cuisinartvette | Tech Tip for all | ||
[QUOTE]the best way to test for spark is to use a cat. Fill the boot with anything that smells like cat food and then set the cat on the air cleaner. Then you have to shut the hood or you could get a contaminated result if the cat jumps off due to the sound of the starter engaging. Turn it over and be alert for a burnt hair smell.
Cats are great though, really. Think if the Indians had brought cats instead of Turkeys to the first thanksgiving dinner. [/QUOTE] :book: |
Posted on: 2008/12/2 21:04
Notorious | Re: Tech Tip for all | ||
Looking to score some points with the cat fanciers here?
Posted on: 2008/12/2 21:18
pianoguy | Re: Tech Tip for all | ||
LMAO!
Posted on: 2008/12/2 21:33
BrianCunningham | Re: Tech Tip for all | ||
You let the cats into the garage again didn't you?
Posted on: 2008/12/2 23:13
TommyT-Bone | Re: Tech Tip for all | ||
And cats like to chase __________ . |
Posted on: 2008/12/3 0:15
vetteblondie | Re: Tech Tip for all | ||
I hate cats, have any more ideas how to kill 'em? I have a ton of strays here that need to be gotten rid of!
Posted on: 2008/12/3 0:20
The answer to any question that begins with "Am I the only one who..." is always "no". �Ugol's Law Yes, I'm a bitch... just not YOURS. |
Randyj75 | Re: Tech Tip for all | ||
Thats what dogs are for. Or you could have JSUP talk to them about high performance heads. J/K John |
Posted on: 2008/12/3 2:41
JrRifleCoach | Re: Tech Tip for all | ||
Kittah not Happy!
Posted on: 2008/12/3 3:03
CSS996 | Re: Tech Tip for all | ||
Mega Guru
I only like the LOL variety.
Posted on: 2008/12/3 3:07
Currently "Between Vettes". |
CentralCoaster | Re: Tech Tip for all | ||
Stray bullets for stray cats. |
Posted on: 2008/12/3 4:02
Schrade | Re: Tech Tip for all | ||
Not grammatically correct! Sulpher, nitrogen, brass, lead, in that sequence. |
Posted on: 2008/12/3 4:35
Here's one solution that has the added benefit of pissing off PETA. Yummy |
happydad | Re: Tech Tip for all | ||
Here's a way to contain them
Posted on: 2008/12/3 13:00
86 Coupe,350 bored .040 over,Eagle Internals,Scorp RR.Crane Cam,Hedman Hedders,Holley Mani,TCI Trans,3:73 Rear, Demon Carb ,Hole in the hood Scooped and Lots of leaks(Horsepower) I forget :thumbleft: |
skirlin | Re: Tech Tip for all | ||
LMAO. Happydad, that is some funny stuff.
Posted on: 2008/12/3 13:15
There is no point in living if you can't feel alive. |
BillH | Re: Tech Tip for all | ||
What do Coyote here call cats?
Lunch |
Posted on: 2008/12/3 13:38
Man! Whew. That makes me pucker yup! And NOT at the end that puckers from lemons either nope. Whew. Yikes. |
Posted on: 2008/12/3 14:01
BWWWAHHHHHAAAA!!! |
Posted on: 2008/12/4 3:12
