227 user(s) are online (183 user(s) are browsing Forums)
Matatk Brake Rotors
22809 Posts
Anyone use the ATE PremiumOne Slotted Rotor from TireRack?
http://www.tirerack.com/brakes/brakes ... 2&autoModClar=&perfCode=S
I need a new set of rotors and it looks like a decent price. I've heard good things about powerslots, but they are $240 a set for the front. At $48 a piece for the ATEs, that's cheaper than stockers from Rockauto (18A946/18A947 - $51.79).
Comments?
Posted on: 2008/9/6 2:11
CentralCoaster Re: Brake Rotors
Other then them looking flowerly queer, seems fine. Why don't you just turn the stockers down a few thou?
Posted on: 2008/9/6 3:24
biggrizzly Re: Brake Rotors
They are probably just fine.
Interesting slot pattern. It is kind of "flowery"
Kind of reminds me of the Obama part in the Jib Jab video clip from this morning's funnies.
My first brake pad change on my C4 I had the rotors turned a bit and that worked fine for a good long while. Then around 135k miles on the odometer I did a complete brake upgrade to Grand Sport calipers and 13" rotors up front and new everything out back. My rotors came from an eBay vendor and have worked great for the 10k miles I put on them before taking the car off the road last year.
Posted on: 2008/9/6 3:58
Mekanic Re: Brake Rotors
Tampa Bay Florida
827 Posts
lol, good price, looked them up for my vette on there.
$77 each for the rear.
Nothing for the front lmao.
Posted on: 2008/9/6 6:55
~Rich
Polo LT4
Matatk Re: Brake Rotors
22809 Posts
They've (stock c5s) already got some miles on them (probably 20,000-25,000) and the right side is warped. $12 a rotor to turn at Carquest, so I'd rather just buy new than pay $24. It's cheap insurance, imho.
Posted on: 2008/9/6 12:56
Qack Re: Brake Rotors
274 Posts
Doesn't look flowery to me ... looks nuclear
Posted on: 2008/9/6 16:51
Warping is rare and usually misdiagnosed.
If they're pulsating it could very well be some uneven pad deposits, turning them will fix that.
A cheap rotor on the other hand will temporarily warp when hot, because of core shift, and depending on where the casting parting lines are, as it can heat up unevenly.
Posted on: 2008/9/6 18:30
22809 Posts
I agree to a point.
I put the rotors on and there were no problems. But now they scrape when I spin the wheel by hand and when I'm driving and squeal horribly when I stop with some light pulsation. I haven't taken them off to check for square, but that's my next step before I actually order new ones. Just doing some preliminary scoping.
Posted on: 2008/9/6 19:46
The squealing is from your pads. They could be glazed, or more likely you need to spray some of the blue permatex anti-squeal stuff on the back side of the shoes.
They're supposed to rub while turning by hand. The few feet of elevation of fluid between the caliper and master cylinder keeps some residual pressure on the pads. It's probably pad deposits, and if its uneven you'll hear it. When you assembled it before you probably retracted the pistons a bit so they didn't even contact the rotor.
I'm not trying to be a pain, but you may be looking at a $20 fix at most. That $100 could go towards mods, or a few steak dinners.
Posted on: 2008/9/6 22:47
22809 Posts
Thanks I'll pull them apart and check it out.
Posted on: 2008/9/6 23:31
Jeffvette Re: Brake Rotors
Matt, I can make you a smoking deal on some DBA 5000 2 piece rotors.
Posted on: 2008/9/9 19:24
BillH Re: Brake Rotors
Ain't that the truth. You hear it a lot.
You can check rotors for 8 bucks. $7.99 for a cheapass HF dial indicator, a bolt, C-clamp and jackstand is all you need.
And you usually won't find that they're warped out of spec.
Posted on: 2008/9/9 19:46
22809 Posts
LOL, thanks, but I don't want my brakes to be worth more than my car....
Posted on: 2008/9/9 22:19
Not even at two for the price of one? Tire rack lists them at 350 each, I can do both for 350.
Posted on: 2008/9/9 22:36
$350 for a pair of 2-pc rotor is hard to beat Matatk!
Posted on: 2008/9/9 22:47
22809 Posts
It is an outstanding price!
However, I can't justify that for my weekend toy..I don't race the car, and the stock c5 rotors have enough stopping power for me. If I had extra cash to spend or I were racing I'd be all over it. That is a seriously good offer Jeff.
Posted on: 2008/9/10 1:20
RickAnthony Re: Brake Rotors
ASE Master Certified
Downers Grove, IL
703 Posts
Matthew, these are the rotors I installed on Arun's Z06 he picked them out, along with a set of Hawk Pads, he hasn't had as good of luck with this combo as with stock Z06 pads and the stock rotors. More then likely it's the pads though then anything.
I didn't look but do they make them for the stock C4 rear? so that you can have a matched set if you go with them?
These rotors do have a strange pattern, almost like an Atom symbol...
Posted on: 2009/11/12 13:15
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
BrianCunningham Re: Brake Rotors
Nice price
I really need to upgrade brakes, as soon as I decide on calipers I'll keep this in mind.
Posted on: 2009/11/12 14:32
SpectatorRacing Re: Brake Rotors
ATE makes a good (and very popular) racing brake fluid. That doesn't mean that their rotors are automatically good, but at least I trust the brand. That's a start.
Powerslot, on the other hand, is a known good product. I've used them on the rear of my car for years.
I vote that you try the ATE parts so I know if they're a good brand to consider when I need a new set of rotors
As for the 2 piece offer, my front rotor discs (hats not included) are $350 each. $350 for 2 hats and rotors is retarded cheap.
Jeff, do you get other sizes? I use a 13.2"OD 32 mm thick 10 bolt disc...
Posted on: 2009/11/12 14:54
jreid Re: Brake Rotors
Boise ID
2 Posts
Hi Jeff
I'm a new memebr and saw your post...
Are you a vendor for DBA? I need to replace the Erda Speed d/s front rotors on my 99. I was looking for slotted only and saw your post at $350 per pair???? CGREAT Price and would be interested in a pair and maybe some rears as well.
Thanks,
Jeff R.
Posted on: 2011/1/15 0:01
jreid wrote:
Hi Jeff
Thanks,
Jeff R.
Welcome, Jeff.
Jeff will probably catch your question but if he doesn't, his website with phone # is: http://www.pnwzr1.com/
Posted on: 2011/1/15 1:47
zoe6 Re: Brake Rotors
Northern Indiana
167 Posts
I've been shopping for rotors and brakes also. Found reasonable price on Bendix Titanium and Bendix Rotors. I never read about anyone using Bendix brake products anymore. So I need some advice also! What is a good rotor and brake pad? EBS, Hawk, Bendix,....
This is on my to do list before spring. Was going to change them last fall but never found the time.
Thanks guys! Erin
Posted on: 2011/1/15 4:19
Owner of a great Vette! Totally stock ZO6
Thanks guys! Erin
I'm not sure where Bendix has their rotors manufactured but they've been around forever. GM rotors are also good for your application.
Avoid any aftermarket with holes. Slots are OK.
With out a doubt, Hawk HPS (High Performance Street) pads.
They're an improvement over stock, brake dust is about the same as stock, no squeal.
They will do OK for your track days because I don't think you'll use the brakes extremely hard the first few times.
Posted on: 2011/1/15 15:15
Steve40th Re: Brake Rotors
1114 Posts
Napa Premium rotors are used by many at the track, and they are relatively cheap. I use OEM rotors. A friend had 30k miles on his 03 ZO6, and he bought fancy rotors. He gave me his. Had them turned for 20 bucks total.
I would just turn the rotors and re-bed the pads.
Posted on: 2011/1/16 7:45
Ko'u ohana aia ku'a ikaika
Boise ID
2 Posts
Many Thanks Bill, I check his site out.
Posted on: 2011/1/16 15:54
