Browsing this Thread:
2 Anonymous Users
bogus | Guess what I broke? | ||
You won't believe me when I tell ya...
Driving down the 110 freeway on my home from work, cruising at a nice 75 mph... I hear a THUD... then I smell nasty burning shit... then I see sparks... Then I merge to the center median pull off... All of that happened in about 10 seconds. I get out... check the right rear tire... nope, not flat. I double check the left rear tire... nope, not flat... I peak under the rear suspension only to find that the rear transverse leaf spring has BROKEN. Sheared right clean off at the end... 3" to 5" not there no mo... Fun, eh? Finally got home about 8:45... lost three hours to this shit... damnit... not how I had planned on spending a quite Tuesday nite at home. sigh... |
Posted on: 2014/2/26 5:25
BillH | Re: Guess what I broke? | ||
That sucks Andy.
But at least the broken spring didn't put you into the concrete highway divider. And if it didn't crack the fender, you're probably lucky. Repair & drive. |
Posted on: 2014/2/26 5:37
Matatk | Re: Guess what I broke? | ||
I've heard of it happening before. Sucks that it happened to you. Good luck and hope you repair it quickly!
Posted on: 2014/2/26 12:37
BrianCunningham | Re: Guess what I broke? | ||
did you hit anything?
Time for coilovers? |
Posted on: 2014/2/26 12:53
TommyT-Bone | Re: Guess what I broke? | ||
The cloud that hangs over you will soon pass. Bad things usually happen in threes. What's this?. Number 11? |
Posted on: 2014/2/26 12:59
teebee | Re: Guess what I broke? | ||
Back in the 70's when I had my 64 coupe, I was driving down the road and the same thing happened to me. Only difference is that the spring didn't break, but the head of the bolt that holds the spring had worn clear through the washer and pulled through and released that end of the spring. I had the same reaction as you did. It was not fun trying to fix that on the side of the road in the dark.
Look at the bright side, it could have been worse Andy. |
Posted on: 2014/2/26 13:07
2007 Atomic Orange 3LT coupe. Borla Exhaust One of Americas' proud Deplorable |
Durango_Boy | Re: Guess what I broke? | ||
Aren't those fiberglass? |
Posted on: 2014/2/26 15:49
bogus | Re: Guess what I broke? | ||
No, hit nothing... and remarkably, never lost control. It just dropped.
I called Vette2Vette and he doesn't think he has any springs! Most are going as complete rear suspension sets. I have thought of coil overs, but I don't think I can afford them at this time... And yes, they are composite. the funny thing? The bolt is still there... so is the nut, just no bushing and no spring perch... |
Posted on: 2014/2/26 16:00
I still have my base springs
you have an aftermarket exhaust I've heard those can weaken and make the springs fail |
Posted on: 2014/2/26 16:17
joeld | Re: Guess what I broke? | ||
Good to hear no other damage to the car or you!
So, this is the "shudder" in reverse problem you had? Joel |
Posted on: 2014/2/26 16:22
1989 Coupe,L98 automatic |
I don't know... but good question... I did brakes a few weeks back, and didn't see anything out of sorts there...
Posted on: 2014/2/26 16:25
I think vbp sells new springs?
Posted on: 2014/2/26 18:39
Ultraman | Re: Guess what I broke? | ||
One night years ago I was following an early C3 in my pickup and we went over some rough railroad tracks and something let go in his rear suspension and it seems to me it was the rear transverse spring and the end hit the pavement and the sparks that flew were like a 4th of July rocket taking off. I stopped to help but the right side of that spring was on the ground.....he got it off the road and I took him to a truck stop so he could call a wrecker...
You may be famous Andy....Wikipedia says no composite Corvette leaf spring has ever failed..... |
Posted on: 2014/2/26 20:00
Thank the engineer that put the bump stop on the car
Posted on: 2014/2/26 20:45
Corsa... and think about it... the FAR OUTSIDE end failed, not the middle. If it had failed at the middle, sure, but 2' away? that theory is baseless, if you want my opinion. Are you interested in selling the rear spring? I have the brackets I think... waiting on confirmation. But tonight, I want to take 5 and check the batwing. If the standoffs for the brackets are screwed, so am I. |
Posted on: 2014/2/26 20:46
I was thinking the same thing... This gave way at the very end... not the middle... this is where stress is at its highest. I swear... I wish I could swing coil overs... that would solve sooo many ills right now. |
Posted on: 2014/2/26 20:47
I should still have everything
I'll sell them to you if you need them |
Posted on: 2014/2/26 21:21
I am going to check the diff tonight... I don't want any damage on the batwing, if so, I am boned...
Posted on: 2014/2/26 22:11
I wouldn't much worry about the batwing as the upright and the the halfshaft
Posted on: 2014/2/26 22:17
the half shaft and upright seem ok at this time.
I am heading home soon, I should know more later. |
Posted on: 2014/2/27 1:18
Wikipedia is full of chit. Used springs are under $200 on ebay but I wouldn't. 2 week delivery from Zip on a new Hyperco, Z51 $430 |
Posted on: 2014/2/27 15:17
I think I know what failed...
I had the poly spring bushings from Ecklers on there... the rubber ones were pretty ugly. I think that the poly broke up under tension, leading to the only thing holding the spring on being a thin washer... over time, the washer caved and the spring sprung. It is the only thing that makes any sense. |
Posted on: 2014/2/27 17:20
LD85 | Re: Guess what I broke? | ||
yes,, this ^^^^^^ |
Posted on: 2014/2/27 19:37
2005/Z51 |
NelsonV | Re: Guess what I broke? | ||
Andy- Did you get a chance to call Mark Savitske? If we're close enough with that "other idea" I mentioned last night, $200-$450 for a new or used leaf might end up wasted if it's just a short term fix. I'm not in a huge hurry to get my ride back - I do want it back though, with leaf springs intact ;) NV |
Posted on: 2014/2/27 20:54
I am planning on calling him later today... as in lunch!
I did some prelims and I think it might work... the math so far is working.... I need some more numbers. |
Posted on: 2014/2/27 21:20
Methinks the biggest issue is whether the shock bodies are close enough in dimensions and mount style. The springs are cheap enough to replace if spring-rates aren't correct. Most of the cost is in the shocks (which are double-adjustable anyway) and the machined parts. |
Posted on: 2014/2/28 2:48
that's what I am hoping to learn.
I sent an email to get the ball rolling. I will try to call tomorrow. |
Posted on: 2014/2/28 3:21
Like I said before. Vette Brakes and Products sells new springs for $350-$400. |
Posted on: 2014/2/28 15:18
I guess no one has read my theory...
I don't think the spring failed, I think the bushing did. It's the only thing that makes sense... the bushing lets go, he weight is no on the washer, the washer is thin and can't take it, it gets crushed, spring comes crashing down. I am reaching out to Ecklers to alert them of this situation. |
Posted on: 2014/2/28 17:12
Andy,
You know you can post FB photos here right? |
Posted on: 2014/3/4 2:30
Yea... just forgot to update here... thanks for moving them over, tho.
the first pic is of the brackets that hold the spring. As you can see, the brace has been sheared! pic 2 is of the spring, or what's left... And pic 3 is of my suspension complete and pre-banski. The lower bushing on the spring is what failed. the numbers are way too small. |
Posted on: 2014/3/4 3:24
corvetteronw | Re: Guess what I broke? | ||
Any solutions yet?
Posted on: 2014/3/4 19:41
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
SpectatorRacing | Re: Guess what I broke? | ||
Crazy.
I might be parting out the C4...some nice coilovers on her Although I am quite certain you don't want anything that stiff. (TWSS) |
Posted on: 2014/3/4 19:52
aka Scaryfast |
hey... coil overs are coil overs...
Posted on: 2014/3/4 22:17
That's the way to go, all sorted out for you.
The actual springs are cheap if you don't like the rates recently replaced mine |
Posted on: 2014/3/5 2:27
yea, springs are cheap...
might have found a deal and a half on a conventional transverse leaf... will keep the world updated. |
Posted on: 2014/3/5 15:11
I got a deal on a spring and bolt package. Whew... Ordered up Energy Suspension bushings... in for under $200 total!!!
Exciting. Parts should be waiting for me when get back from FL next week. I also bumped the battery and started it up, moving it into a place where I can take the thing apart... finally. Reassembly won't take more than 90 minutes or so. |
Posted on: 2014/3/9 3:04
That's good news! Sounds like a deal on the parts.
I'm still curious if this helps that shudder. Joel |
Posted on: 2014/3/9 4:01
I doubt it... I think the shudder is aging in the diff. I talked to a friend who does diff rebuilds, and he said as the gears age, they, essentially, get used to going in one direction, top that off with clutch wear and bearing wear, a shudder isn't impossible.
Posted on: 2014/3/9 6:23
Glad to hear
Looking forward to the update |
Posted on: 2014/3/9 18:48
Sounds like a good deal.
Posted on: 2014/3/9 19:46
jonszr1 | Re: Guess what I broke? | ||
you talking about the rear end jogged my memory about what happened to mine the diferental shaft had started to wobble in its hole . that caused a vibration to my car . it was years ago and c.r.s. has set in till you mentioning the rear end caused my memory to activate.lol
Posted on: 2014/3/10 2:47
I will inspect the rear end thoroughly when I get the thing apart.
I took the nut off the left side, but the spring is so wedged in there, I am concerned about it unloading... I am kinda hoping that with the nut off, it will come undone on its own. no harm done... at least not to me! I won't be able to work on it for a week or so. |
Posted on: 2014/3/10 14:08
ugg
if it was a coil I'd run a safety chain best you can do is put a jack under it |
Posted on: 2014/3/11 19:31
yea, that's gonna be my plan. I will have to get the back end up, which is real easy with my floor jack and go from there.
I hope this doesn't hurt the shocks any... I know they come compressed, so this shouldn't be bad. |
Posted on: 2014/3/12 1:26
Update...
Plan B worked... I had to move the Vette into the garage... so the broken part is still on the ground... The pavement was enough to unload the bolt and the spring fell off! Done! |
Posted on: 2014/3/13 5:16
Now you have to get the new one back on!
Posted on: 2014/3/13 11:44
Cool, glad it worked out.
Posted on: 2014/3/13 15:10
CentralCoaster | Re: Guess what I broke? | ||
Make sure you put the bottom washer on this time. ;)
Posted on: 2014/3/16 6:02
smart ass....
Posted on: 2014/3/16 12:44
