Matatk | Basement Remodel (lotsa pics) | ||
Well, as mentioned in daily chat, we are finishing our basement. We have my wife's cousin doing most of the base work, I'll do some of the finish work. Here are a few pictures to get started:
Day 1, framing started: Moving junk off the walls Sill plates down Day 2, framing: Bathroom I'll post more as things come along. Day off today for the guys then they'll be back at it tomorrow to finish framing the walls and get the soffits done. Electrician is supposed to come Fri night and start pulling some wire. Plumber won't be here until the 11th. We'll just move along with what we can. Matthew |
Posted on: 2009/2/5 16:33
Epimax | Re: Basement Remodel (lotsa pics) | ||
That's going to be Nice! Looking forward to more pics!
Also,that's quite a gym you have there! |
Posted on: 2009/2/5 16:47
pianoguy | Re: Basement Remodel (lotsa pics) | ||
How do you like the metal studs? I've never worked with them.
Posted on: 2009/2/5 17:39
CentralCoaster | Re: Basement Remodel (lotsa pics) | ||
Did you price out the metal studs vs. wood?
Posted on: 2009/2/5 18:55
BrianCunningham | Re: Basement Remodel (lotsa pics) | ||
You don't want wood studs in a basement
Good choice |
Posted on: 2009/2/5 19:05
red_johnny | Re: Basement Remodel (lotsa pics) | ||
Nice teaser pics. Now you have to show us more progress...lol, I am one to talk.
Posted on: 2009/2/5 19:24
My whole foundation is wood. |
Posted on: 2009/2/5 19:33
Matatk | Re: Basement Remodel (lotsa pics) | ||
Thanks guys. I am not doing (ie personally putting up) the framing with the metal, but it looks easier than with wood from watching Andy do it (wife's cousin's uncle by marriage...haha figure that one out). Put down a sill plate of pressure treated lumber then put down a metal track on top. Screw the studs in with sheet metal screws. Cutting is done with a pair of tin snips. To do a horizontal joint (like under the windows) he notched the sides then bent it the center over to make a 90*. He was trucking along pretty quick.
As far as cost difference, for my basement the difference was like $65 more using metal than wood. for 2.5" steel studs I paid 2.15 each vs 1.85 for wood. There are three different sizes for various things, 3.5, 2.5, 1 5/8. There are pros and cons for both wood and metal. I'm not gonna get into the whole debate, I just felt it better for my application. My BIL is almost finished with their basement and he used wood. Either or is fine. Couple sites: http://www.dietrichindustries.com/stu ... e/introtometalframing.pdf http://video.bobvila.com/m/21319325/b ... ming-with-metal-studs.htm Matthew |
Posted on: 2009/2/5 20:03
Thanks, I'm itching to get everything back together. It's been 5 days since I've worked out and I hate it. I am gonna do a circuit training video for the next couple weeks because I can do it in the living room with a couple of dumbbells only. It's ok, because circuit training is a good thing to do. Some people give it a bad rap, but that's because they are idiots....lol. Good to mix things up. Matthew |
Posted on: 2009/2/5 20:06
Posted on: 2009/2/7 12:39
TommyT-Bone | Re: Basement Remodel (lotsa pics) | ||
Looks like there is good attention to detail. Maybe you'd like to rent it out.
Posted on: 2009/2/7 12:51
OK, haven't gotten a lot done yet, but we started hanging a little drywall last night. Plumber will be here today to get the bathroom sorted out. Electrician will finish (hopefully) tomorrow. Plumber will be back Friday for finishing touches. I'd like to get as much drywall done by Friday night as I can. If that goes well, the patchers can come in Monday and start.
Matthew Few pics of drywall going up: Closer up of the same pic above: |
Posted on: 2009/2/11 12:35
crash | Re: Basement Remodel (lotsa pics) | ||
LOOKING GOOD MATT. ROSIE WANTS ME TO FINISH THE BASEMENT BUT IM HOLDING OFF FOR AS LONG AS I CAN. IVE GOT OTHER SRUFF I WANT TO DO FIRST, IF I DID START NOW ID PROBALY BUILD THE WET BAR FIRST AND THAT WOULD PROBALY BE AS FOR AS I GET FOR AWHILE LOL
Posted on: 2009/2/11 12:42
IM NOT COMPLETELY USELESS I CAN BE USED AS A BAD EXAMPLE |
C2C3C4C6 | Re: Basement Remodel (lotsa pics) | ||
Your work is progressing well. One suggestion: put the check valve for your sump pump below the surface of the floor --in the pit right on the pump. Last year the connection on my pump failed, and all the water was discharging IN the basement. If you put the check valve in the pit, and screw it into the pump, there is only one connection with a clamp. That way there is less chance the clamp will fail. I have done this and it works great. I put two clamps on the valve where it connects to the discharge pipe, and put pipe clamps on the pipe where it runs up the wall to the outside. They hold the pipe to the wall firmly, giving it less chance of moving everytime the pump goes on.
Good Luck |
Posted on: 2009/2/11 12:54
Looking good. I got to post some picks of my own this weekend.
Posted on: 2009/2/11 14:22
Thanks for the suggestion. I actually had mine go bad about 3 months ago. The PO/builder used the wrong size valve and the contortion and twisting over the years tore the rubber and sprayed the stuff all over the floor. I was able to fix it without too much trouble, but a PIA nonetheless. Plumber was here today and got started on the vent pipes and running the copper. We'll finish it up on Friday. I'll get some drywall put up today. Thanks for the comments, everyone. Matthew |
Posted on: 2009/2/11 22:34
Schrade | Re: Basement Remodel (lotsa pics) | ||
Looks great. Wish I had both my own sticks workin' better to do upgrades like that in my own place.
You wirin' in CAT5 lines for internet? Speaker wirin' for integral wall speakers/surround sound? IR ports for remote control entertainment center, lighting and HVAC? Intercom for the upstairs? HVAC is important. Nothin' worse than Gold's steamy saturated stinkin' gym in wintertime, with NO oxygen/ventilation. Makes for a lousy burn. EDIT: Scratch the intercom; only one person you gonna' hear from on that... "Honey, can ya' hear me now?" |
Posted on: 2009/2/12 3:32
CAT5 is preexisting throughout the entire house. No surround sound, I have that upstairs and won't be putting it in the basement. If I do, I have a drop ceiling. As far as HVAC, I cut a couple vents, but my basement is almost as warm/cool as the rest of the house. I have a constant circulation HVAC unit that helps eliminate hot/cold spots. I don't need IR, I can use old fashioned switches
Got up 9 more panels last night on the walls and soffits. Going quicker than I expected, always a pleasant surprise. Matthew |
Posted on: 2009/2/12 12:24
xccter | Re: Basement Remodel (lotsa pics) | ||
Looking Good!
Been there. Done that. Mark |
Posted on: 2009/2/12 12:28
´71 350/270 L48 Coupe Numbers Matching Ontario Orange 4 spd, Mid-year side pipes, deluxe black leather, ac, ps, pb, pw, tilt/tele steering wheel. 93k miles. Original rotors still riveted to the hubs! NCRS #48337 |
Posted on: 2009/2/13 13:58
OK, drywall is 100% done as far as the hanging goes, including bathroom. Need to put up two more corner beads and pick up another one at the store tomorrow, that's about a 5 min job. Everything ready for the tapers to come in and do the finishing. After that we'll prime really quick and my cousin will get started on the drop ceiling and finishing. I also picked up a couple more base cabinets to stain and the countertop that will be on them.
A few more pics. Countertop I picked out: Matthew |
Posted on: 2009/2/15 1:39
Wow, some good progress there!! I am really taking my time on mine on purpose. I dont want to feel rushed this time but it is time to kick it into high gear so I am going to hang some dry wall tomorrow and see how much we can get done. I have a tiny bit of electrical to do yet (2 outlets and 1 light) Lights already wired but I need to relocate it. I did my bathroom light/fan tonight and it took about an hour to do, the ducting did not want to cooperate. Looking forward to more pic and how your going to fit that very large counter top somewhere....lol.
Posted on: 2009/2/15 1:56
pappyfreebird | Re: Basement Remodel (lotsa pics) | ||
sweet matt...my house is 1930 built n basement is a dungin ,,no amount of cash would make it look like yers evin started with,,,dig that gym thou..aways wanted a combo set up,,,aways wanted a cool basement too,,mines got laundry room my weights treadmill n some food shelves..n rest is wood shop junque hole... oh well i spend my time in garage i rekon
Posted on: 2009/2/16 2:10
Stained my base cabinets today so they'll be ready to go next week. Tapers are supposed to be here on Friday morning to start patching. I'm anxious to get started priming and painting.
Matthew |
Posted on: 2009/2/19 0:36
Excellent - man, that's coming together fast!
Posted on: 2009/2/19 1:16
So is pappy's scribin'. Good work pappy! Git BACK!!! Quote: [code]sweet matt...my house is 1930 built n basement is a dungin ,,no amount of cash would make it look like yers evin started with,,,dig that gym thou..aways wanted a combo set up,,,aways wanted a cool basement too,,mines got laundry room my weights treadmill n some food shelves..n rest is wood shop junque hole... oh well i spend my time in garage i rekon |
Posted on: 2009/2/19 6:29
More pics. We've been moving along quick.
Custom bench with storage underneath - very nicely done. Inside of bench. Counter top Johnny wanted to know about, it's covered, though. Sump pump is hidden, tv stand on top. Long wall. Paint and tile in bathroom. Ran out - damn it! Still working on some stuff, my cousin should start the drop ceiling today or Monday. Can't wait! Matthew |
Posted on: 2009/2/28 12:32
People who make improvements like that make those of us who aren't doing shit feel bad. That's just wrong. You should still be in the thinking about it stage........ dammit.
Posted on: 2009/2/28 13:32
Looking good!!!! I do have one question, how did you guys cut the tile in such a perfect circle around the toilet flange? I need to know as I will be doing this in a week or two. I love the look of that tile layout so much that me and the wife are going to copy that. We were going to do a straight normal grid but that layout really breaks free from that and looks AWESOME!!
Posted on: 2009/2/28 17:22
As for the toilet flange, you don't need a circle, the toilet will cover up all of it in front and back of the flange. Just try and get the flange about 1/4" above the tile, and make damn sure it's level in that area or the toilet may leak at the wax ring eventually. I pull the baseboards before putting tile down. |
Posted on: 2009/2/28 19:05
I might try something diagnonally, maybe with large tile. And surprisingly, you actually cut the same amount of tile this way. Yes, more edge pieces, but the other half of the cut get used. |
Posted on: 2009/2/28 19:09
Posted on: 2009/2/28 19:34
Thanks for the comments. We did the brick pattern for two reasons: one, it looks cool; two, it's actually easier because the grout lines don't have to be as exact as with the standard pattern. We did use spacers. Plus the tiles we used are "rough edges" so if you're off a little it hides it well.
I will be finishing up the tile setting myself later tonight. Grout in the next couple days. Maybe on Tuesday, my day off. As far as cutting around the toilet flange, we marked a semicircle on the tile and then cut it with a 4" diamond wheel attached to an angle grinder. Very easy to do. Makes a mess, but oh well. Part of the drop ceiling is up. I'll get pics when that's done. Matthew |
Posted on: 2009/2/28 23:00
Huh, I heard that works but I would think it would break the tile.
Posted on: 2009/2/28 23:09
Didn't break for me, although I did break a tile on the tile cutter. Such is life.
Matthew |
Posted on: 2009/2/28 23:13
I think I will do what I have done in the past since I dont want to buy another grinder which is just using the wet saw to slice it into shape and following it with tile nippers.
Posted on: 2009/2/28 23:20
Home depot's is, and they'll cut them for 50 cents each. And they usually don't care to enforce the policy that you have to buy the tiles there.. |
Posted on: 2009/3/1 1:08
happydad | Re: Basement Remodel (lotsa pics) | ||
That is Sweet,,,When your done you can help me and meet the wife
Posted on: 2009/3/1 3:00
86 Coupe,350 bored .040 over,Eagle Internals,Scorp RR.Crane Cam,Hedman Hedders,Holley Mani,TCI Trans,3:73 Rear, Demon Carb ,Hole in the hood Scooped and Lots of leaks(Horsepower) I forget :thumbleft: |
As long as the beer is cold, give me a call. Matthew |
Posted on: 2009/3/1 12:19
Posted on: 2009/3/5 21:00
Looks good man!!
Posted on: 2009/3/5 21:31
One of the best things I ever bought was one of those $88 wet saws. For goofy cuts like around the toilet base, I just free-hand them around the saw blade. |
Posted on: 2009/3/5 23:08
Yeah, wet saws are great, but I prefer the free kind, which is whatever my BIL brings over I realized, guys, that I forgot to post more recent pics that I promised. Took these about a week ago. Toilet/vanity installed - I have since put up the mirror and towel bars. Ceiling is in!!! We're looking at carpet options now. I'm thinking about going with carpet tiles, save the $$$ on installation, plus removable if they are damaged/get wet. Matthew |
Posted on: 2009/3/12 20:11
Well, welcome to my 98% done basement. Still have to paint the doors, paint the bench, paint trim in bathroom, finish caulking in bathroom, apply pole wrap, and a couple odds and ends. But here it is for the most part. Furniture arrangement isn't all done yet, but it's downstairs so we'll move it later.
Matthew |
Posted on: 2009/4/3 1:39
CSS996 | Re: Basement Remodel (lotsa pics) | ||
Mega Guru
Real nice!
Now when my wife kicks me out, I'll have a sofa to sleep on! |
Posted on: 2009/4/3 19:47
Currently "Between Vettes". |
Looks great. Is that where the pool table is staying? That pole is gonna screw up my shot.
Posted on: 2009/4/3 22:57
Everyone is welcome! We have a guest room upstairs, too
I originally wanted to keep the pool table there, but I don't know if it's gonna be roomy enough. It might get moved back to the long area in between the weights and the couch where it used to be. I still have to work it out. Matthew |
Posted on: 2009/4/3 23:06
Dads90 | Re: Basement Remodel (lotsa pics) | ||
Looks great, haven't commented until now. Been watching though. I know when I did ceramic tile in my home, I couldn't rest, that's all I thought about was getting it done. Nice work.
Posted on: 2009/4/4 4:21
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
wow, very nice! I like your weight room, lots of free weights and dumbbells!
Posted on: 2009/4/4 12:11
