240 user(s) are online (203 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
Danspeed1 C5 Brake Upgrade - Still need Brackets
Mooresville, North Carolina
1121 Posts
Hello,
Well, I have most of the parts for my C5 Brake upgrade, but I am still lacking the brackets. Does anyone know where I can get a good set? I need to do this soon, my brakes are pretty much metal to metal.
Dan
Posted on: 2008/1/30 21:58
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
ninetyfivevette RE:C5 Brake Upgrade - Still need Brackets
Rhode Island
81 Posts
Exotic Muscle has a pair on Ebay here- though I've seen them much cheaper.
Here is a link to a drawing a saved a while back that has the dimensions for 88-96 caliper brackets here
I'm sure if you found a machine shop willing to do onesy-twosy type stuff, you could get these made a lot cheaper.
Posted on: 2008/1/30 22:30
Notorious RE:C5 Brake Upgrade - Still need Brackets
I wish I knew what Ed Salinas was doing these days and if he's still making them. His are immaculately engineered and were only $130 when I got mine from him. It didn't take me a hour to do the entire installation.
Posted on: 2008/1/30 23:16
I hate sporks...
BlkCpe RE:C5 Brake Upgrade - Still need Brackets
Georgia
23 Posts
i could use a set also.
Posted on: 2008/1/31 0:42
Danspeed1 RE:C5 Brake Upgrade - Still need Brackets
1121 Posts
If you find out let me know,
DG
Posted on: 2008/1/31 1:28
1996 Ford Explorer
2009 Cadillac CTS-v
RollaMo-LT4 RE:C5 Brake Upgrade - Still need Brackets
Trivia Winner
Rolla, Missouri
422 Posts
Didn't Jeffvette make them also?
You might send him a PM.
Posted on: 2008/1/31 1:42
1121 Posts
I wanted to get them from Jeff, but he seems to be having a problem getting them back from the guy who is plating them.
DG
Posted on: 2008/1/31 2:32
1996 Ford Explorer
2009 Cadillac CTS-v
1121 Posts
Anyone else?
DG
Posted on: 2008/2/2 4:40
1996 Ford Explorer
2009 Cadillac CTS-v
I'd be more than glad to. The problem is, his name became "a name that is not to be spoken of" over there a long time ago. I don't know that they ever outright banned him but they threatened to (he told me that himself) because people were always bringing his name up on the forum when the question of where to get brackets was raised. He only made them as a sideline but they were top-notch pieces and sold for much less than the name vendors' brackets. At some point he moved to another state too and so may have just quit making them after that, I don't know. The bottom line is I haven't heard anything about him in two or three years now.
Posted on: 2008/2/2 11:52
sliding RE:C5 Brake Upgrade - Still need Brackets
Zagreb, Croatia
326 Posts
These are from Ed]http://img406.imageshack.us/img406/6642/adapterifu5.jpg[/img]
Try to mail him if this is still his email:
edsalinas AT cox.net
Posted on: 2008/2/2 12:19
Matatk RE:C5 Brake Upgrade - Still need Brackets
If someone finds out, I am still waiting for a set, too. Hopefully someone can come through
Posted on: 2008/2/2 13:38
MK 82 RE:C5 Brake Upgrade - Still need Brackets
Palm Beach Gardens, FL
439 Posts
What makes the C5 calipers better than the J55s on my CE? How many pistons do they have? My CE stops pretty damn well with Hawk pads and powerslot rotors. Is it a looks thing or performance thing?
Anyone have a photo of J55 calipers next to C5s?
Please excuse the slight hijack.
Posted on: 2008/2/2 15:16
96 CE Roadster LT4
Zagreb, Croatia
326 Posts
C5 calipers are better design (heat wise). C4 calipers have problems
with venting.
Also, I believe C5 brake pads are bigger, therefore make more contact with rotor.
Posted on: 2008/2/2 15:43
439 Posts
I think the biggest differences are:
1. C5 has larger pad contact patch.
2. C5 rotors are thicker.
I also think that J55/GS calipers are more than sufficient unless you road race.
If you are just looking for the bling factor, GS/CE calipers with the black body and white raised letters are an option. Easily painted red. No adapters required as far as I know
Posted on: 2008/2/2 15:48
96 CE Roadster LT4
DrEvil RE:C5 Brake Upgrade - Still need Brackets
Get in mah belly!
71 Posts
The C5 stuff has a better initial bite due to the larger surface area of the pad in contact with the rotor. Droptop, for most people the stock J55 is good enough but even in autox events I could use more brakes. Another plus for the C5 brakes is cost. Rotors are about half price and pads are cheaper and offer more selection.
One last point, the J55 calipers also have a knack for spreading apart. The GS calipers are a bit stronger than the standard J55s but the C5 is much better.
Posted on: 2008/2/2 21:28
MyFatNutz RE:C5 Brake Upgrade - Still need Brackets
7 Posts
C5 calipers are MUCH larger and the rotors are 1.25" compared to the J55 1.1". Superchevyperformance.com used to have the calipers compared side by side C5vsC4
The J55 are probably similar performance street/everyday driving wise, but the C5 brake hardware is more readily available and much cheaper in the long run. Do a price comparison for new GM components and you'll see. I think when I did this conversion the Z06 calipers were $67, now they are (GM prices) $113. The GS caliper is $168 and non gs $200+
Obviously you can shop around for refurbs and generic rotors. On average though, C5 parts are less expensive. FOr example, the only rotors I could get local for the C5 brakes were raybestos brute stop, drilled and slotted for $65 a piece. The J55 brute stop rotor was $90.
Posted on: 2008/2/3 16:16
95 Yellow FE1, Zf6 LT1-->LT4 Heads, CompCams 304, pro magnum RR; C5/Z06 calipers/brake conversion
439 Posts
It would appear that the problem lies in availability of the brackets.
Posted on: 2008/2/3 16:31
96 CE Roadster LT4
Jeffvette RE:C5 Brake Upgrade - Still need Brackets
Hey guys, got back from Costa Rica and will have a update on the brackets today.
Jeff
Posted on: 2008/2/4 19:10
1121 Posts
Figured I'd keep this one alive.... ttt
Posted on: 2008/2/6 8:35
1996 Ford Explorer
2009 Cadillac CTS-v
439 Posts
I would buy a pair.
Posted on: 2008/2/6 15:13
96 CE Roadster LT4
1121 Posts
I wonder if any of the 3 vendors would want to do a Group Purchase?
DG
Posted on: 2008/2/6 15:17
1996 Ford Explorer
2009 Cadillac CTS-v
SpectatorRacing RE:C5 Brake Upgrade - Still need Brackets
Cost seems to be the main reason as stated above. Initial "bite" is more a product of pad compound than caliper selelction. Rotor thickness will help with cooling, but In a street application this is irrelevant. On track or Auto-X this is more important.
So...go with what you can get for less money up front and less money for replacement parts.
Posted on: 2008/2/6 20:29
1121 Posts
Been asking around.... no luck yet,...
DG
Posted on: 2008/2/10 0:52
1996 Ford Explorer
2009 Cadillac CTS-v
Jeff
Any particular "today" you had in mind?
I have mine but there seems to be plenty of interest. Hopefully you'll come through and treat them right.
Posted on: 2008/2/10 1:34
I hate sporks...
Jeff
Exasperated I finally got them tonight. I'm changing machine shops as well. 3 months on this last order was asinine.
email me at info@pnwzr1.com for brackets and I'll send out payment info.
Jeff
Posted on: 2008/2/11 6:17
Email sent!
Posted on: 2008/2/11 14:44
439 Posts
Jeff
Jeff
What's the price?
Posted on: 2008/2/11 16:33
96 CE Roadster LT4
1121 Posts
Ill send you out a paypal tomorrow morning....
DG
Posted on: 2008/2/12 3:08
1996 Ford Explorer
2009 Cadillac CTS-v
Dan, with your payment all brackets are spoken for.
If somebody doesn't pay, I'll make another post.
Posted on: 2008/2/12 6:19
rayquayle RE:C5 Brake Upgrade - Still need Brackets
139 Posts
Jeff, Did my payment get to you in time? I's hate to miss out on this again.
Posted on: 2008/2/12 9:12
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
Ray, I have plenty of the 85-87 brackets. You were never in jeopardy. It's the 88-96 brackets that go like hotcakes.
Posted on: 2008/2/12 17:24
1121 Posts
Last set of 89's are spoken for...
Payment Sent! :thumbleft:
Posted on: 2008/2/12 21:49
1996 Ford Explorer
2009 Cadillac CTS-v
139 Posts
Sweet! Thanks again.
Posted on: 2008/2/12 23:51
NCM Founder #2896
NCM Lifetime #672
And for the rears? Anything?
Posted on: 2008/2/13 1:14
Rimcrew RE:C5 Brake Upgrade - Still need Brackets
40 Posts
Well - I have been waiting since early December - I even offered to pay in advance... Am I doing something wrong?
Posted on: 2008/2/13 2:58
40 Posts
Posted on: 2008/2/13 2:59
Gearheadotaku RE:C5 Brake Upgrade - Still need Brackets
Michigan
52 Posts
When's the next batch coming around? I'm interested in making the swap before track season... price?
Posted on: 2008/2/13 3:16
In the servitude of my fiberglass Mistress
439 Posts
I wanted a set for my 96. What did I do wrong? Sounds like you need to crank out a few more and have some sort of organization to the sale.
Posted on: 2008/2/13 3:23
96 CE Roadster LT4
1121 Posts
Just to let you guys know so you don't feel like you've been forgotten,... I have waited since November. Jeff Really should crank out more sets of these things,... looks like alot of people really want them.
DG
Posted on: 2008/2/17 21:31
1996 Ford Explorer
2009 Cadillac CTS-v
DG
I'd suggest finding a more reliable source and being done with it. Damn shame that Ed's apparently not doing this anymore, but that's the way it seems to be. Spend a few more bucks and get it done, unless you want to wait indefinitely and with no guarantees.
Posted on: 2008/2/17 22:36
klkordzi RE:C5 Brake Upgrade - Still need Brackets
Pittsburgh, Penna
152 Posts
Not trying to undermine Jeff but Wdo-Mkr over on Digital corvette forum also sells them
Posted on: 2008/2/17 22:38
Don't worry about it. Those who don't already have them deserve a reasonable and reliable source for them. Post a link if you have one.
Posted on: 2008/2/17 22:47
439 Posts
I agree. I am looking elsewhere!
Posted on: 2008/2/17 23:10
96 CE Roadster LT4
Pittsburgh, Penna
152 Posts
Here you go. He is 11th post. I got my brackets from him with no problems. http://www.digitalcorvettes.com/forums/showthread.php?t=77136
Posted on: 2008/2/17 23:22
If you want another source go talk to Gene at electrodynamics for his set at 300 bucks.
Another source is wdo mkr, good luck getting a set from him as well. http://forums.corvetteforum.com/showp ... 61715450&postcount=70
Guys, these things are feast and famine. I try not to stock much of these and in the past my machinist/plater hae been able to turn out these sets in 3-4 weeks. Typically a batch will last me 6 weeks.I do not make much on these by the time I get them made and plated, I include high quality hardware and then include shipping. My next batch I think I will start to increase the price.
Most of you jumped onto a list when I was still on the CF before I was banned. Well after being banned and not having any access to PM's, well, I had no names to go by.
Posted on: 2008/2/18 3:21
cuisinartvette RE:C5 Brake Upgrade - Still need Brackets
Hopefully all works out..Ive had many dealings with Jeff and I totally trust the guy. The support afterward is what makes it worth it. Hours and hours of it, even a few small parts, cant complain .
Posted on: 2008/2/18 7:23
Pittsburgh, Penna
152 Posts
Jeff is a true friend to forum members and has never given me the impression that he is just trying to make money off of people. I have used him as a resource for technical questions several times and he is always willing to share the wealth of knowledge that he has.
Posted on: 2008/2/20 2:34
40 Posts
So can you put me on a new list? I'm still interested in a set.
Thanks.
Posted on: 2008/2/20 5:57
Got my brackets yesterday, couldn't be happier. I hope to get them put on in a couple weekends when I have time. Thanks again Jeff.
BTW, I was also waiting for brackets since November, so when I saw them come up I jumped on them. Jeff wasn't trying to give anyone the shaft, it's just the way things worked out with the machine shop. You can't control everything.
Posted on: 2008/2/20 14:35
Thanks Matt. let me know if you have any questions on the upgrade.
Thanks.
Yes, noted.
Guys, I just got back from a different machine shop. Their pricing for getting 10 sets made............ 380 per set. Delivery time 4-6 weeks. If I go up to 50 sets, price goes down to the 90's per set.
Posted on: 2008/2/20 19:30
