203 user(s) are online (152 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
mojo92 what engine oil do you use ?
Tifton,Ga.
58 Posts
I put Mobil 1 10w 30 in and I was woundering if that is a good oil.
Posted on: 2008/3/30 20:41
bastet44 Re: what engine oil do you use ?
1389 Posts
We use Mobil 1. 10w30 (green) in the Jeep, and 5w30 (blue) in the Vettes.
Posted on: 2008/3/30 20:53
captmike13 Re: what engine oil do you use ?
Hillsboro Mo
2166 Posts
Just put some amsoil in mine.
Posted on: 2008/3/30 20:58
13 GMC 3500 dually
captmike13@yahoo.com
bogus Re: what engine oil do you use ?
If you live in a real cold climate, use 0-30. If you are in the rest of the world, 5-30 and 10-30 are just fine.
Just don't run a super heavy oil... 20-50 is a bad idea!
Modern engines are so tight that thick oil might not make it around the tightly machined passages.
I met this knowitall at Sebring a few years back. He just got a Mitsu Evo. The first thing he was doing? Changing to 20-50 motor oil. What a maroon. I know it's a turbo, but 20-50 is so not a good fit.
I know that BMW uses 10-60 in their M series motors. That is some expensive stuff... 9.00 a litre!
Then for expensive? Shell Helix. That is what Ferrari uses.
Posted on: 2008/3/30 21:32
pappyfreebird Re: what engine oil do you use ?
1028 Posts
10/30 mobil here
Posted on: 2008/3/31 0:02
93Moneypit Re: what engine oil do you use ?
Santa Cruz Ca
38 Posts
5-30 mobil 1
Posted on: 2008/3/31 20:33
C2C3C4C6 Re: what engine oil do you use ?
Sandwich, Illinois
63 Posts
Mobil 1 here 5w30
Posted on: 2008/3/31 21:18
CentralCoaster Re: what engine oil do you use ?
'85 L98 flat tappet motor - 15w40 Shell Rotella T.
Relating to Bogus' comment, really thick oil will increase your guage reading which seems good but that's because it's too damn thick to flow which means you're getting less lube to the cam and top end.
Posted on: 2008/4/1 0:17
yo mojo!
Question, when did you change the oil?
Were you running synthetic before? If not, that could be the cause...
Posted on: 2008/4/1 1:20
C4DERF Re: what engine oil do you use ?
332 Posts
Mobil 1, 5W30 every 4500 to 5000 miles with filter change at each oil change. Presently 111K on LT1.
Posted on: 2008/4/1 2:42
Oaklands Re: what engine oil do you use ?
Morristown, TN
480 Posts
Ditto, Mobil 1 5w-30 every 5000 with a new filter each change.
Posted on: 2008/4/1 3:03
LD85 Re: what engine oil do you use ?
Indianapolis, Indiana
784 Posts
10w30 Penzzoil or Q-state
Posted on: 2008/4/2 10:17
2005/Z51
Mr_Mojo Re: what engine oil do you use ?
Lakewood,NJ
225 Posts
I use Mobil 1 5/30, Costco has a coupon starting 4/4 for $8 off a case of 6.
Posted on: 2008/4/2 11:17
runner140 Re: what engine oil do you use ?
Ft. Lauderdale, Florida
721 Posts
I use Mobil 1 5W30 every 4000 miles with a K & N oil filter.
Think I'm up to 143,000 miles.
Posted on: 2008/4/2 11:31
boomguy Re: what engine oil do you use ?
Tacoma, WA
9 Posts
Royal Purple 5/30. Read an article in Vette Magazine or one of the other vette specific rags. It gave about 6hp gain over M1 and 2-3 over Castrol.
Posted on: 2008/4/3 21:10
I would rather die upon my feet than to have lived upon my knees!
Mekanic Re: what engine oil do you use ?
Tampa Bay Florida
827 Posts
M1 5-30 every 5000 with a Napa Gold filter (relabeled Wix for a lot less $$ )
Posted on: 2008/4/3 23:04
~Rich
Polo LT4
784 Posts
I dont use expensive oil becasue I pull my enigne every 18 months
Posted on: 2008/4/4 0:00
2005/Z51
Strick Re: what engine oil do you use ?
Lake Wylie, SC
129 Posts
This is correct info. Comp Cams told me to use this with flat tapet cams or their additive or the warranty is off. I guess it's the newer oils (after 2007) don't have maganise or zinc which is needed for flat tappet cam life.
I use Mobil 1 in my LT1. It sure keeps the engine clean.
Posted on: 2008/4/4 15:30
CasetheCorvetteman Re: what engine oil do you use ?
thats Shell Helix ULTRA they use in the Ferraris, its not expensive here!!
Anyway, cause oils aint oils, i use Castrol.
Wait til you open up the engine later in its life, then ask if it was really worth the 2 horses.
Posted on: 2008/4/5 11:39
1Fast04Vert Re: what engine oil do you use ?
Mobile One 5W30 and changed at 3500 mile intervals, 205,000 miles and going strong. 65PSI at cold start and stays at 60 psi cruising, never drops below 30 psi.
Posted on: 2008/4/5 19:33
bomar76 Re: what engine oil do you use ?
Marysville Ohio
37 Posts
Rotella Synthetic
Posted on: 2008/4/7 11:45
1987 Coupe
Automatic
Electronic Climate Control
