| jsup | Gaguge Piller Installation | ||
I'm working with Greg from Blower Works, who, BTW is absolutely amazing. He knows these C4s inside out. He actually made a tester, I have to get a pic of it, that he has in his shop to test the chips. It's a 90-91 setup, just my luck.
Anyway, I have it on good authority he's a phenomenal tuner. Anyway, he would like to see a fuel pressure gauge in the car. So I figure, I'll put in a trans temp gauge too. I was thinking about one of those A piller mounts, I really don't like them, but can't think of a neater install. He's going to teach me the ropes of tuning as he does mine, and suggests that the FP guage is a requirement. Comments, suggestions? |
Posted on: 2008/9/18 1:27
Transfer
| Matatk | Re: Gaguge Piller Installation | ||
Can you run a FP gauge in the car? I thought for that you actually had to have a line coming off the schrader valve? At least that's how I test the FP in my car. Most guys say tape it to the windshield while driving to see it. Obviously that is not a permanent solution, but I don't know if you can do it otherwise. Is there some kind of gauge that has a remote sending unit (like two gauges) to safely run it into the car?
Matthew |
Posted on: 2008/9/18 1:36
Transfer
| jsup | Re: Gaguge Piller Installation | ||
The electric sending unit goes on the valve.
Posted on: 2008/9/18 1:43
Transfer
| Mekanic | Re: Gaguge Piller Installation | ||
was about to say that haha. |
Posted on: 2008/9/18 1:48
Transfer
| NC Kid | Re: Gaguge Piller Installation | ||
I was going to install an A pillar gauge awhile back but never did it. A electronic gauge is a must so if the line did break, gas would not go everywhere.
Posted on: 2008/9/18 1:54
Transfer
| BrianCunningham | Re: Gaguge Piller Installation | ||
I want to do the A-pillar guage as well.
Fuel & boost in my case. |
Posted on: 2008/9/18 2:38
Transfer
Got any links for what you guys would use for fuel pressure. I found another one for air ratio mixture...
Posted on: 2008/9/18 2:41
Transfer
| Andrew | Re: Gaguge Piller Installation | ||
The pillar gages work well and really don't stick out that bad when driving. It is nice to keep an eye on things.
Here is a picture of what it will look like. Also, the picture of the motor, the sending unit is right behind were the fuel lines are. Look for the module that has the red wires running to it. [IMG]http://i229.photobucket.com/albums/ee251/awheel73_photo/1996%20Yellow%20LT4%20Corvette/1996%20Yellow%20LT4%20383/FuelPressureandNOS.jpg[/IMG] [IMG]http://i229.photobucket.com/albums/ee251/awheel73_photo/1996%20Yellow%20LT4%20Corvette/1996%20Yellow%20LT4%20383/MotorDriversSIde.jpg[/IMG] |
Posted on: 2008/9/18 2:55
2003 Atomic Orange Z06 Sold - 1996 Competition Yellow LT4 - DRM 383, NX N2O, Line Lock, LT Headers, 3" stainless exhaust, Power Effects, and many more mods SOLD 1996 Competition Yellow LT4 SOLD 1979 4 Speed with 383 |
Transfer
Oh, almost forgot. What is Greg's contact information and how much does it cost for him to send you a tune? I'm thinking really hard about adding some 36 lb injectors and will need a good tune.
Posted on: 2008/9/18 2:57
Transfer
| c4-zo7-91 | Re: Gaguge Piller Installation | ||
hi guys,
sorry for butting in on your thread but i was just wandering how much are the electrical fuel preasure guages ?? and where and what brand is the cheapest to buy ?? iv seen them sell for around $ 200,thats alot of money. any ideas guys please ?? cheers glen |
Posted on: 2008/9/18 10:10
Transfer
I doubt Greg would have the maps needed for your build since he specializes in blower cars.
Did you have a chance to call Xtreme? Or possibly find a reputable dyno tuning shop in your area? |
Posted on: 2008/9/18 10:40
Transfer
| anesthes | Re: Gaguge Piller Installation | ||
Called an ECM bench. Used to test calibrations in house before playing with the car. Helpful to figure out why code does things when certain inputs hit thresholds. Thats how we discovered things like the MAX ve issues with $8D on injector pw. Quote:
He is. Quote:
My fuel pressure gauge is in my engine bay. The only reason I'd ever need to see it is if I suspected an injector or fuel pump fault. I set my fuel pressure to 50psi at baro. I expect a 1:1 rise with boost. You are N/A.. I'd set your fuel pressure to be about the same but you have a few other issues to combat. 1) Injector size 2) Max VE $8D shows BPW in the datalog, not final injector PW. My code is patched to display actual final PW, so I'll dial my idle in to get the injectors to fire a reasonable PW so I can get away with higher fuel pressure (for better atomization). Plus, I can run a smaller injector which is really my main goal. I also have code mods to my bin that runs open loop until 1400RPM, and I've altered my 02 swing points for open-tps closed loop operation so the corrections are closer to my desired AFR. Your combo I imagine is harder to tune than mine.. -- Joe |
Posted on: 2008/9/18 11:02
Transfer
Cool. Learn something new every day. Matthew |
Posted on: 2008/9/18 11:24
Transfer
greg@blowerworks.net |
Posted on: 2008/9/18 12:12
Transfer
anesthes wrote:
It's about three feet by two feet, and has all kinds of knobs, displays, and dials. On the other side of the shop he has fuel pumps and all kinds of plumbing. I have to get pictures when I go back tomorrow. According to him he "invented" the PW hack and is pretty protective of his methods. I have to sign a non disclosure that I won't let anyone else read his chip. Glad to hear he's a good tuner. He really seems to get it. Quote:
He's offered to give me lessons on tuning until I get it. He says having the gauge in the car will make it a lot easier. I will take him up on it, should be fun. |
Posted on: 2008/9/18 12:18
Transfer
Which PW hack? Quote:
Any time you can get someone to show you how to do something is much better than just doing it for you. I've had a few conversations with him and he's a nice guy that knows his stuff. The NDA thing doesn't really sit well with me but in the last few years a lot of 'tuners' have been ditching the DIY scene to make a profit, stabbing each other in the back, etc so I can't say I blame him. -- Joe |
Posted on: 2008/9/18 13:19
Transfer
| Lichen | Re: Gaguge Piller Installation | ||
Trans. temp gauge on pillar. I've since attached it with double-sided tape.
Attach file: pillar1.jpg (55.17 KB)![]() |
Posted on: 2008/9/18 14:14
Transfer
| bogus | Re: Gaguge Piller Installation | ||
have you checked with www.summitracing.com? I am sure they would export. |
Posted on: 2008/9/18 14:32
Transfer
| BillH | Re: Gaguge Piller Installation | ||
Electric's the way to go but, some racecars use the mechanical gauge with a gauge isolator installed before routing to the cockpit (definately more expensive). |
Posted on: 2008/9/18 15:08
Transfer
| JonnyAngle | Re: Gaguge Piller Installation | ||
Check ebay or www.glowshiftdirect.com |
Posted on: 2008/9/18 16:22
Transfer
Thanks! http://www.glowshiftdirect.com/84-96- ... ette-dual-pillar-pod.aspx ![]() |
Posted on: 2008/9/18 19:21
Transfer
yep thanks johnny angle for the link.
also i found a electric fuel preasure guage made by stewart warner for $ 79.95. # 587-114218 it is a 0-100 psi guage with sender unit. it measures 2/1/16" www.miaspeedshop.com, its quite a nice cheap good looking guage. cheers glen |
Posted on: 2008/9/19 9:57
Transfer
guys who have these...how's the fit and finish in real life. I have searched high and low for a full pillar, but none seems to exist, these over lays seem to be the only option.
Posted on: 2008/9/19 14:21
Transfer
They make the full pillar for the fbody, but not corvette. They look ok. I drilled and screwed mine for better appearance. I didn't like the stupid little push inserts that came with them. -- Joe |
Posted on: 2008/9/19 16:01
Transfer
what gauges are you putting there?
I'm thinking boost/vacuum as oppose to just boost, and a fuel pressure guage. |
Posted on: 2008/9/19 18:17
Transfer
i know i will be fitting a air/fuel ratio and a electronic fuel preasure guage in my dual pod but i have to find a right hand side pillar pod ,not left hand side though.
btw guys,what did you think of the stewart warner fuel preasure guage ???? cheers glen |
Posted on: 2008/9/19 19:30
Transfer
I've had a voltmeter, bt now I"m fp all the way!
Posted on: 2008/9/19 20:50
Transfer
| MK 82 | Re: Gaguge Piller Installation | ||
I think a wideband O2 would be useful too.
Posted on: 2008/9/19 22:01
96 CE Roadster LT4 |
Transfer
hi andrew, is your picture shown above the glow shift guage pod brand as in the link on page 2 from glow shift direct.com?? thanks glen |
Posted on: 2008/9/20 10:57
Transfer
| djxib | Re: Gaguge Piller Installation | ||
For what its worth I tried to get gauges that look as close to the stock gauges as possible - I painted the gauge bezels black too. Apologies for the poor photo! And this was the combination that Greg suggested - it is easy when tuning to instantly see boost and fuel pressure. The boost/vacuum is just 'T'-ed into intake vacuum piping (actually I have the 2-stage alky controller under the dash that is boost controlled, so T was easy there). The FP is via an electrical sending unit on the fuel rail.
Posted on: 2008/9/20 12:01
Transfer
| biggrizzly | Re: Gaguge Piller Installation | ||
You guys are just too fancy!!!
Stick 'em up there on the dash like we did in the old days. Or you can get them little chrome surrounds that screw under the dash!!! ![]() |
Posted on: 2008/9/20 13:25
Transfer
Glen, it is not the same pod. It is exactly the same design, but the finish on mine is smooth / gloss black look and the glow shift pod looks like a matted surface.
I think the glow shift pod matches the interior and looks better! By the way, $79 for the FP gauge is a steal!! |
Posted on: 2008/9/21 1:00
Transfer
I remember those.....problem is there's no dash to screw them under anymore. |
Posted on: 2008/9/21 1:44
Transfer
I was just havin' some fun! |
Posted on: 2008/9/21 2:18
Transfer
Transfer
