289 user(s) are online (225 user(s) are browsing Forums)
TommyT-Bone How Do You Spit Out Of A C4 Window Opening ?
33766 Posts
It's almost like a sporting event. It involves position, timing and execution.
1) Roll down the window
2) Prepare for expulsion
3) Leave plenty of room to the front and rear
4) Adjust speed
5) Turn your head 90' to the left and butt
your head against the base of the top
(Right hand drivers turn to the right 90')
6) Quickly and forcefully expel orally contained materials
7) Regain control and begin lane centering of your C4.
If you have done this correctly there will be no spittle on your shirt, your door panel or the side of your beautiful machine. Maybe one of those two little holders in the console is really for a mini spittoon?
Posted on: 2008/6/16 23:42
red_johnny Re: How Do You Spit Out Of A C4 Window Opening ?
Posted on: 2008/6/17 0:01
Notorious Re: How Do You Spit Out Of A C4 Window Opening ?
If you have a nice loogie with some bulk to it, you should be able launch it with enough velocity that this shouldn't be an issue.
Posted on: 2008/6/17 0:19
I hate sporks...
pianoguy Re: How Do You Spit Out Of A C4 Window Opening ?
LMAO! That's about all those factory cup-holders are good for.
Posted on: 2008/6/17 0:58
Calm Re: How Do You Spit Out Of A C4 Window Opening ?
Vancouver, Canada
608 Posts
Is this one of dem Spit or Swallow threads?
Posted on: 2008/6/17 1:07
Danspeed1 Re: How Do You Spit Out Of A C4 Window Opening ?
Mooresville, North Carolina
1121 Posts
You've actually been sitting around thinking about this???
Posted on: 2008/6/17 4:01
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
bogus Re: How Do You Spit Out Of A C4 Window Opening ?
This is why I keep McDonalds napkins in my car.
Posted on: 2008/6/17 5:16
Personally, I am waiting for the vector analysis diagram.
brian Re: How Do You Spit Out Of A C4 Window Opening ?
193 Posts
i have the targa top off. so i just look up and spit. works really nice.
Posted on: 2008/6/17 7:00
runner140 Re: How Do You Spit Out Of A C4 Window Opening ?
Ft. Lauderdale, Florida
721 Posts
Tommy,
How's your cold?
Posted on: 2008/6/17 11:50
1Fast04Vert Re: How Do You Spit Out Of A C4 Window Opening ?
This manuever is best executed when you have a kid in a Civic with his fart can mufflers right behind you.
Posted on: 2008/6/17 13:05
Matatk Re: How Do You Spit Out Of A C4 Window Opening ?
What's our vector, Victor?
Posted on: 2008/6/17 13:25
j3studio Re: How Do You Spit Out Of A C4 Window Opening ?
Carefully...
Posted on: 2008/6/17 13:32
BrianCunningham Re: How Do You Spit Out Of A C4 Window Opening ?
Now if you can tell me how to ash my cigars out the window w/o getting ash all over the body.
Posted on: 2008/6/17 13:48
NC Kid Re: How Do You Spit Out Of A C4 Window Opening ?
North Carolina
1671 Posts
Posted on: 2008/6/17 14:41
Lichen Re: How Do You Spit Out Of A C4 Window Opening ?
Scottsdale, Arizona
166 Posts
How many shots of Ny-Quil have you had?
Posted on: 2008/6/17 17:29
CSS996 Re: How Do You Spit Out Of A C4 Window Opening ?
Mega Guru
Central PA
3644 Posts
I do not smoke... Primarily so I do not have to stick my ash outside of the car at any point in time...
Brian... You car smells like ash.
Posted on: 2008/6/17 19:25
Currently "Between Vettes".
One of the corniest, yet funniest comedies ever!
Another high level, intellectual discussion brought to you by your friends at Corvette Guru.
Posted on: 2008/6/17 22:44
Haha...glad someone else got a kick out of it!
And don't call me Shirley!
Posted on: 2008/6/18 2:35
Dads90 Re: How Do You Spit Out Of A C4 Window Opening ?
Pearland, Tx
318 Posts
There is actually a vacuum spot. Sorta slightly 8 inches above and 1 inch behind the rear quadrant of the driver side mirror. If you hit that spot exactly the luggie will propel itself out and away form the car. It takes lots of practice, and I'm presently at a 60 % rate.
Posted on: 2008/6/18 4:08
Cigar bar actually Resized Image
Don't worry people are allowed to hang their head out the window when I drive :D
Posted on: 2008/6/18 15:14
BillH Re: How Do You Spit Out Of A C4 Window Opening ?
Spit only in right hand turns. That way, the bodywork is moving away from the projected loogie flight path.
Posted on: 2008/6/18 15:36
Aardwolf Re: How Do You Spit Out Of A C4 Window Opening ?
Fremont, WI
209 Posts
Spit on a cat then throw it out the window???
Posted on: 2008/6/18 16:48
SpectatorRacing Re: How Do You Spit Out Of A C4 Window Opening ?
You guys need to date sluttier women. Then she won't have this issue.
Posted on: 2008/6/18 18:48
OMG LOL
Posted on: 2008/6/18 22:52
TommyT-Bone Re: How Do You Spit Out Of A C4 Window Opening ?
33766 Posts
That's worth a shot. Don't know what the hell this has to do with anything but it is definately worth a shot.
Posted on: 2008/6/18 23:34
S-L-U-T
She may be a slut but she looks good to me
-Todd Rundgren
From the song appropriately entitled "Slut."
Posted on: 2008/6/19 12:54
She won't have to spit...
Posted on: 2008/6/24 19:37
Z51 Re: How Do You Spit Out Of A C4 Window Opening ?
OREGON
127 Posts
haha, greatest movie ever....
Posted on: 2008/6/27 11:52
1990 roadster
33766 Posts
SpectatorRacing wrote: She won't have to spit...
Now I get it ..... :sign7:
Posted on: 2008/6/27 12:41
daddue11 Re: How Do You Spit Out Of A C4 Window Opening ?
Mountain View, Southern Mo.,
131 Posts
Don't spit out the window,do like I do,shoot your loogie on the windshield and let it run down to the defroster vent turn on the fan and let it dry up the ooz and then scrape it off at the end of your trip.
If ya got a real good woman she'll let you use her cell phone to scrape it off.
Posted on: 2008/7/3 21:40
Aint no amount of gold in any ole mine,that would be enough to take away this car of mine.-beach boys
Mega Guru
Central PA
3644 Posts
You live in a whole other world, mister!
Posted on: 2008/7/4 1:51
131 Posts
Just kiddin,I'd kill anyone that spit in or at my Vette,I just like to say off the wall crap.
Posted on: 2008/7/4 16:44
