209 user(s) are online (174 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
RIISITAS C4 Brake Rotors
Las Vegas
46 Posts
I've decided to do a brake job on my 96 C4 with 53K miles this week. This is the first time I've done a brake job in quite awhile. I bought OEM pads for the job. One question... Can the brake rotors on a C4 front and rear be turned/refinished? It looks like my front left rotor definitely needs to be turned or replaced. I can see a slight gouge on the inside of the rotor surface. This is the first brake job this C4 has ever had. Any suggestions/tips to go along with this task would be appreciated.
Posted on: 2009/6/17 13:27
BillH Re: C4 Brake Rotors
Yes, rotors can be refinished in they meet the min. thickness when done. Replacement rotors are not that costly.
Here are the 92 specs, should be similar.
Std rotors: thickness - 20.2mm, 18.9 mm after refinish, 18.4mm-discard.
Thickness variation - 0.013mm, runout - 0.15mm
HD rotors: thickness - 28.8mm, 26.9mm, 26.5mm
Same runout as above.
If it was me I'd take the OEM pads back and get a set of Hawk HPS pads, big difference in performance.
I'd also change the fluid, flush the system.
Posted on: 2009/6/17 13:59
TommyT-Bone Re: C4 Brake Rotors
33798 Posts
Posted on: 2009/6/17 14:07
volzfan Re: C4 Brake Rotors
Kingsport, TN
306 Posts
:goodpost:
The Hawk pads were one of the smartest moves I made on my C4. There is a big difference!
Posted on: 2009/6/17 14:49
Vettes of the Smokies
BrianCunningham Re: C4 Brake Rotors
The stock pads are clean, but they don't stop for a hill of beans.
Posted on: 2009/6/17 15:06
pianoguy Re: C4 Brake Rotors
Another vote for the Hawk pads - follow their bedding instructions (real easy). I'd also install some speed bleeders, makes the job easy - Earl's Solo Bleed looks like an improvement over the original Speed Bleeders.
Posted on: 2009/6/17 15:23
CentralCoaster Re: C4 Brake Rotors
8 bucks each to get rotors turned at Pep Boys.
Turn them if the rotors are grooved. A gouge isn't a big deal unless it resulted in metal sticking above the rotor surface.
Posted on: 2009/6/17 19:01
vetteoz Re: C4 Brake Rotors
Full set of OEM factory rotors including 13" fronts $80
http://www.corvetterecycling.com/C4_C ... nt_12_Rear_p/rotorset.htm
Posted on: 2009/6/18 5:17
bogus Re: C4 Brake Rotors
NAPA sells OEM rotors, made in USA or Canada. I worry about Chinese castings... cheap, yes, quality, so-so.
I would also do the Hawk pads. They rock.
Posted on: 2009/6/18 6:06
mseven Re: C4 Brake Rotors
Motor City Madhouse
247 Posts
The hawk pads were worth the money and are every bit as good as everyone here has stated. The best bang for rotors is corvette reclycling. They are original OEM's in the delco boxes for 20.ea.
Posted on: 2009/6/18 9:27
klkordzi Re: C4 Brake Rotors
Pittsburgh, Penna
152 Posts
I will be doing the C5 conversion on my 85 soon and was wondering if the set with 13in front rotors would work with the C5 calipers? Anyone know?
Posted on: 2009/6/18 10:27
Matatk Re: C4 Brake Rotors
22810 Posts
You need c5 rotors. They are also pretty inexpensive.
Posted on: 2009/6/18 11:46
RIISITAS Re: C4 Brake Rotors
Las Vegas
46 Posts
Thanks for all of the great advice! I'll try the Hawk paos. Nice tip on the Corvette Recycling rotors. Great price!
Posted on: 2009/6/18 12:37
SpectatorRacing Re: C4 Brake Rotors
$17 apiece at NAPA, baby!
Posted on: 2009/6/18 13:11
You don't need C5 rotors, and getting the calipers and adapters costs money and time.
And again, I don't know where this secret Napa store is, around here C5 rotors cost about $45 each plus tax.
Posted on: 2009/6/18 17:37
So the Wilwood kit can use standard C4 rotors?
Posted on: 2009/6/18 18:03
Dunno. I have a C5 Wilwood kit and the offset and diameter are both different from stock C5 brakes.
They could've easily designed it the same, but then I guess Wilwood couldn't sell as many rotors.
I had my stock rear brakes turned at Pep Girls.
Posted on: 2009/6/18 18:06
22810 Posts
How do you figure? If he's doing the c5 conversion he needs c5 rotors.
Posted on: 2009/6/18 22:33
Oh, I didn't see the threadnapper's post, yeah he needs C5 rotors. I thought you guys were pushing it on the OP.
Posted on: 2009/6/19 21:00
22810 Posts
threadnapper
I wasn't pushing the c5 upgrade on the OP. But since you mentioned it, it's the best upgrade I've done on my car. And for the $300 I spent on it, it was well worth it.
Posted on: 2009/6/20 1:28
