308 user(s) are online (276 user(s) are browsing Forums)
bogus It has happened... again...
On my way to lunch, a Peterbilt rear-ended me at a stop light.
Thankfully, he was going REAL slow... he has stopped and was drifting up to the light, when he lost me in his blind spot - the hood!
Thud.
It has scuffed the rear bumper pretty good, but the main damage is a tear in the lower right portion of the bumper.
The driver is insured, and admitted to the accident.
No injuries; the truck was doing about 2mph.
Then again, the kinetic energy in an 18-wheeler at 2mph is staggering.
My Vette was only cosmetically damaged. I don't think that even the bumper impact absorbing material was hurt. Won't know for sure until the adjusters are done.
Time to call McJack's!!!
Posted on: 2016/4/12 0:22
Ultraman Re: It has happened... again...
14738 Posts
Geez that's to bad Andy.....that is a total rookie move by the truck driver if you don't know where they are then you stop where you are at......I am surprised he did not offer to settle right on the spot so it did not get turned in to his insurance......they frown on any type of mishap.......glad you were not hurt.....
Posted on: 2016/4/12 0:40
pianoguy Re: It has happened... again...
Indeed, glad it was not more serious!
Posted on: 2016/4/12 0:59
TommyT-Bone Re: It has happened... again...
My goodness. Is that Vette a target? Only Letty has it worse.
Posted on: 2016/4/12 1:43
Matatk Re: It has happened... again...
22803 Posts
Glad you're OK!
Posted on: 2016/4/12 2:09
teebee Re: It has happened... again...
12364 Posts
Could have been much worse, thank god it wasn't.
Posted on: 2016/4/12 3:05
BrianCunningham Re: It has happened... again...
Glad you're ok
Make sure they check the aluminum frame for cracks
Posted on: 2016/4/12 16:19
rklessdriver Re: It has happened... again...
Could have been much worse. Sorry to hear but glad your OK. The Guru Vette can be fixed.
Posted on: 2016/4/12 19:02
bogus Re: It has happened... again...
oh, yes. it looks very fixable.
I need to get under to make sure that the impact absorbing material is ok, and that there are no signs of bends in the frame.
The C4 is real easy to find bend frame problems... the epoxy that bonds the steel frame to the SMC body panels and storage area will break and leave gaps in the seams.
It's also the death knell of the poor car...
Posted on: 2016/4/12 19:55
joeld Re: It has happened... again...
Sorry about the car, glad you're OK!
When you start the inspection, use the best flash light you've got. Good luck
Posted on: 2016/4/13 1:00
captmike13 Re: It has happened... again...
Hillsboro Mo
2165 Posts
Geeze Andy if it weren't for bad luck in traffic you'd have no luck at all.
Posted on: 2016/4/13 1:48
13 GMC 3500 dually
captmike13@yahoo.com
BillH Re: It has happened... again...
Sucks, Andy.
Good Luck
Posted on: 2016/4/13 15:18
vetteblondie Re: It has happened... again...
Jonesboro, AR
4648 Posts
Only collision I had with a semi was a 76 Montego while in high school. Name "lucky" was written on her cab door.
Anywho, glad you are okay - bumpers can be fixed or replaced. Be sure to check out your exhaust system and make sure it didn't get jammed forward, check wiring, etc.
Hope all goes well with the insurance
Posted on: 2016/4/13 17:47
�Ugol's Law
I haven't seen any damage to the exhaust. I think his bumper was too high...
The exhaust sounds the same (I do have a leak up at the transmission I need to fix)...
Posted on: 2016/4/13 19:59
Jonesboro, AR
4648 Posts
The F150 that nailed the back of mine pushed one side up farther than the other.. hit it just right
Posted on: 2016/4/13 21:35
�Ugol's Law
I am concerned about the offset nature of the impact. It was more on the right than left... and that might have a bad result to my frame.
I really need to crawl under and check.
Posted on: 2016/4/14 16:50
The preliminary estimate is in... Just under $1100.
What is still to debate is if there is any hidden damage and we won't know that until the car gets to the body shop and Jack has the chance to take it apart.
Posted on: 2016/4/26 1:36
The latest update...
The bumper cover needs to be replaced. Apparently, the cover was stretched beyond repair. They can flex, but go to far, it damages and distorts the cover.
No structural damage was found... whew...
ETA is Saturday... hopefully.
Posted on: 2016/5/25 16:41
GRIS Re: It has happened... again...
OKLAHOMA
7643 Posts
GLAD YOU GOT OFF EASY ANDY.
Posted on: 2016/5/25 22:51
yea... coulda been ugly. I was afraid that the ins company would go low ball on the value and really screw me.
Posted on: 2016/5/25 23:37
Glad to here
Posted on: 2016/5/26 1:20
It's all fixed! About $1600 later...
Looks great!! Jack did a fab job, as always!!!!!
Posted on: 2016/6/6 17:06
Pics!!!
Posted on: 2016/6/7 2:31
I will do some next week... the next few days are gonna be nutso...
Posted on: 2016/6/8 1:47
