150 user(s) are online (81 user(s) are browsing Forums)
BrianCunningham rebuildable front bearings!
Finally!
http://forums.corvetteforum.com/autoc ... rings.html#post1569177039
[QUOTE]Mojave;
This information is from an f-body forum (http://www.frrax.com ). These are designed for 4th gen f-bodies, but will fit C4's if the holes are drilled out or the bolts are installed the other direction.
These appear to be very well built, and hopefully the last set of hubs you'll ever buy. I'm just reposting this information here; I'm not involved with this business.
Any questions should be directed to Mike (contact info below).
MJM Racing is proud to present the first rebuildable, adjustable and regreasable front hub for 4th gen F-bodies. As most of you know already, these have been a long time coming and have gone though several interations and lots of testing over the last two years. If you've ever autocrossed with 315 Hoosier's or Kumho's, you know why these were developed.
Pictures can be seen here:
http://www.mjmracing.shutterfly.com/
Highlights:
1. New forged and hardened 4340 steel spindle made by Mark Williams Enterprises to MJM Racing, LLC specifications
2. Timken tapered roller bearings
3. Factory ABS retained
4. Original exterior dimensions retained for a "bolt on" application with no other modifications required.
5. Adjustable for bearing play, regreasable and rebuildable.
6. Comes with new ARP studs
We will begin to take orders on 1-1-09.
We need to get at least 20 pairs in the initial order to get the best pricing on machine work and parts. Please post any questions as well as stating your interest so a list can be compiled.
The initial price will be $650 each plus a core. That price will apply to this first initial offering only and these are only offered to the people of this site at this time. The core charge will be $100 per hub if you do not have any old ones you can send. Frankly, cores are necessary and if that ends up being too low of a core charge to get people to send cores, it will go up. Please be considerate and at least knock the big chunks of rust, dirt and grease off before you send them. If you have already sent cores to help with development your names are recorded and you need not send any additional cores (unless you want to).
Our lawyer has prepared a document that must be signed by each interested party prior to any transaction. A copy will be emailed to all who state they are interested in purchase.
Please post all questions here or call me, my PM folder is already a bit full.
Mike Minear
Managing Member
MJM Racing, LLC
303-710-9297[/QUOTE]
Posted on: 2009/3/5 18:20
CentralCoaster Re: rebuildable front bearings!
Very cool.
I would presume if they're provided a Corvette core, then you'll get a bearing back that will fit the Corvette.
Although somebody should check with them on that. I can't justify the cost at this point in time.
Posted on: 2009/3/5 18:48
Ok, the bearing shown on their website (aside from the threaded holes) will work on 84-85 and 91-96 Corvettes.
It will "fit" the 86-90 Corvette, but your ABS sensor is different, so I don't know if it will work with ABS.
Also, the 84-85 Corvette bearing was superceded by the 86-90 bearing. Most 84-85 owners with replacement front bearings, and all 86-90 owners will have a bearing that they may or may not be capable of modifying.
But somebody should ask and point them to this thread:
Here's the backside of the 86-90 vette bearing:
Here's the backside of the original 84-85 vette bearing:
Here's the backside of the 91-96 vette bearing:
(Those big holes in the wheel flange are for removing the knuckle bolts.)
Posted on: 2009/3/5 19:14
BrianCunningham Re: rebuildable front bearings!
Done, though I don't know how long before it's deleted.
Posted on: 2009/3/5 19:33
jhammons01 Re: rebuildable front bearings!
Youwza!! 650 each....
Posted on: 2009/3/5 19:37
jaa1992 Re: rebuildable front bearings!
Stone Mtn, GA (near Atlanta)
187 Posts
Yea, but they pay for themselves after the third time you rebuild them. Its still not in my budget for a looonnnnggg time.
Posted on: 2009/3/5 19:52
I hate bothering the guy if I'm not even buying a set, but some Corvette owners will, so I'm just spilling the beans for them.
Brian, you've had these hubs apart right? Which type unit did you dissasemble? I presume the internals are the same.
Posted on: 2009/3/5 20:12
I took a rear apart, but the front should be about the same.
Photobucket
Photobucket
Posted on: 2009/3/5 20:20
What is so special about these hubs that make them un-rebuild able?
It seems that we may have to break something to get them apart...but we should find a replacement part to take that place...
The Tensioner on the serpentine belt is not supposed to be rebuild able either....$58 for a replacement tensioner or $11 for a Bearing at NAPA.
Can you tell I'm cheap?
Posted on: 2009/3/5 20:24
The races are plastic, (see the mess above) so they break apart when you take them apart, and are real hard to put together unless you have a special tool
Posted on: 2009/3/5 21:35
You mean the cages?
Posted on: 2009/3/5 21:56
Cages are the finger things that space the Balls apart
The Race is the surface that the Balls role around on.
Plastic Races...no
Plastic cages...we could get a bearing house to give us bearings..........You can special order bearings in "half" sizes to take up slop from worn races.
I'm just throwing what I've seen in life......for the sake of discussion. There comes a time when parts are no longer available for certain cars
Posted on: 2009/3/6 0:20
yes, cages
Posted on: 2009/3/6 1:37
So what parts get consumed in the wheel bearings? Do you guys think that the Bearings are worn down over time? or what?
Posted on: 2009/3/6 16:36
There's a few things going on.
1st the bearings are too close together.
2nd they are ball bearings not roller
Which is great for rolling resistance, but not good at all for wear
But the 1st two wouldn't be an issue if you could change the grease, which you can't.
When you take them to the track the bearings heat up and outgas, f@rt, when the cool down the suck air in, pulling contaminants with them.
GT cars change the grease and seals every event.
If we could do that, which these bearings allow, we'd be all set.
Posted on: 2009/3/6 17:12
Did you destroy things when you took them apart? Besides the Cages what about snap rings?
I getting at this.......If they can be converted into being rebuild able someone could make a dime or two
Posted on: 2009/3/6 18:54
The snap rings are fine, it's just a matter of finding a new bearing with metal cage that will fit, or alter the housing so they fit, which is what those guys did.
BTW they chimed in on the other forum:
MJM Racing LLC
Junior Member
My Corvette Photos
Default
I'd be happy to answer any questions you guys have. Feel free to call me.
In looking at the photos above of the older versions, I don't think mine will work with the ABS on the 86-90 and may not work for the 84-85 either.
I have a few questions for you guys. Will the 91-96 hub bolt up with the plastic ABS sensor cap in place? Is the reluctor ring on the 86-90 version exposed behind the upright? What about the 84-85, can the back of the bub be seen from the back of the upright?
The reason I ask is that the plastic cap is also the grease seal on that end of the hub. Unless the back of the hub is concealed by a pocket in the upright, the cap must remain.
Posted on: 2009/3/6 21:19
I think I mounted 91-96 front bearings on my 85 and the abs all fit within the knuckle. Either that or I just removed the ABS cap. The knuckle hole is enclosed on mine anyways.
So yes, they should fit 84-85 without issue. But he's answering the wrong question. The question is, can he rebuild those earlier bearings using those as a core? Obviously he's not going to use Corvette cores for a Camaro owner.
Posted on: 2009/3/9 15:25
Invite him over to the forum.
Posted on: 2009/3/9 23:43
So we can kick his tires? Anybody here serious about purchase?
Posted on: 2009/3/10 2:54
Yeah, me
and anyone else that's serious about track days.
If they work out, they'll actually SAVE you a lot of money.
Posted on: 2009/3/10 3:30
Steve40th Re: rebuildable front bearings!
1114 Posts
I just checked my bearings on the rear, for example and they are ready to be replaced. The front more than likely also due to 100000 miles since last change. They were AC Delco up front, and BAE? for the rears. I have to say, its amazing the bearings cant be taken apart, as someone out there has to have a tool to do it. Someone.
I have a machinist here that would love to attack one of these. Anyone have an old one willing to ship to Hawaii?
Posted on: 2009/3/11 2:32
Ko'u ohana aia ku'a ikaika
The forums about to receive some feedback.
One of my front bearings is starting to sing.
So I'm going to go ahead and pull the trigger.
Posted on: 2009/5/6 21:25
anesthes Re: rebuildable front bearings!
Boston, MA
So after 30 years, they have paid for themselves ?
Good.
-- Joe
Posted on: 2009/5/7 15:50
You don't track your car do you
Posted on: 2009/5/7 15:58
Boston, MA
You mean the parking lot stuff guys do with the cones? Nope.
Always built 1/4 mile cars. Does EVOC count?
I know some guys that do the SCCA stuff, but they don't use corvettes. Considering the turning radius on a C4 is 34 feet I can imagine why not.
-- Joe
Posted on: 2009/5/7 16:15
You don't get to the track much then.
Plenty of guys in Corvettes doing autox, HPDE's and wheel to wheel.
Posted on: 2009/5/7 19:39
Jeffvette Re: rebuildable front bearings!
Most people don't have the balls, or the wallet to do it.
Posted on: 2009/5/7 20:52
Aardwolf Re: rebuildable front bearings!
Fremont, WI
209 Posts
I've got an '88 rear that I changed out. Any idea the shipping cost?
I still use street tires and the bearings hold up well. For time trials you take points for stickier tires plus having more maintenance has held me back from going to race compounds.
Posted on: 2009/5/7 20:59
I'll post up the shipping cost, I've also ordered extra seals & bearings so I can repack it after an event.
No rears yet, but if you saved the old one he interested in looking into it.
Posted on: 2009/5/7 22:58
1114 Posts
It shouldnt be more than a couple burgers, If you are bored, and take paypal, let me know. PM when/if you want to send it, and I will giv eyou my address.
Posted on: 2009/5/8 4:48
BillH Re: rebuildable front bearings!
And multiple VISA cards maxed out. :shaking:
Posted on: 2009/5/8 13:40
Matatk Re: rebuildable front bearings!
22813 Posts
I've still got the two rear bearings from my recent swap if you need more to test. One appears to be eaten up pretty good, the other is in better shape.
Posted on: 2009/5/8 15:57
Got y order last night.
Looks nice complete with 3 set of bearings and seals
Posted on: 2009/6/23 15:16
SpectatorRacing Re: rebuildable front bearings!
The price point is still too high at $650. I've come to terms with rear bearings being a wear item, like brakes and tires. I replace about 2 per season. I found a source that sells cheap-o's for $50 each. So that's 13 bearings before they pay for themselves. And there still isn't a rebuildable rear that I know of.
Fronts last a couple of seasons...in fact, I've only replaced my fronts twice in 10 years. Of course only the last 5 were serious track use.
In other words, the concept is sound, the cost is not justifiable. I'm guessing it's just as much work to take them off for a rebuild, so where is my savings?
Posted on: 2009/6/23 15:44
If you repack them, you may not have to rebuild them at all
Where are you getting rear bearings for $50?
Posted on: 2009/6/23 15:58
I bet you'd get more out of them if they had some easy miles on them before you started abusing them.
I put maybe 15K on mine before they saw their first track day. I don't run the car much, but I'm expecting these tapered rollers to last awhile.
Posted on: 2009/6/23 17:56
I'm having trouble visualizing how you'd repack them. Would this be possible while the hub is still on the car? If so, you're on to something.
I get the cheap ones from some ebay store, I think it's MAC auto or something, in New York. I'll have to check my receipts at home if you really want to know. Matt (mrc24x) found them and passed the info along. I use the older C4 style as I don't have ABS anymore, but I think the 92+ style are still only $65. I just buy 4 at a time, they usually do shipping deals, like pay for one the second one's free.
Posted on: 2009/6/23 18:23
It's certainly possible that they'd last longer, I've read that before. Unfortunately it's not an option, the car is clearly not street legal so I'd have to do my break in at the track. At $2000 a weekend for a few hours of track time I'd rather bring some extra bearings than tool around at break-in speeds ;)
Posted on: 2009/6/23 18:31
I'll have to see when I put them on.
But I think I'll be able to pop the ABS sensor cover with it on the car.
In that case I can change the grease real easy.
Posted on: 2009/6/23 18:35
I got a response
[QUOTE]MJM Racing LLC
Brian,
I read through that post and I appreciate the support. I'm not sure there is much I can add. But I think your idea of trying to regrease on the car is a bit too optimistic. Even if you can get the ABS cap off while still on the car, you would still need to remove the brakes and rotor to get the spindle/flange out of the housing. At that point, it's only 4 more bolts and the ABS plug to remove the whole thing. Also, they go together a bit tighter than you may think. They don't just fall apart when the spindle nut is removed.
Now if you can get the ABS cap off while it's in place, you should be able to adjust out any play without removing it. This can not be done on an F-body.
You may also be overly conservative on how often they need to be greased. For track use, I recommend regreasing before each race weekend just to be safe. For street and autox, every 4-6 events or every other oil change is probably more than enough.
The only downfall to a maintainable hub... is that you have to maintain it.
PS, I'd be happy to take a look at the C4 rear bearings if some one has an old one they want to get rid of, C5/6 fronts as well. Although I thought there were aftermarket upgrades available for both already. You are welcome to post my number 303-710-9297 if anyone wants to contact me.
Thanks,
Mike[/QUOTE]
Posted on: 2009/6/23 19:34
Well, just to be a prick, I can get to the track in 35 minutes and I get all the free testdays I want. :binky:
Posted on: 2009/6/23 20:46
yeah, but I can't fit my car in my pocket, and having an extra burger for lunch doesn't slow it down by destroying the pwr/wt ratio!
Posted on: 2009/6/23 21:25
Ha, all too true but, fast is fast.
Posted on: 2009/6/23 22:46
It's easy really, you buy my "broken in" bearings for $100 each and send me 2 new ones.
Posted on: 2009/6/24 2:25
Deal of the century! CC would probably scrub in your new A6s too.
Posted on: 2009/6/24 13:54
That's actually not as ridiculous as it sounds...but probably a lot more work for you. I change them all the time, anyway. And a few street miles aren't going to reduce their life any for my purposes.
BTW, I just received a timely email from the store with the cheap bearings. Here's thier info for anyone interested:
315 Boston Post Road • Port Chester, NY 10573
(800) 209-9598
www.MACAUTOPARTS.NET
More importantly, they sent me a $10 off coupon code for my next order. So make that $40 each for rear bearings...
Posted on: 2009/6/29 8:43
I got the bearing installed this weekend.
He uses the Firebird housings, so it's tapped for a bolt, as opposed to clear drilled like the Corvette bearings
No problem I just put the stock bolts in from behind.
Man I didn't realize how shot my front bearing was until I replace it!
The steering is nice and tight now.
Posted on: 2009/6/29 13:15
(800) 209-9598
DAMN!! I don't see the front ones...does he carry fronts?
Posted on: 2009/6/30 6:25
I have purchased fronts from there last year. Give them a call. I assume they still do, but I guess anything's possible.
Did you look on ebay? We originally saw them on ebay.
Posted on: 2009/6/30 17:44
