193 user(s) are online (142 user(s) are browsing Forums)
Assembly Line Diagnostic Link
jsup IT'S IN!!!! IT'S IN!!!!
1778 Posts
The motor is in, here's what a fresh 427 looks like in a car, almost assembled, and ready to run....
[IMG]http://pic80.picturetrail.com/VOL857/2991862/20410170/333885243.jpg[/IMG]
[IMG]http://pic80.picturetrail.com/VOL857/2991862/20410170/333885228.jpg[/IMG]
The trans cooler lines:
[IMG]http://pic80.picturetrail.com/VOL857/2991862/20410170/333885236.jpg[/IMG]
New trans pan:
[IMG]http://pic80.picturetrail.com/VOL857/2991862/20410170/333885261.jpg[/IMG]
[IMG]http://pic80.picturetrail.com/VOL857/2991862/20410170/333885274.jpg[/IMG]
I will be in this car on Saturday!!!! Then I can stop bothering you guys..
Posted on: 2008/9/10 0:12
NC Kid Re: IT'S IN!!!! IT'S IN!!!!
North Carolina
1671 Posts
:-( I liked your posting of troublesome things. Makes me feel better. J/K.
Posted on: 2008/9/10 0:16
North Carolina
1671 Posts
Plus your entertaining :D
Posted on: 2008/9/10 0:17
crash Re: IT'S IN!!!! IT'S IN!!!!
WRIGHT CITY MO 63390
977 Posts
dam that looks good hope your troubles are over and it runs like a bear
Posted on: 2008/9/10 0:18
CentralCoaster Re: IT'S IN!!!! IT'S IN!!!!
What's almost ready?
Nice pan. Except on my car those cooling tubes would be filled with oil grime from the motor.
Posted on: 2008/9/10 0:19
cuisinartvette Re: IT'S IN!!!! IT'S IN!!!!
Looks good J. Next time youre under there could you see how much clearance between the front of the pan and the crossmember? Maybe it could benefit some other C4 guys as some pans out there end up hitting.
I bet if AFR made pans, they wouldn't hit.
Posted on: 2008/9/10 0:20
jsup Re: IT'S IN!!!! IT'S IN!!!!
1778 Posts
The oil pan is hitting the cross member just slightly on teh passenger side, he's going to pull down the cross member and clearance it.
Posted on: 2008/9/10 0:24
North Carolina
1671 Posts
Whats it matter if it hits the crossmember?
Posted on: 2008/9/10 0:26
1778 Posts
I don't want it to hit the pan and cause a hole over time and lose all my oil
Posted on: 2008/9/10 0:28
1778 Posts
Almost ready means some cleaning up of vacuum hoses, install the distributor, give it a good once over, clean things up, add tranny fluid.
Stuff like that.
Posted on: 2008/9/10 0:29
It matters a lot, especially when the motor torques over.
Was worried about that when the initial pic of it came up a few weeks back, didnt want to say nothing.
Fixable though.
Posted on: 2008/9/10 0:35
North Carolina
1671 Posts
Hits on all vettes or just some?
Posted on: 2008/9/10 0:38
Mekanic Re: IT'S IN!!!! IT'S IN!!!!
Tampa Bay Florida
827 Posts
NICE!!!!!
Posted on: 2008/9/10 0:39
~Rich
Polo LT4
Qack Re: IT'S IN!!!! IT'S IN!!!!
274 Posts
Nice
When does it hit the dyno? We GOTTA know!!!
Posted on: 2008/9/10 0:49
1778 Posts
Qack wrote:
Nice
It hits the dyno when I get the tune right...
Posted on: 2008/9/10 0:53
joeld Re: IT'S IN!!!! IT'S IN!!!!
I would be going without food and sleep to fire that engine as close as it is! Good luck, and not trying to "arm chair your build" but please add coolant into that engine before it runs.
Posted on: 2008/9/10 1:01
1778 Posts
Who says I'm not.
Posted on: 2008/9/10 1:10
Matatk Re: IT'S IN!!!! IT'S IN!!!!
Looks awesome. I bet you've been walking around with a chub all day. I'm sure you're just dying to fire that bad boy up.
Posted on: 2008/9/10 1:27
TommyT-Bone Re: IT'S IN!!!! IT'S IN!!!!
33782 Posts
I am jealous. I don't envy anyone that often but I'll make an exception this time. It's been a long road but what a destination.
Posted on: 2008/9/10 2:28
BrianCunningham Re: IT'S IN!!!! IT'S IN!!!!
Posted on: 2008/9/10 2:46
Schrade Re: IT'S IN!!!! IT'S IN!!!!
Cool!
I got my cash ridin' on ya' now, to beat Calderone's lights!
Posted on: 2008/9/10 2:52
1778 Posts
Blade_1 wrote:
Cool!
Laying a bet in the fourth quarter? 8th inning?
:laughing2:
Posted on: 2008/9/10 2:57
biggrizzly Re: IT'S IN!!!! IT'S IN!!!!
Very Nice! I kinda know what your going through!
I'll post mine in another thread
Cheers - hope to see you soon
Posted on: 2008/9/10 3:18
1778 Posts
I'll meet you 1/2 way.. should be fun.....wanna race?
Posted on: 2008/9/10 3:23
1778 Posts
I have to add, these guys did a quality job. One hell of a fit and finish. They even went as far as to drill and tap a hole in the block to put a hanger for all the starter wires. They are going to custom cut a set of spark plug wires, really, really detail oriented. All those little things mechanics typically forget. They are going to fix one of my injector plugs which is cracked. I mean, really, really detailed.
Posted on: 2008/9/10 3:26
Happy to work on it probably means they're still making money on it, which is a good thing.
I work with contractors all the time, and the details all go out the window as soon as they get behind and start racking up unforseen costs, typically because they lowballed to begin with to get a job they maybe shouldn't have.
Posted on: 2008/9/10 3:40
jsup wrote:
Blade_1 wrote:
Cool!
:laughing2:
I always place bets after the third half!
Posted on: 2008/9/10 5:55
LD85 Re: IT'S IN!!!! IT'S IN!!!!
Indianapolis, Indiana
784 Posts
What CR did you go with ? 10:5-1 ?
Posted on: 2008/9/10 19:56
2005/Z51
1778 Posts
yep.
It runs......just spoke to them, they started it up.. Now it's just tweaking.
Posted on: 2008/9/10 20:22
784 Posts
Awesome, so 600hp at the FW is @ 510-RWHP (15% loss) ?
Posted on: 2008/9/10 20:28
2005/Z51
1778 Posts
I'm hoping so. If I can get to 500RWHP that would be quite an accomplishment. That's an on paper estimate.
Hey, LD, what do you think of these cam specs?
...........................Intake ..............Exhaust
Duration at .050 .......240 .................246
Lobe Lift .................. .378 ............ .378
Separation 112* ..........op-cl ...........op-cl
Timing Events at .050 12......... 48.......... 59........ 7
Duration at .006 ..........298 ................303
Gross Valve lift ..........604 .................604
Degree intake lobe 108
Fast ramp, high lift, moderate duration..I hear injected cars like that.
Posted on: 2008/9/10 20:32
784 Posts
I like the duration at the fact that it is Hyd-Roller but I don't think it will make 600HP, IMO, you would need a stout Solid Roller cam for this type of HP. I hope I am wrong.
My buddy makes 425 RHWP with is 246/246 solid roller @ 11:0-1 CR in his 406ci, some have done better than this but this is with professionally ported heads etc...
But if I was forced to "guess" at the RWHP I would say that 460 rwhp or possibly as much as 475 RWHP should be obtainable.
Posted on: 2008/9/11 1:14
2005/Z51
anesthes Re: IT'S IN!!!! IT'S IN!!!!
Boston, MA
I saw low 500s at the flywheel. Maybe 530.
-- Joe
Posted on: 2008/9/11 1:22
Maybe good enough for 200 mph! Nice knowing you.
Posted on: 2008/9/11 1:36
Always the optimist
PS - if you need someone to test drive it for you, I'll PM my number!
Posted on: 2008/9/11 1:42
1Fast04Vert Re: IT'S IN!!!! IT'S IN!!!!
Wow! Looks awesome, bet it runs even better.
Posted on: 2008/9/11 2:30
1778 Posts
Picking it up after work.....will try to get some video.
It's going to rain all weekend and I didn't want to go down on Saturday.
Posted on: 2008/9/11 18:31
red_johnny Re: IT'S IN!!!! IT'S IN!!!!
Awsome news!!
Posted on: 2008/9/11 18:50
John, How close are you to Lancaster County PA?
I'm pretty sure I may be going up to an autocross up that way in two weeks on the 21st.
Posted on: 2008/9/11 19:08
1778 Posts
Call me or PM me your number.
Sounds like I can make it....
Posted on: 2008/9/11 20:18
