/17 22:56
1994 Coupe. Too many Mods. Can't stop throwing good money after bad. Just another C4 owner.
yea, he went cwazy when he ordered said mini-van with alloy wheels...
oh, so how much for this thing?
Posted on: 2010/6/18 4:38
Bartlett, IL
573 Posts
Best to check with Jason, for pricing
Posted on: 2010/6/18 14:43
-=Jeff=-
BrianCunningham Re: New C4 Frame Braces
You know me, I like to buy parts
But I'd need to see some pics of it off the car to see what it's actually doing.
Posted on: 2010/6/18 14:46
Bartlett, IL
573 Posts
Posted on: 2010/6/26 22:20
-=Jeff=-
that seems seriously expensive.
Posted on: 2010/6/27 4:46
RickAnthony Re: New C4 Frame Braces
ASE Master Certified
Downers Grove, IL
703 Posts
Agree....I was thinking this was probably around 2-300$
-=Rick
Posted on: 2010/6/27 5:28
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
Matatk Re: New C4 Frame Braces
I talked to Jason about the pricing yesterday. There is a lot of machining costs involved in these, plus they are a brand new product. If you noticed the heim rod ends on there, those are at least $25 a piece and there are four of them. So it adds up quick! I figure if these become popular, the price will come down considerably.
Posted on: 2010/6/27 11:33
Bartlett, IL
573 Posts
Nice to finally meet you Matt!!!
Yes the Heims are a big cost.. but so far I feel these are a great product
Posted on: 2010/6/27 13:37
-=Jeff=-
astock165 Re: New C4 Frame Braces
Manchester NH
199 Posts
Never mind. Saw the pics from the other thread and that answered my questions.
Posted on: 2010/6/27 21:55
Banski MotorSports LLC
Manchester NH
tom@banskimotorsports.com
www.banskimotorsports.com
Bartlett, IL
573 Posts
UPDATE
I talked to Jason today.. the deal has changed and been extended until after Carlisle.. everyone that has called and shown interest will get this deal as well
Introductory price of $550 SHIPPED!!!
I will get my website updated within the next couple of days
Posted on: 2010/7/22 19:44
-=Jeff=-
Still waiting to hear your test results and driving opinion.
Posted on: 2010/7/22 22:13
Bartlett, IL
573 Posts
oh,
I guess I did not update here.. According to Gordon, you may need to tweak it a bit, I have adjusted it twice and each time it has gotten better, I think I need to tweak the driver side a bit more now, but I need to drive it a bit more to be sure. otherwise they do work, there is one set of tracks I could crossover at more the 15mph, I can take them at 30 with no issues with NO other changes to the car.
so far I am impressed and happy I have them
Posted on: 2010/7/22 22:18
-=Jeff=-
Lowell, MI
I installed these on my 91 coupe at home and tightened them down pretty tight.
I can only say that it feels like I am driving a new car right off the showroom floor instead of something with 111,000 miles on it. And that is with the targa top off.
The double set of railroad tracks that I cross to and from work each day are done at the 30mph speed limit instead of 10mph. No rattles!
I can drive my favorite twisty road faster than I ever did. In fact I cannot drive as fast as the car will let me due to my fear of hitting a farm wagon coming out the other end of a tight curve. Once again - with the targa off.
The cost of this product to improve your ride and handling is much less than selling your C4 and buying a C5. The tubes REALLY tightened this old FX3, A4 stocker with performance axle up!!!!!
Posted on: 2010/7/23 0:52
pianoguy Re: New C4 Frame Braces
It does sound intriguing, will have to keep chewing on it a bit (I already have an R-D Cross-Frame).
Posted on: 2010/7/23 2:03
Lowell, MI
Pics:
I just jacked up my 91 in order to drain the coolant so I could do my intake upgrade. I used the normal jacking point for my floor jack with no problems.
I also measured at time of install and the rods were the same distance from the garage floor at their lowest point as the lowest point of my stock exhaust.
These REALLY make the car a pleasure to drive with the top off. Tight, tight, tight!
Posted on: 2010/7/23 4:33
