231 user(s) are online (119 user(s) are browsing Forums)
DaleD Very bad day.
Cuyahoga Falls, Ohio
1389 Posts
No rain in the forecast, go out to drive my Corvette to work. As I'm sitting in the garage warming it up, I notice lots of smoke. Lots of smoke. White smoke, continuous. Not just a puff on startup. I didn't have time to look at anything I had to get to work, where I am now.
I think I'm just going to have to park it. I can't afford head gaskets right now.
Posted on: 2008/6/24 12:54
CSS996 Re: Very bad day.
Mega Guru
Central PA
3644 Posts
Oh no...
Sorry man.
Posted on: 2008/6/24 13:00
Currently "Between Vettes".
DaleD Re: Very bad day.
1389 Posts
I know. I've been toying with selling it. If anyone is interested in an 87 with lots of new parts, I would be willing to listen.
Posted on: 2008/6/24 13:50
pianoguy Re: Very bad day.
Major suckage
Posted on: 2008/6/24 14:01
1Fast04Vert Re: Very bad day.
Well that truly sucks. Any chance it is something less costly?
Posted on: 2008/6/24 14:24
red_johnny Re: Very bad day.
Well before you close the books on it take a look. Might be something else.
Posted on: 2008/6/24 14:26
1389 Posts
I guess it's possible, but I'm not quite sure what would make white smoke, besides a head gasket.
Posted on: 2008/6/24 14:29
Matatk Re: Very bad day.
Ugh that sounds crappy. I believe white smoke (especially continuous) is a sign of coolant/water leak such as a bad head gasket. Let us know what you find out.
Posted on: 2008/6/24 14:44
Yeah but you might catch a break. It does sound like a head though.
Posted on: 2008/6/24 14:48
dan0617 Re: Very bad day.
Dude, don't sell your car over a head gasket. Many on here will walk you through the job, it really isn't bad if you take your time. If your car isn't your daily driver then you don't need to be in a hurry doing it. It's just alot of bolts. Also, you can upgrade your head gasket to a thinner one to pick up some ponies, then upgrade other things on the reassembly if you have the money. If not, just put it back together. You will respect your car so much more after you have been into the motor and back out.
Posted on: 2008/6/24 15:07
bogus Re: Very bad day.
head gasket is the logical problem... could also be intake.
Posted on: 2008/6/24 16:29
1389 Posts
Intake? White smoke? I don't understand.
Posted on: 2008/6/24 16:36
CentralCoaster Re: Very bad day.
Corrosion between the head and intake base can let coolant under pressure leak into the lifter valley and into the oil pan on L98s.
Common with iron heads. But if you have aluminum heads, I'd bet on a bad head gasket first. Do you have an oil cooler by chance? Maybe if you're lucky that's your source of coolant. Never seen it happen personally, but...
Posted on: 2008/6/24 16:58
1389 Posts
No oil cooler. It's an 87, aluminum heads. Waiting on a quote.
Posted on: 2008/6/24 17:00
Nevermind, none of that will cause white smoke. Now I see why you asked.
I think a head gasket job goes for about $50 + labor these days.
Posted on: 2008/6/24 17:02
1389 Posts
As usual, an inexpensive part will generate a big bill. I called a guy who's working a quote, he says he does a valve job and mills the heads while he has them off.
Anyone want to buy a car?
Posted on: 2008/6/24 17:28
Mega Guru
Central PA
3644 Posts
I know you are feeling beat down by your car. But just chill for a few days. Do you really HAVE to do the milling and the valves?
Just replacing the gaskets wouldn't be TOO bad.
Don't leave us, man. Just give yourself a little time to cool down.
Posted on: 2008/6/24 18:01
1389 Posts
It depends on what the estimate looks like.
This isn't a standard shop, it's a guy that is a circle track racer who does repair/builds to pay for his addiction.
If I were to keep it, I'd want it done right.
To sell it, I'd assume a buyer would want it done right.
Yeah, I have a roof that leaks, and a wife that wants new windows to the tune of $8k. So, this comes at a bad time, and makes me think it may be a sign that my Corvette days are numbered.
Thanks for the good words though.
Posted on: 2008/6/24 18:16
FLYINLOW90 Re: Very bad day.
Windsor Ontario Canada
514 Posts
Hey Dale sorry to hear about this.
Really sux when these repairs come to light on these cars. It never is a good time.
I remember the year I had to replace my injectors. Two weeks
Later the 3/4 clutch pack goes in the tranny. A very expensive summer for the Vette.
Hopefully you won't need to sell.
I do like your attitude about the repair though. If you do it your going to do it right and if you have to sell it the new owner will want the repair done right
Take Care Man
Gary
Posted on: 2008/6/24 18:45
To hell with the head rebuild, that's where everything starts adding up. Just clean the heads up nice, maybe even scuff them with some very fine grit paper on a block if you think the surface is too slick and slap em on.
Posted on: 2008/6/24 19:00
81c3 Re: Very bad day.
Colorado
143 Posts
Dont give up. A head pull on a SBC is easy even if youre a novice. The only special tool you really need is a torque wrench, which you can borrow or rent. The rest is just nuts and bolts. Just follow along in the Chiltons or FSM. We can help you here also.
Posted on: 2008/6/24 19:58
This is where older cars start to beat you down.
If it's paid for, keep it. I agree with CC, scuff the head/block and be done with it. At this mileage, short of doing valve seals, I wouldn't waste the $$.
I am also with 81c3, this is a DIY project. Just dedicate a weekend.
Posted on: 2008/6/25 5:51
patgizz Re: Very bad day.
Medina, OH
228 Posts
FYI unless you have big huge windows or want something other than vinyl, it shouldnt be 8 grand unless you have 24 of them in the house. it's what i do and i can give you a quote if you want.
and i'll offer a hand or advice if you decide to take on the head gasket job.
i'd buy if i did not have a bunch of other projects
hell i'd even think of offering to do your windows in trade for the car if it were feasible on both sides.
Posted on: 2008/6/25 18:39
Colorado
143 Posts
Hey, arent you from the NastyZ28 site? My username is JOHNNYMO overthere! Whats up with your second gen these days? I sold my 79Z28 a few years back and have been into these frikken plastic cars ever since!
Posted on: 2008/6/25 19:35
LT4BUD Re: Very bad day.
52 Posts
Perhaps a stupid question...but is it coming out the exhaust pipe??? Everyone appears to have assumed this, but you don't really say...
BTW my 1989 got lost in a cloud of smoke from oil leaking onto the exhaust manifold...it indeed was continuous and catastrophic looking...almost blocked my vision at a stop sign....not a blown head gasket
Good luck...
Posted on: 2008/6/26 0:36
1389 Posts
Good luck...
Yes, it is coming out of the tail pipe.
Posted on: 2008/6/26 1:08
1389 Posts
We've got 18 windows, a few of them are pretty big. It's a spilt level. I've had 2 quotes, if you want to give me one, can't hurt to have another quote. I am in Cuyahoga Falls, so it's a little hike for you. PM me if you want. As for windows for the car, depending on your quote and the quality of the windows, there could be cash involved.
Posted on: 2008/6/26 1:12
1389 Posts
It took me all weekend to do a tune up. And even that bit me in the ass. As Clint Eastwood said: "A man's got to know his limitations."
I can't even imagine me doing this in less than 3 weekends. My time is worth more than that. I don't want to be overly negative, but I never even imagined doing this type of repair when I bought the car. I've done what I think is within my ability.
Posted on: 2008/6/26 1:16
You'd be amazed what you can do. I was 17 when I changed the head gaskets on my s10 blazer - I had to do it over the weekend so I could drive to school Monday morning. I had never done any serious work to a car before but surprised myself with how well I did. I just followed the instructions in the book and had a little help from my neighbor adjusting the rockers. I guarantee that you are capable of doing this. Just have a little confidence in yourself!
Good luck!
Posted on: 2008/6/26 1:41
JDSWHITE93 Re: Very bad day.
Ohio
334 Posts
You are too critical of yourself, you got the tune up done. There are no extra points for style or speed. I have a nice Snap On 1/2 cordless electric impact and a torque wrench, will travel. Hell it would be fun to tear your car down and then say something like wow I wonder where all this shit goes..... Just kiddin man, I do have tools and will help though. Car might be down for a couple of weekends but so what it's better than paying out the ass.
Posted on: 2008/7/1 23:25
1389 Posts
Thanks for the offer JD. I couldn't ask you to spend that kind of time on my car. Downtime isn't an issue. But it does have to be fixed.
I'll bite the bullet and go with the guy down the road from me.
Seriously, thanks for the offer, I know you'd do it if I asked.
Posted on: 2008/7/2 1:42
Livin_the_dream Re: Very bad day.
robesonia , pa
516 Posts
Dale
hope it all works out for you. Doing it right while a little more money adds to reliabilty. And who knows you might want to keep it.. oh and about all the offers check out the mid east section of this forum and you will see an exhaust install. Out here a lot of us get together, work talk cars, have pizza go for a drive when done! lots of fun and usually everybody learns. for that C5 we had like 15 people hanging out working.
http://www.corvette-guru.com/modules/ ... hp?topic_id=2970&forum=46
Posted on: 2008/7/2 2:18
Ohio
334 Posts
I think you could do it as long as you realize that it will take twice as long as it should and will not go according to plan. Nothing I work on goes as planned. I have gotten used to it. My mother in law needed front brakes on her Neon a few months ago. Simple enough job right ? A caliper bolt broke off flush trying to take it out and the piston in one of the calipers cracked in half. A simple brake job involved two extra trips to the parts store and a helicoil kit before it was over. One of the first things I did to my 93 was a gear swap which went smoothly until the cover was seeping gear lube, I got the bright idea to retorque the bolts and stripped one, so I had to pull it out AGAIN and bust out the helicoil kit.
Posted on: 2008/7/2 17:56
I figure my average home improvement project requires 5 trips to Home Depot (including the first one to get everything I need).
Posted on: 2008/7/2 18:29
Well Dale, glad you're gonna get it fixed. Just don't let them talk you into dropping in a supercharged 406!
Posted on: 2008/7/2 18:52
cuisinartvette Re: Very bad day.
At least have the heads checked for cracks and sufaced/checked for warpage. Would be a bummer to do all that work only to do it over again. Hang in there.
Posted on: 2008/7/2 20:22
BrianCunningham Re: Very bad day.
may not be the gasket
Posted on: 2008/7/3 2:11
Livin_the_dream wrote:
Dale
I agree, there are always friends around to lend a helping hand. Sometimes you just gotta ask. Might only cost you a case or two of been in most cases.
Posted on: 2008/7/3 2:17
2hip4u Re: Very bad day.
6 Posts
I know this is going to sound peculiar, but what does the white smoke smell like? Does your car have an automatic transmission?
I don't know the particular configuration of Corvette automatics, but many automatics draw operating vacuum from one of the cylinders. There is a valve that prevents transmission fluid from back flowing into that cylinder. If this valve fails, fluid can get into the cylinder and burn white. Transmission fluid smells different from coolant.
Posted on: 2008/7/3 13:41
