213 user(s) are online (143 user(s) are browsing Forums)
The ...
bogus I am off to do the heater core...
wish me luck!!!
Posted on: 2007/12/30 21:07
brut RE:I am off to do the heater core...
New Albany, IN
1308 Posts
damn sux to be you.
Notorious RE:I am off to do the heater core...
To show my support, the next beer's for you!
Posted on: 2007/12/30 21:12
I hate sporks...
vis_croceus Re: I am off to do the heater core...
VA
260 Posts
Piece of cake.
As long as you already have the entire dash out.
Posted on: 2007/12/30 23:31
New Albany, IN
1308 Posts
ewwww....
Posted on: 2007/12/30 23:32
teebee RE:I am off to do the heater core...
12373 Posts
Make sure you take pictures along the way, submit it for inclusion as a Tech article! :thumbleft:
Posted on: 2007/12/31 1:39
Touringmike Re: I am off to do the heater core...
Sussex,Wi
569 Posts
wish me luck!!!
Now I know why the SO was posting.
She's going to fill in while your gone, right?
Posted on: 2007/12/31 1:59
ยด85 4+3
j3studio RE:I am off to do the heater core...
May the force be with you!
Posted on: 2007/12/31 2:05
kentucky_vetter RE:I am off to do the heater core...
somerset, ky
154 Posts
you have my sympathy !
Posted on: 2007/12/31 2:06
CA_Irregular RE:I am off to do the heater core...
Sacramento, CA
8 Posts
You didn't provide your plan so this may be premature. How is it going?
I did mine over a long weekend in bursts of activity. I was also able to use my younger, thinner son's help. The only advice that I would add, if you haven't reached the stage yet, is to check for leaks before installing. I used a thin inner tube and clamps to put about 15 lbs of pressure in the system and held the unit under water. I also verified that the method worked when I tested the old core that I replaced. One other thing, I used a photo of the cover provided by Agent86 and it really helped me find the upper, driver's side screw.
If yours is installed and not tested, I'm sure that it will be good. The odds are tremendously in your favor.
Posted on: 2007/12/31 16:06
LD85 RE:I am off to do the heater core...
Indianapolis, Indiana
784 Posts
Pull the dash top off, it's much easier that way
Posted on: 2007/12/31 18:34
2005/Z51
bogus RE:I am off to do the heater core...
I am actually testing the text provided by Jet-Jock. He did his a couple years ago, and I have edited about as much as I intend to on his text, but want to now apply it.
I need to get some extra pictures, so people can better see what is being talked about.
I am also doing a full interior resto, new carpets, insulation, etc.
Ok, back to it! I have a ton of things to do today... ugh...
Posted on: 2007/12/31 19:00
CasetheCorvetteman RE:I am off to do the heater core...
Its quite easy when the car is converted to right hand drive
Posted on: 2008/1/1 2:58
Cheater!
Posted on: 2008/1/1 3:50
One thing that will get ya though it everything has to go in upside down, which can also be an advantage, cause the blend door attachment is then on the bottom and easy to get to if need be!!
Ill get some pics up
Posted on: 2008/1/1 4:27
You may notice also that the heater core sitting up that way means that the coolant should be less likely to sit at the bottom and start eating it.
Posted on: 2008/1/1 4:33
movnviolation RE:I am off to do the heater core...
Hesperia, Calif
188 Posts
I would rather eat glass than do that again!
Posted on: 2008/1/2 8:32
Mate ill gladly do it again anytime if someone needs it done, not on my bloody car cause its a new core and i shouldnt have to do it!!
Posted on: 2008/1/2 8:58
NitroFish86 RE:I am off to do the heater core...
Clarksville TN
23 Posts
When I was pulling my dash apart to do a repair on the firewall I was wondering how the hell anyone was supposed to get in there to change that heater core. Major PITA-good luck with that.
Posted on: 2008/1/2 15:40
86 Black Coupe: Under destruction, future friday night street fighter
Strick RE:I am off to do the heater core...
Lake Wylie, SC
129 Posts
Hope you have lots of bandaides and beer.
Posted on: 2008/1/2 17:45
AILERON RE:I am off to do the heater core...
5 Posts
Have you finished the core change, Andy?
I used Lani's pdf and thought he did a great job, tho we did chat by phone a couple of times.
Mine went very well, between his instructions and the phone calls. PM me if you need to.
Best,
Bruce
Posted on: 2008/1/12 10:44
I am getting ready to get going on it again...
I have the dash pretty much out... I need to attack the last bits to reach the core itself.
Posted on: 2008/1/12 19:47
Are you still milking this project? Damn, I'd hate to pay you by the hour!
Posted on: 2008/1/12 22:16
I hate sporks...
Oh, that's gotta hurt ...
Posted on: 2008/1/12 22:24
[size=24:03ff7e5497] The Heater Core is OUT!!!!!!!!!!!!!!!!!!!!![/size:03ff7e5497]
what a bitch of a job THAT is...
Posted on: 2008/1/12 23:04
MyFatNutz RE:I am off to do the heater core...
7 Posts
WOW, I can't believe this seems like it's going to be worse than adjusting the windows. Is that pdf from Jet-Jock available for download anywhere or it's one of those email and send deals. I have quite a few servers to make an unlimited download of this if anyone wants to send to me.
Posted on: 2008/1/13 0:48
I am working with Jet-Jock's document.
The basic idea of Guru is to provide these types of documents to our members at no charge.
As soon as I add some (lots) of pictures, I will be posting it!
Check out the library here: Tech Library
The link is in the top menu bar, below the top graphic banner.
Posted on: 2008/1/13 1:07
7 Posts
Awesome, thx!
Posted on: 2008/1/13 1:33
95 Yellow FE1, Zf6 LT1-->LT4 Heads, CompCams 304, pro magnum RR; C5/Z06 calipers/brake conversion
I think I boned myself.
Last night, I plugged everything back together under the dash... and forgot two connectors. One is very large and and has many wires the other had 4 wires. I need to find my electrical manual to determing which is which.
However, I tried to start this morning and nothing... a SYS on the IP... I find the connections, well... not connected. I reattach and still SYS.
Tonite, I get home and start diags. The battery is quite low. I am wondering if the contacts are bad... but it's charging right now. I found one fuse, for the theft system, that looked questionable. I replaced it.
At this point, I am pulling for a bad battery... but expecting a dead CCM. I think I fried it. Damnit. I just don't know how.
the CCM is showing a C41 and H41 error. they mean the same thing - loss of serial data link.
Not good...
Yes, I am a moron.
Posted on: 2008/1/15 2:34
pianoguy RE:I am off to do the heater core...
Electrical mojo!
Posted on: 2008/1/15 2:43
SpectatorRacing RE:I am off to do the heater core...
I have the CCM from my '93, I can't remember if they're coded or if you could use it.
Let us know when you figure out what's cooked.
Posted on: 2008/1/15 2:48
thanks! I will keep you posted!!!
Posted on: 2008/1/15 3:22
Greg Heater Core
Corydon, IN
11 Posts
When I put my dash back together after replacing the heater core I got to sets of connectors switched. I think that there are only two that are possible to plug in to one another. You might check that.
Good Luck!
Posted on: 2008/1/15 3:44
ooh. I will check that. IF it's the two I am concerned about that could be it. Thanks for the pointer. I am gonna check it right now, infact.
I have disconnected the battery... I am getting a C41/H41 error plus ERR for both the engine controller and the EBCM.
Posted on: 2008/1/15 3:49
ok. Greg is the MAN!!!!!
Dude, you nailed it.
I had no clue GM could be so stupid to put two sets of identical connectors next to each other like that. It woulda taken me hours to figure this one out.
When I update Lani's document, I am gonna be 100% sure that detail is properly documented.
Posted on: 2008/1/15 4:57
Greg Heater core
Corydon, IN
11 Posts
I took me a while to figure it out. I did'nt think that was to bright on GMs part.
Posted on: 2008/1/15 5:57
I am gonna suggest that a shot of spray paint on each pair to make them unique... or a sharpie mark.
I don't care.
Posted on: 2008/1/15 6:24
Sharpie mark it is.
I just got in from reassembling the dash. I have the core in and the structure reassembled. The ducting is all working and the car actually starts... shocking.
The next step is getting the hoses reconnected and then we have heat!
Posted on: 2008/1/19 22:14
Steve40th RE:I am off to do the heater core...
1114 Posts
Cant wait to see photos and a write up. I havent needed mine in 8 years here in Hawaii, but, I will in three years, so getting started soon would be a good idea.
Also, replace the electric motor for electric AC/Heater controls. its a cheesy little motor in there.
Posted on: 2008/1/19 23:40
By me a ticket to fly out there and I'll get it done. This way we can move on to other things here.
Love ya', mean it! :toothy8: Yeah, I'm just trying to get a free vacation...........
Posted on: 2008/1/20 0:36
1114 Posts
Wouldnt want to ruin your vacation if ya came out here
Posted on: 2008/1/20 1:08
I have heat!!!!!!!!!!!!!!!
I have also figured out something... the heater core is a constant flow type. It adds some coolant to the system (no question) but is constantly runs coolant, which means there is a bit of heat loss in the heater at all times.
I am wondering if the car will now run cooler because it's back in.
Next up is the rest of the interior resto.
I added a number of pictures to Lani's write up... so that will help... and there will be even more of the disassembly.
Posted on: 2008/1/20 1:20
Vette_Gator RE:I am off to do the heater core...
1 Posts
Congrats! I just did this job yesterday on my 85 Camaro. I wouldn't wish it on my worst enemy. My hands and arms look like I was fighting with a cat.
Posted on: 2008/2/11 20:12
