211 user(s) are online (131 user(s) are browsing Forums)
Dads90 Floor Jack/Did I screw up ?
Pearland, Tx
318 Posts
Took everyones advice on floor jacks. Went to Northern Tool and they never heard of a Alcan XL35. They had a pretty good selection so I got the Torid red 3000 lbs jack. This thing acts like is struggling to lift the car. I have to put lots of weight on the handle to pump it up. Its all aluminum, its lite but is it heavy duty enough ? The wheels are now scuffed up and I'm considering taking it back. I'm hoping not to get any crap about it. The vette is 3800 lbs roughly, any advice.
Posted on: 2008/2/9 22:18
Dads90 RE:Floor Jack/Did I screw up ?
Pearland, Tx
318 Posts
Opps, thats Arcan Xl35, sorry.
Posted on: 2008/2/9 22:21
pianoguy RE:Floor Jack/Did I screw up ?
Posted on: 2008/2/9 22:51
DaleD RE:Floor Jack/Did I screw up ?
Cuyahoga Falls, Ohio
1389 Posts
If it's that same jack as the one in that thread over on CF that pianoguy linked to, it's a 3.5 TON jack. That's 7000 lbs. The Vette is about 3200 - 3400 lbs depending on year and options.
Posted on: 2008/2/9 23:10
FLYINLOW90 RE:Floor Jack/Did I screw up ?
Windsor Ontario Canada
514 Posts
I don't know but I would think that jack would still do the job rated at 3000 lbs.
After all your not lifting the whole car with it, only 1 corner. 1 corner of the car won't be over 3000 lbs.
JMO.
Gary
Posted on: 2008/2/9 23:23
Pearland, Tx
318 Posts
Even the catalogue they handed me while I stood in line didn't list it. They were just a bunch of kids. Even the little junkie walmart jacks were easier to pump up. I want to lift one side at a time to put in jack stands. Then move to the other side. They have cheaper low profile thats rated 2 1/2 tons mostly steel and heavier, but it will take less effort to lift it.
Posted on: 2008/2/10 0:49
bogus RE:Floor Jack/Did I screw up ?
20861 Posts
sounds like there is something out of wack with the hydraulic ram.
I have an AC-Hydraulic jack... nice, but hella expensive.
Posted on: 2008/2/10 1:28
TommyT-Bone RE:Floor Jack/Did I screw up ?
33814 Posts
Bring it back and get what you want. Tell them it doesn't work right. Don't keep something that's just going to piss you off.
Posted on: 2008/2/10 1:38
I think they're a pretty good outfit, they should take it back if you're not happy with it.
Posted on: 2008/2/10 1:42
Pearland, Tx
318 Posts
Tomorrow it's going back. I stood there thinking " I shouldn't have to grunt to lift this car". Was less effort with the 12" handle on the little cheapy jack. I hate returning items even if their defective.
Posted on: 2008/2/10 2:27
33814 Posts
It's all part of being a man.
Posted on: 2008/2/10 3:01
Pearland, Tx
318 Posts
Hey Tommy, did you get my PM last week ?
Posted on: 2008/2/10 3:24
33814 Posts
[/quote]Hey Tommy, did you get my PM last week ?[/quote]
No PM. Sorry.....
Posted on: 2008/2/10 4:14
CasetheCorvetteman RE:Floor Jack/Did I screw up ?
This is the one i have, its 2,000kgs, fully lowered at 94mm and 510mm fully raised. Lifts the car from the front centre cross member as seen in the pic with ease.
[web]http://i11.photobucket.com/albums/a185/Casethecorvetteman/Car%20work/Tools%20and%20equipment/Jack.jpg[/web]
[web]http://i11.photobucket.com/albums/a185/Casethecorvetteman/Car%20work/Tools%20and%20equipment/Jackedup1.jpg[/web]
Posted on: 2008/2/10 4:39
Pearland, Tx
318 Posts
Nice jack, Case. My air foil wouldn't let this jack roll far enough under to catch the cross member. May have to drive up on a 2 X 10.
Posted on: 2008/2/10 4:55
I dont know about that, cause it gets up under mine and its about as low as it can get, its got quite a long reach.
Posted on: 2008/2/10 5:22
cmashark RE:Floor Jack/Did I screw up ?
virginia beach, va
74 Posts
not to get too far off topic, but i have noticed some people using the front crossmember to jack the front for jackstands....but where do put the jack to lift the entire rear after you have lifted the front?
i have seen the link for jackstand placement, but was curious as to where to put it just to lift the entire rear.........
chris
Posted on: 2008/2/10 5:49
1987 Coupe 2 tone white/silver, auto, Z52.
bone stock, except for Flowmaster catback and precats eliminated.
You can get a tool that goes in the jack so you can lift it by the diff between the exhaust pipes, but id be reluctant to use that as a lift point.
Posted on: 2008/2/10 6:13
Mr_Mojo RE:Floor Jack/Did I screw up ?
Lakewood,NJ
225 Posts
That's the Jack-A-Vette, I have one and it works well.
For the front I use a regular ol floorjack after I drive up on 2 x 10's and then place the jackstands where the swaybar is attached to the frame.
For the rear, I use the Jack-A-Vette and place the jackstads either at the point marked "jacking point" or on teh rear part of teh frame where the bumper attaches.
Posted on: 2008/2/10 15:41
Pearland, Tx
318 Posts
Well today I took back the 1 1/2 ton Torin jack. Nat'l Tool had to open it, inspect it, I pled my case. I got the refund and bought the 2 1/2 ton Torin. What a difference. This doesn't take much effort at all. Its not as fancy, but I happy with it. The extra money difference went into jack stands. Thanks for the input guys. I'll have to get some 2x10's to drive onto to lift from front now.
Posted on: 2008/2/11 4:15
33814 Posts
It's always easier to return something when you want to get something else because it didn't work or you weren't happy with the product. I've kept way to much stuff I should have returned because I lazily waited to long to return it. Good job
Posted on: 2008/2/11 11:46
CentralCoaster RE:Floor Jack/Did I screw up ?
Its a "quick lift" jack. Probably has quick release also.
As mentioned, it's a man's jack. This means it lifts the car in less pumps, but requires a little more grunt per pump. It's due to the piston sizing and done on purpose.
If you want a girly jack that you can use without breaking a nail, you bought the wrong one.
I like that one, looks lower profile than my cheapy harbor freight jack. Does it reach the front cross member? Actually what I need is a high lift jack if I'm gonna be pulling the tranny once per year.
Posted on: 2008/2/11 17:30
Pearland, Tx
318 Posts
I grunt all day lifting packages (UPS) I don't want to grunt lifting my car It doesn't go under the air foil. So I don't know far it will reach. Will put it on 2X10's and see. Will post a picture.
Posted on: 2008/2/12 3:55
MK 82 RE:Floor Jack/Did I screw up ?
Palm Beach Gardens, FL
439 Posts
Been doing it for 10 years with no problems.
This one.
http://www.corvettegadgetman.com/products3.html
Posted on: 2008/2/12 4:02
96 CE Roadster LT4
SpectatorRacing RE:Floor Jack/Did I screw up ?
I grunt all day lifting my package, too
I crushed my rear crossmember trying to lift the whole back of the car once...lesson learned. Now I do it one side at a time. Plus I have two 3-ton jacks so I can just lift everything and stick the jackstands under all 4 corners. Only takes about 4 minutes.
If anyone doesn't have a jack and needs one, Costco carries a nice low-profile aluminum 3 ton jack. It's only $99 and I've been using one for a few years now with no complaints.
Posted on: 2008/2/12 4:06
If that rear crossmember you're talking about is above the spare, then it isn't part of the frame as far as I know.
It's paper thin, wouldn't stand a chance as a jacking point. I lifted mine by the rear diff for the first time, I figure not a big deal as the diff carries the entire sprung weight of the car anyways as it sits, and more when you hit a bump.
Posted on: 2008/2/12 5:12
yup, that's the one. I proved you right...
Posted on: 2008/2/12 21:09
I confess I jacked it back there once, I threw a 4x4 between it an the jack, or maybe I even still had the spare installed and threw it halfway on the lip of the spare, which spread the load out enough to work.
Posted on: 2008/2/13 0:04
pappyfreebird RE:Floor Jack/Did I screw up ?
1028 Posts
hey drop t...what are the demensions of that lil rig ya got?? i ll weld me one up ....looks like the ticket fer the rearend..if you would... height of center n width of top n bottum plate .. really be preciated
Posted on: 2008/2/13 14:48
1028 Posts
well i got bored n made me one....n I beam the right hieght n cut to length be cheapest n easiet...dint have I beam so i used 2 c beams back to back n welded em n cut top down to 2.5" n bottum is bout 4"square n prolly 4.5 tall...hey was free what the hey...now ifn fits i be happy ..ifn nawt i have me a mini anvil
Posted on: 2008/2/13 20:26
439 Posts
I will try to measure it tomorrow. Wouldn't be hard to fabricate. Kinda looks like a slice out of a railroad rail.
Edit: Saw you made one. Pappy, even redneck I am losing you!
Posted on: 2008/2/14 0:27
96 CE Roadster LT4
I just measured mine. The I-beam is wider on the bottom than the top.
Length - 3.5"
Width, top - 1.5"
Width, bottom - 4"
Height - 3.5"
There is also a rubber pad on top, about 3/16" thick. And the bottom has a provision to screw in a peg (centered on the bottom) that fits in the hole in your jack.
Posted on: 2008/2/14 0:49
1028 Posts
thanks dudes ....mines 4 tall n bout same other wise...ceptin as i think cc er somebody said ealier ...mines got a piece of tin welded over exhaust right where this lil helper would go...but i also noticed real thin there at curve (exhaust pipes)...so ill have some pipe made up n tell them to be sure n use strap brace instead of tin leaving that arear clear fer this lil tool...thanks fer the tips guys...now how the L do ya ya lift that front evenly wid out a 4' jack handle...(lay on ground n swear a bit i rekon)
Posted on: 2008/2/14 12:16
Ramrod RE:Floor Jack/Did I screw up ?
S. California
296 Posts
I made mine from angle iron, butted them up to make a "T". it slips between the exhaust, and ya jack at the bottom of the "T"
Posted on: 2008/2/27 3:23
