248 user(s) are online (211 user(s) are browsing Forums)
Strick Top end swap on my 92 LT1 to the LT4 (fresh start)
Lake Wylie, SC
129 Posts
I'm going to start fresh and see what I'm possibily missing on this project. My goal: to replace the top end of my 92 LT1 (6 spd vert) with a LT4 set of heads and a LT4 intake along with GM's Hotcam Kit that comes with the cam, roller rockers (1.6) springs, etc. I'm also upgrading the opti to a 95 opti using a 95 timing cover. Here is what I have so far:
LT4 heads
LT4 intake
95 timing cover
95 fuel rail w/ fuel regulator
long tube headers
fuel rail covers off a 95 (to fit new fuel rail)
I still need:
Harness for new opti (to adapt my 92 to the 95 opti) Got it
Hotcam kit from GM (comes with rockers, springs, keepers etc)
95 opti
I have questions about fuel injectors, which ones will I need? Looks like Bosch 3s
Also, who can upgrade my ECM (prom) to handle this project?
Finally what else will I need to complete this project? I know several of you have done this before me and I'm looking to have everything on hand before I start turning wrenches this fall. Thanks for any comments or ideas. I'd hate to have to re-invent the wheel on this. This is no longer just a pipe dream.
Posted on: 2011/8/9 19:38
rklessdriver Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
Still Missing:
Headgaskets - I recommend the Victor Reinz PN 5898, Mr Gasket PN 5716G, or GM Performance PN 12553160
Intake Gaskets - GM Performance PN 12528884, Fel Pro PN 1284 or Mr Gasket PN 135G
Timing cover gasket, crankshaft/balancer seal, WP gaskets, WP drive seal and Opti seal - Fel Pro makes a "kit" that is cheaper than buying all that stuff seperately. Fel-Pro QTCS45956
ECM - Honestly PCM4Less has litterally tuned hundreds of hotcam LT4's and can hit it darn near perfectly mail order. I'm sure others can do it, but I've actually seen one of those hotcam combo's they tuned and it was spot on.
Injectors - Your stock injectors are fine provided they are in good shape.
What are you going to do on the timing chain?? They are different between the 92 and 95.
If you want to keep the factory cam driven WP the GM Extreme Duty timing set is about your only option. GM Performance PN 12370835
You can upgrade to any number of double roller timing sets to fit 86-99 GEN I SBC's w/factory roller camshaft - but you'll have to utilize an elect WP. The Cloyes PN 9-3545X9 is the best of the best in this chain class and what I have in my 92. There are many other options out there from Cloyes, Roll Master and SA Gear thou. Any of these will seem cheap compared to the LTX chain set.....
Posted on: 2011/8/9 23:45
RickAnthony Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
ASE Master Certified
Downers Grove, IL
703 Posts
Your going to like that setup! Glad to see your still running the B&B's!
-=Rick
Posted on: 2011/8/10 3:02
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
biggrizzly Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
Any plans to freshen the bottom end?
I'm not being a Debbie Downer... just relaying some good honest first hand experience. I once scoffed at people that told me this very thing and thought that I would beat the odds; but I didn't
Only reason I ask you about your bottom end plans, is that in 2007 I did a top end rebuild on my motor. At that time it had about 150k miles on it. It was well taken care of up to that point with regular oil changes and service. It was not burning oil or other issues; matter of fact when the heads came off the cylinder bores looked great, as did the cam and lifters. The engine also was clean as a whistle on the inside with just a bit of carbon build up on the valves.
I had a bad water pump, some oil leaks and an Opti-Spark with 150k miles on it. I only had enough money to do a H&C swap and a small one car garage that really gave me no room to extract the motor. So, I decided to just do H&C. I probably spent nearly enough doing the top end only to do the whole damn thing if I had planned better too.
Once completed it held together fine and gave me more power and grins for about 18 months or so. I was a happy camper.
However, at my first trip to the drag strip ever with this car, I toasted every bearing on the crank assembly on my second run of the day. This was just over a year ago. When the engine was disassembled my builder said that it appeared that this damage was taking place over time and that the run at the track was just the straw that broke the camels back. Matter of fact I didn't even throw a rod, just spun a few bearings and heated things up real good!! Good enough to initially freeze up the bottom end. After it cooled, it would crank and try to run but you could hear the bearings just grinding away. I wish I had a video tape of that sound... it would convince a lot of folks to check that bottom end real good before just doing the top.
With all this said, I know that there are good reasons to just do top end rebuilds and your plans sound good and solid. I just wanted to relay my experiences as they are not told third person or about a friend of a friend. It happened to me.
Posted on: 2011/8/10 12:42
Strick Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
Lake Wylie, SC
129 Posts
Thanks guys, I appreciate the words of wisdom. Yes, I realize the risk of not beefing the lower end. My engine has 70K on it and if it does spin a bearing that will give me reason to build a nice little 383. I'm not a drag strip racer and only like the road course or auto cross fun days. However, that became much too expensive. So, I'm just running with my club on the open roads of North and South Carolina. Love those mountain roads in western NC. Besides, if I do spin a bearing, I'll be well practiced in tearing down my LT1/4. I have an electric water pump already so I'll be able to make more choices in timing chain set ups. I don't want to go through removing the tranny as that is another time consumming effort.
Changing compression ratio with head gaskets....hummmm...I have to look in on that.
The bottom line is that I'd like a little more fun in the fun pedal so I can keep up with the C5 and C6s, but still have a semi tame car in traffic.
Posted on: 2011/8/10 14:56
Lake Wylie, SC
129 Posts
Let's talk about timing chains. Remember I have an electric water pump and removed the gearing mechanism and plugged the hole. I'll have a GM Hotcam kit and a 95 timing cover with a 95 opti-spark. What is the current best set up? Thanks again.
Posted on: 2011/8/11 21:47
Lake Wylie, SC
129 Posts
No replies?
Posted on: 2011/8/12 15:56
Billet gears, German IWS chain, 9 keyways....
Posted on: 2011/8/12 17:19
Lake Wylie, SC
129 Posts
Help me out here, 9 keyways? German IWS chain? I'm not up to speed on these characteristics.
Posted on: 2011/8/13 12:40
PeteK Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
Will is just stating it is a quality piece.
9 Keyways facilitate an easy way to phase the cam exactly where you want it.
Phase=Degree
Do yourself a huge favor and degree the cam.
Posted on: 2011/8/13 12:44
Lake Wylie, SC
129 Posts
Phase=Degree
I thought that was standard procedure, but thanks for the reminder. Okay the timing chain question is settled. Now how about the LT4 damper. It's a different part number than the LT1. Should I upgrade this too?
Posted on: 2011/8/14 0:23
As long as your stock damper is in good shape, it's fine to re-use.
Check the rubber elastomer ring for cracks or chunks missing.
If your stock one is trash you can buy a new damper/pulley from Pioneer or Dorman.
Dorman PN 594-107 (reuses the stock hub)
Pioneer has 2 different ones.
Non SFI PN 872013 (requires hub PN 872015)
SFI approved PN 872043 (requires hub PN 872015)
Posted on: 2011/8/14 1:36
Lake Wylie, SC
129 Posts
Thanks Will.
Here's another question, the LT4 piston has a different style of ring. Are there any other differences in the piston between LT4 and LT1? Will those rings fit on the LT1 pistons?
Posted on: 2011/8/14 12:05
Strick wrote:
Thanks Will.
I don't know about any difference in the stock rings. Honestly I never looked that close thou. When I tear them down (to build them) - Once I press the pistons off the rods I just toss them in the trash.
The pistons are different. The valve relifs on the LT4 are smaller for more compression.
Posted on: 2011/8/14 16:27
Lake Wylie, SC
129 Posts
[IMG]http://i4.photobucket.com/albums/y136/48strick/DSC_0357.jpg[/IMG]
Still need the Hot cam kit, 95 opti and all the gaskets.
Posted on: 2011/8/19 1:23
mistaben Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
141 Posts
this right here... I think i had my bottom end freshened up and rebuilt for like 600$ at a local speed shop. they put the bearings in but I brought them to them. let them rehone the cylinder walls and mains and new piston rings etc, they also checked all my clearances to make sure nothing was out of spec.... I highly recommend this while you have it apart. at 150k miles these things go.
Posted on: 2011/8/19 1:35
Lake Wylie, SC
129 Posts
My next problem is the rocker arm studs. The LT4 heads have a 7/16-40 thread hole for the studs. If I buy a GM Hot Cam Kit, complete with roller rockers, springs, etc, What will the top of the stud be, 3/8" or 7/16" thread?
Posted on: 2011/8/24 0:47
The SA rockers GM sells in the kit are for 3/8" studs.
Posted on: 2011/8/24 1:24
Lake Wylie, SC
129 Posts
I got another part today. The harness connection 92 to 95 opti. I've learned that the GM Hot Cam Kit is designed for the LT1 engine. So the rocker arms will be adjustable and the studs will be 7/16 base and 3/8 top and they are self aligning rocker arms. So, all is good so far.
Posted on: 2011/8/25 0:32
Lake Wylie, SC
129 Posts
It's off to the AutoFair in CLT to see if I can find a vendor selling the Hot Cam Kit at a good price.
Posted on: 2011/8/27 13:03
1Fast04Vert Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
If you are interested I have a used GenII opti off a running LT4 engine for sale very, very cheap.
Posted on: 2011/8/27 14:54
Lake Wylie, SC
129 Posts
Thank you , but this is one part I think I should start out with new. BTW, how cheap is cheap?
Posted on: 2011/8/27 20:30
About $30.
Posted on: 2011/8/27 21:02
Steve40th Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
1114 Posts
95vette wrote:
About $30.
If he doesnt want it, I'll take it.
Steve
email me at Steves396lt1@yahoo.com if so. Thanks
Posted on: 2011/8/28 8:48
Ko'u ohana aia ku'a ikaika
Lake Wylie, SC
129 Posts
Next question, Do I need to go with LT4 knock sensors?
Posted on: 2011/8/28 13:07
Steve40th wrote:
95vette wrote:
About $30.
Steve
Steve, strick isn't interested, so email sent this morning.
Posted on: 2011/8/28 15:07
Stl94LT1 Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
128 Posts
There is no LT4 specific knock sensor, only OBDI and OBDII sensors.
As for the LT4 knock module, will only work in the 94-96 cars.
Posted on: 2011/8/28 17:53
1114 Posts
95vette wrote:
Steve40th wrote:
95vette wrote:
About $30.
Steve
Check, emailing you back now.
Posted on: 2011/8/28 19:12
Lake Wylie, SC
129 Posts
Steve40th wrote:
95vette wrote:
Steve40th wrote:
95vette wrote:
About $30.
Steve
Do I get a commission on this sale?
Posted on: 2011/8/28 20:13
Lake Wylie, SC
129 Posts
The Charlotte Auto Fair was a bust. So far the best price on a GM Hot Cam Kit is $566 from GMPartsDirect. Anybody know of someone with a better price?
Posted on: 2011/9/2 0:47
Lake Wylie, SC
129 Posts
I found a good price on the GM Hot cam kit from Jegs Performance online and ordered it. Now I need the timing chain and opti along with the gaskets. I'm almost there. A great guy on the CF sent me his LT4 left overs (rockers, springs, studs and adjuster nuts, push rods, and fuel injectors) for just the shipping cost. Of course I sent a little extra to cover a beer or two. So, I'll have to decide on which rocker arms to use as the ones I got from my buddy look almost new. The LT4 set up is not adjustable and the hot cam kit rockers are adjustable. This is going to take some more thought.
Posted on: 2011/9/15 1:16
Lake Wylie, SC
129 Posts
FedEx showed up today with my Hot Cam kit. Now I'm really getting excited about this project.
Question, when replacing a cam, should the lifters be replaced on roller set ups?
Posted on: 2011/9/15 14:53
Check them over really well. Make sure the roller wheel has no delamination on the contact surface and the brgs all roll smooth, check the body for deep gouges on the sides, cracks around the skirt and cracks radiating from the brg trunion/axel.... Honestly with proper engine maintenance they are typically good forever.
As long as they check out good they can be reused.
Posted on: 2011/9/15 22:06
Lake Wylie, SC
129 Posts
Thank you Will. I'll do just what you suggest.
Posted on: 2011/9/16 1:05
Lake Wylie, SC
129 Posts
I'm down to the timing chain, rocker studs, opti, and gaskets. Timing chain is narrowed down to the GM Extreme duty set GM pn 12370835. The rocker studs will be the ARP pn 070-134-7104 set which has a touch longer length, but only by .145". The opti will be a GM part for the 95 LT1 for around $362. I have the intake gasket figured out as there is a difference in the area they cover. I'll be port matching the intake to the heads and pn 12367777 intake gaskets won't block any of the porting areas. Next, I'll be sending my LT4 injectors out to be cleaned and checked. And lastly, will be the chip to PCM4Less. I'll list all of the parts I use and let you know how the project is progressing. Estimated start date.......November.
Posted on: 2011/9/22 18:13
Lake Wylie, SC
129 Posts
I received the ARP studs and the timing chain. I tried out the studs and found that they bottom out before the shoulder on the stud touches the head. So I immediately sent them back and ordered the ARP 134-7101 studs which are a touch shorter and should not bottom out like the 7104's did.
I looked at some thread inserts at work and noticed that the very bottom of the insert (where the part goes straight across the diameter of the hole, I guess it's used to install the insert) and it has a small notch which is used to break off the piece that goes across the bottom of the insert. In my LT4 heads, the inserts have that same piece going across the bottom of the insert. Along with that, I noticed that the LT4 OEM studs are shorter than the ARP studs (at least at the threaded part that goes into the head). Do you think GM just left that piece in there and shortened the stud to hasten the assembly process?
Posted on: 2011/9/30 19:48
Be sure to talk to Bryan at pcm4less about the knock sensor.
Posted on: 2011/9/30 22:58
flyboy Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
Dumb question maybe, but do LT4 heads have threaded inserts on the rocker arm studs from the factory?
Posted on: 2011/10/1 1:07
Lake Wylie, SC
129 Posts
Absolutely.
I found out that the bottom of the insert is removable. You just use a small pair of needle nose pliers and break it off. GM left them on as the OEM studs are shorter than ARP studs and don't bottom out. It saves time on the assembly line.
Posted on: 2011/10/1 22:11
tjpreul Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
Strick wrote:
Absolutely.
Are you going to use pushrod guides? This could help with the thread length.
Posted on: 2011/10/2 3:46
BrianCunningham Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
only use pushrod guide for non-self-aligning rockers.
Posted on: 2011/10/2 17:18
128 Posts
Strick wrote: GM left them on as the OEM studs are shorter than ARP studs and don't bottom out. It saves time on the assembly line.
I'm guessing that the ARP stud base is longer because many use these with guide plates.
Posted on: 2011/10/2 21:15
Lake Wylie, SC
129 Posts
Good thought, but I don't need guide plates. I'll just break off the pieces and move on. I expect the new studs this Monday. I'll let you know how they work out.
Posted on: 2011/10/3 0:28
Lake Wylie, SC
129 Posts
I finally removed all the tangs at the bottom of the stud holes. The new ARP rocker arm studs fit just right. Now to get the opti-spark and the gaskets. I'll be taking the heads in for port matching to the intake next.
Posted on: 2011/10/9 19:57
141 Posts
rklessdriver wrote:
Still Missing:
hey rkless,
do you think pcm4less could hit my '91 spot on too, or is it because he has an lt1 computer system?
383/afr190cc/sr/219cam
Posted on: 2011/10/9 21:59
Lake Wylie, SC
129 Posts
Got my heads back. Ken, of Pro Outboard, has a great shop for doing valve work and re-surfacing. The heads have new LT4 springs and oil seals. The surface is dead on flat and looks very shiney. The chambers measure out at 54cc's. Everything is set for the Hot cam. Now it's getting close to start wrenching. I have one more cruise and then I'll begin the set up for surgery.
Posted on: 2011/11/11 0:20
bam Re: Top end swap on my 92 LT1 to the LT4 (fresh start)
missouri
250 Posts
Nice, got any pictures? Post some if you can.
Posted on: 2011/11/11 2:59
Lake Wylie, SC
129 Posts
Yes I do. I'll be posting them as I start the project. You guys on here are very observant and posting pictures sometimes sparks additional ideas or comments that I over looked. I'm putting together a complete checklist of removing the engine according to the FSM and other inputs. It will be interesting to see the additional items that my list has missed. I'm still having problems with the "Happy Hooker" and those small bolts in the intake. They just seem to be too small, but others swear by it.
Posted on: 2011/11/12 1:43
Lake Wylie, SC
129 Posts
Here is a few shots of the heads.
Before
[IMG]http://i4.photobucket.com/albums/y136/48strick/head.jpg[/IMG]
during resurfacing
[IMG]http://i4.photobucket.com/albums/y136/48strick/head2.jpg[/IMG]
finished
[IMG]http://i4.photobucket.com/albums/y136/48strick/head1.jpg[/IMG]
Posted on: 2011/11/12 2:21
