179 user(s) are online (121 user(s) are browsing Forums)
cuisinartvette Tech Tip for all
[QUOTE]the best way to test for spark is to use a cat. Fill the boot with anything that smells like cat food and then set the cat on the air cleaner. Then you have to shut the hood or you could get a contaminated result if the cat jumps off due to the sound of the starter engaging. Turn it over and be alert for a burnt hair smell.
Cats are great though, really. Think if the Indians had brought cats instead of Turkeys to the first thanksgiving dinner. [/QUOTE]
:book:
Posted on: 2008/12/2 21:04
Notorious Re: Tech Tip for all
Looking to score some points with the cat fanciers here?
Posted on: 2008/12/2 21:18
pianoguy Re: Tech Tip for all
LMAO!
Posted on: 2008/12/2 21:33
BrianCunningham Re: Tech Tip for all
You let the cats into the garage again didn't you?
Posted on: 2008/12/2 23:13
TommyT-Bone Re: Tech Tip for all
33770 Posts
And cats like to chase __________ .
Posted on: 2008/12/3 0:15
vetteblondie Re: Tech Tip for all
Jonesboro, AR
4659 Posts
I hate cats, have any more ideas how to kill 'em? I have a ton of strays here that need to be gotten rid of!
Posted on: 2008/12/3 0:20
�Ugol's Law
Randyj75 Re: Tech Tip for all
MD
129 Posts
Thats what dogs are for.
Or you could have JSUP talk to them about high performance heads.
J/K John
Posted on: 2008/12/3 2:41
JrRifleCoach Re: Tech Tip for all
1524 Posts
Kittah not Happy!
Posted on: 2008/12/3 3:03
CSS996 Re: Tech Tip for all
Mega Guru
Central PA
3644 Posts
I only like the LOL variety.
Posted on: 2008/12/3 3:07
Currently "Between Vettes".
CentralCoaster Re: Tech Tip for all
Stray bullets for stray cats.
Posted on: 2008/12/3 4:02
Schrade Re: Tech Tip for all
Not grammatically correct!
Sulpher, nitrogen, brass, lead, in that sequence.
Posted on: 2008/12/3 4:35
Here's one solution that has the added benefit of pissing off PETA.
Yummy
happydad Re: Tech Tip for all
northern Ill
151 Posts
Here's a way to contain them
jpeg  cat-carrier.jpeg (105.41 KB)
478_493682c012e0d.jpeg 745X576 px
Posted on: 2008/12/3 13:00
skirlin Re: Tech Tip for all
Caledonia Michigan
277 Posts
LMAO. Happydad, that is some funny stuff.
Posted on: 2008/12/3 13:15
BillH Re: Tech Tip for all
What do Coyote here call cats?
Lunch
Posted on: 2008/12/3 13:38
Man! Whew. That makes me pucker yup!
And NOT at the end that puckers from lemons either nope.
Whew. Yikes.
Posted on: 2008/12/3 14:01
Jonesboro, AR
4659 Posts
Whew. Yikes.
BWWWAHHHHHAAAA!!!
Posted on: 2008/12/4 3:12
�Ugol's Law
